Zenec ZE-NC2011D Facia Help
Evening,
I'm looking for some advise with my Zenec ZE-NC2011d install please.
Basically I've finally installed my Zenec 2011d after my original Zenec got stolen but that's a whole other story...
The head unit is installed and everything is working fine, it's just the cosmetics now.
https://truck.it/p/Pf6_D0VaeI
From the picture (link attached) you can see that the head unit is just a standard double din fitment not shaped like the Bolero or Columbus units.
I've seen a couple of YouTube videos that show what look to be full replacement facias and wondered where I could get one for my 2012 FL Octavia.
If you need any other photos just let me know.
Rob
The part / fascia that I appear to have been looking for is the following: ct24sk02
Rob
That does not look right for an Octavia despite what the description says. The surround needs to include the area around the aircon/heater controls. Assuming its the one in the pictures then its wrong.
It looks to me that the adapter would fit within the existing trim to convert the space normally occupied by the Bolero/Stream (as it's the larger shape) to the standard shape therefore itw ouldn't need to cover the area around the aircon controls as the original trim will still be in place.
John
The fascia has arrived and mannyo you are rights its the wrong fascia.
I'm not beat yet though, the shape is perfect for the corners so I'm in the process of using my Dermel to gently sand the fascia back into the correct shape.
I think there is a good couple of hours work in getting it into shape.
For 10 quid its worth chopping it up!
I'll try and remember to post pics when I'm finished.
Rob
