Octavia tdi cutting out at roundabouts
Recommended Posts
Hi, have had this happen 4 or 5 times since buying the car ( about 8 months ago). Car is 56 reg octavia vrs tdi, when slowing down at roundabouts or junctions the car loses all power and battery light shows, car starts first turn of the key everytime. Today it did it at a roundabout then 2 minutes later at a junction then again at a roundabout 10 minutes later. It was fine after that but will have to find out what is causing this and wondering if anyone has any ideas? Would there be any fault codes stored?
Link to comment
Share on other sites
You should some fault codes stored. The 109 relay is the ECU power relay, when it goes wrong all kinds of craziness can ensue. But I don't think the mkII has exactly the same relay.
Worth finding someone near you with VCDS. A scan should shine some light on the problem.
Link to comment
Ok cheers will try and get someone asap as it is pretty dodgy when you don't notice it's cut out, was going to take it to Skoda dealer but they want silly money to plug in a machine and probably tell me they can't find anything.
Link to comment
Perhaps a clogged fuel filter.
It will allow less than full flow so peak demands will result in poor acceleration and top speed/power.
Coming off the power at roundabouts/junctions may just be the trigger to briefly starve the engine enough to stall.
As suggested, get it scanned and see what IT thinks is wrong.
Link to comment
Without knowing all the specifics it's not easy.
A generic OBD scan would be the first step and if that shows a blank then a more in depth VCDS scan should show something.
Assuming the engine is fine otherwise, running smooth and even, pulls strongly when floored in 3rd up an incline when max fuel is demanded and reaches max rpm freely then I think it's safe to rule out under fueling.
It would suggest to me a sensor somewhere has got an issue, poor connection/dirty/faulty.
But it's early and I'm not Scotty without coffee!
Get it scanned and let us know the results.
Link to comment
Interesting. Mines been doing similar over a period of time but only once every 4-6 weeks or so but as per the OP, when I slow to junctions or roundabouts, basically when I change down to 2nd gear, it stalls. Starts immediately.
Also when using cruise control the other day (set to 60), going up hill and it started slowing down, cruise was still engaged though but had to Chang down to 403rd to get any power... Been fine since and that was over a month ago. All linked?
Let me know if things improve re new sensor or whatever. Thanks
Edited by Ciderspace
Link to comment
Mines was big gaps inbetween aswell just the one time that it's happened so close together, will post anything I find out.
Link to comment
Yeah it had it done years ago with the first owner can't remember when exactly, it wasn't marked down on the service book but I phoned up Skoda uk and was told it had been done
You might find the car will really begin to suffer with cold starting issues when the temperatures begin to fall this winter. I'm guessing at 8 months you haven't run it through a winter yet?
This thread is a bit heavy but there are lots of examples of random stalling and poor cold starting from owners who have had the injector recall done. You'll be able to see my tale of woe too...
http://www.briskoda.net/forums/topic/189502-cold-start-problems-with-a-pd-tdi-170/page-1?hl=+poor
Link to comment
Meeting someone local with vcds tomorrow evening so hopefully can find out what the problem is, is it just a case of plugging in and scanning the car for any fault codes or is there other things we should be looking for?
Link to comment
Last night Dave was round at mine for me to plug in VCDS and scan the data from the car. This is was I retrieve on the initial connection to the car:
Tuesday,30,September,2014,19:14:54:37412
VCDS Version: Release 11.11.0 (x64)
Data version: 20111111
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: TMBEH21Z478014258   Mileage: 130820km/81287miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine        Labels: 03G-906-018-BMN.clb
   Part No SW: 03G 906 018 EL    HW: 03G 906 018 EL
   Component: R4 2.0l PPD1.2 G    9953
   Revision: --H22---    Serial number: SKZ7Z0F3754501
   Coding: 0000072
   Shop #: WSC 20033 576 82832
   VCID: 73EFAE6812AE376
No fault code found.
