Starting Issues with Skoda Fabia 2002 model
Recommended Posts
I recently got my Skoda Fabia 1.4 16v(Gasoline engine),it has be parked for quite sometime...it is not starting at all. Diagnostic check was done & everything is fine..but it still would not start.The mechanic said the spark from the coil pack is not strong enough to start the engine,i replaced 1 coil pack & the spark still looks weak.. Can someone please help.
Link to comment
Share on other sites
Have you put fresh petrol (gasoline) in it. Old fuel goes stale with age and makes starting difficult.
If its sparking then it should at least attempt to run.
Have you checked the plugs for dampness? If the fuel is getting to the cylinders and not being burnt then the plugs should show signs of dampness at the electrodes.
Edited by ilikeradios
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
