Rear wiper and front/rear wash stopped working
Recommended Posts
Help!
Anyone got any ideas on this problem?
My front and rear screen washers have both stopped working, as well as the rear wiper.
The front wipers and headlight washers behave normally - when I go to do a front screen wash the wipers operate, as well as the headlight washers, so I don't suspect the stalk.
Fuses for wipers and screenwash seem OK - is one common fuse for the washers and one common fuse for the wipers?
Not had chance to do a scan yet.
Are there any relays or fuses in the engine compartment I should be looking at as well? Is there a relay on the CEM that could be at fault?
I am not aware of any leaks of screen wash into the car anywhere, and the bottle isn't losing fluid either.
They worked two days ago, today they didn't.
Link to comment
Share on other sites
Funnily enough, checked that when I realised the rear wiper wasn't working. Tailgate is shut, and maxidot thinks it is shut as well. At first I thought just the washer circuits had failed. I will do a scan in the morning and see if anything shows up.
Link to comment
Results from the scan are:
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 1K0 937 049 N HW: 1K0 937 049 N*
Component: Bordnetz-SG H34 0803
Revision: 00H34000 Serial number: 00000001438632
Coding: E18A8F21101E140000110D00000000000009FF0F5C
Shop #: WSC 00368 210 56181
VCID: 3A7F36DB0E9F
Subsystem 1 - Part No: 1Z2 955 119 A
Component: Wischer SK351 012 0401
Coding: 00065525
Shop #: WSC 00368
Subsystem 2 - Part No: 1K0 955 559 R
Component: RegenLichtSens 010 1010
Coding: 00471077
Shop #: WSC 00368
3 Faults Found:
02401 - Terminal 75x
012 - Electrical Fault in Circuit
02398 - Control Circuit for Rear Windshield Washer Pump
009 - Open or Short to Ground
00897 - Windshield Washer Pump (V5)
Is this looking like a new pump needed? If so, do you reckon Halfrauds will stock them? as I am driving to Somerset tomorrow morning so could do with sorting it today.
Link to comment
You are a star - I can always pop round if you have a spare :-)
I had a funny feeling it was the pump as it seemed a bit on the weak side the last time I used the washers on Thursday, and louder than normal.
I can always pick one up from TPS Bristol next week - I wonder if they will let me use a trade account from Sheepbridge TPS there?
Link to comment
Sussed it out - it is the bottom right hand relay on the CEM. If I swap it for the fuel pump relay the washers and rear wiper work.
it has 460 on the top and part number 1KO 951 253A
Looks like I need to call in to TPS on my way to Somerset tomorrow......
At least it is only a £5 part that has gone and not anything expensive!
  • Like 1
Link to comment
  • 4 years later...
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