Readiness: N/A
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
   Part No SW: 1K0 907 379 AC    HW: 1K0 907 379 AC
   Component: ESP FRONT MK60      0101
   Revision: 00H11001
   Coding: 0006786
   Shop #: WSC 73430 790 00000
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No: 1Z0 907 044 H
   Component: ClimatronicPQ35 084 0305
   Shop #: WSC 00000 000 00000
   VCID: 3B7F46487A7EBF6
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 3C0 937 049 E    HW: 3C0 937 049 E
   Component: Bordnetz-SG     H37 1002
   Revision: 00H37000    Serial number: 00000004312460
   Coding: 01880F030004140000110D000000000000087F075C
   VCID: 2B5F76088A1E2F6
   Subsystem 1 - Part No: 1Z2 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer SK351  012  0401
   Coding: 00063477
   Shop #: WSC 73430
8 Faults Found:
01501 - Bulb for Blinkers; Rear Left (M6)
            012 - Electrical Fault in Circuit - Intermittent
             Freeze Frame:
                    Fault Status: 00101100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 59
                    Mileage: 130214 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 5.00 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
01505 - Bulb for Blinkers; Rear Right (M8)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 59
                    Mileage: 130214 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 5.00 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
00987 - Lamp for Brake Light; Left (M9)
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 59
                    Mileage: 130214 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 5.00 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
00988 - Lamp for Brake Light; Right (M10)
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 59
                    Mileage: 130214 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 5.00 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
01506 - Bulb for Rear Fog; Right (L47)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 59
                    Mileage: 130214 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 5.00 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
01518 - Bulb for Back-Up Lights; Left (M16)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 59
                    Mileage: 130214 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 5.00 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
01519 - Bulb for Back-Up Lights; Right (M17)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 59
                    Mileage: 130214 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 5.00 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
00926 - Terminal 30
            011 - Open Circuit
             Freeze Frame:
                    Fault Status: 01101011
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 49
                    Mileage: 119826 km
                    Time Indication: 0
             Freeze Frame:
                        OFF
                    Voltage: 5.00 V
                        OFF
                        ON
                        OFF
                        OFF
                        OFF
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 T    HW: 1K0 909 605 T
   Component: Q4 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD0NJ2RY
   Coding: 0020788
   VCID: 3D7B4850646AB16
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 BK    HW: 1K0 953 549 BK
   Component: J0527           051 0101
   Coding: 0001042
   Shop #: WSC 04766 210 92258
   VCID: 7CFD85543FF078E
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No SW: 1Z0 920 912 E    HW: 1Z0 920 912 E
   Component: KOMBIINSTRUMENT VD1 1610
   Revision: V1610036    Serial number: SKZ7Z0F3754501
   Coding: 0003401
   Shop #: WSC 20026 067 57207
   VCID: 37775A7846569B6
Address 19: CAN Gateway        Labels: 1K0-907-530.lbl
   Part No SW: 1K0 907 530 H    HW: 1K0 907 951
   Component: J533__Gateway   H12 0150
   Revision:   H12       Serial number: 31001067260963
   Coding: 3D3F034007001303
   VCID: 2C5D75148F1028E
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO            VD1 1610
   Shop #: WSC 20033 576 87174
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN3.lbl
   Part No SW: 1T0 959 701 D    HW: 1T0 959 701 D
   Component: Tuer-SG         005 0954
   Coding: 0000756
   VCID: 387559444B4894E
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K2 909 144 L
   Component: EPS_ZFLS Kl.074 H07 1806
   Shop #: WSC 20033 576 175713
   VCID: 356B50705C5A696
Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb
   Part No SW: 1K0 959 433 BT    HW: 1K0 959 433 BT
   Component:    KSG PQ35 G2  020 0202
   Revision: 00020000    Serial number: 00000000000000
   Coding: 01801A085283007F3F04850540085F96907CA0
   VCID: 830F7EA8C20E876
   Subsystem 5 - Part No: 1Z0 951 171
   Component: Innenraumueberw.008
   Coding: 00000000
   Shop #: WSC 20033
   Component:   Sounder No Answer
   Component:       NGS n.mounted
1 Fault Found:
01134 - Alarm Horn (H12)
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 4
                    Fault Frequency: 254
                    Reset counter: 175
                    Mileage: 110020 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 11:42:12
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN3.lbl
   Part No SW: 1T0 959 702 D    HW: 1T0 959 702 D
   Component: Tuer-SG         005 0944
   Coding: 0000756
   VCID: 39735C4070428D6
1 Fault Found:
00110 - Right Mirror Turn Signal Lamp (L132)
Address 56: Radio        Labels: 1K0-035-1xx-56.lbl
   Part No SW: 1Z0 035 161 C    HW: 1Z0 035 161 C
   Component: Radio FO3       019 0034
   Revision: 00019000    Serial number: SKZ7Z3F0044042
   Coding: 0000402
   VCID: 2E597F1CB90C5AE
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN3.lbl
   Part No SW: 1K0 959 703 J    HW: 1K0 959 703 J
   Component: Tuer-SG         005 0907
   Coding: 0000144
   Shop #: WSC 73430 790 1012544
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN3.lbl
   Part No SW: 1K0 959 704 J    HW: 1K0 959 704 J
   Coding: 0000144
End   ---------------------------------------------------------------------
Immediately my first port of call was to check the data on the engine controller, but there were no fault codes and nothing from the measured values. Now i've been on Ross-tech most of this morning to try and figure out what Malfunction 0010 means but had no luck.
During last night I took Dave's car for a test drive and it pull and drives really well and it's previous owner has looked after the car which this shows throughout.
I'm stumped Guys...
Link to comment
I would save the scan and then clear the codes and see what comes back.
Looks like you may well require a new alarm module - the internal batteries go after about 6 years and cause issues - can result in flat main battery if you are unlucky - use search as it has been discussed a number of times.
Those central electrics errors may suggest that you have a damp central electrics module, but could also mean that the car has been on with the rear clusters removed, so clear them and see if anything comes back.
Other things that could cause stall issues like that are the lift pump in the tank and the tandem pump which acts as a fuel pump and vacuum pump.
If there was a relay 109 issue I'd expect some other electrical errors probably on the Engine ECU and possibly loss of communication in the ABS ECU.
Link to comment
Will have a look at the links when I get home tonight, has the alarm battery being flat been known to cause stalling problems? Not long after I got the car there was a few days where the alarm would go off for no reason and I had been advised was probably the alarm battery was on its way out and had been going to replace this but the alarm stopped going off so didn't bother changing it, is there any way to check if this is the problem?
Link to comment
I tried to clear any codes that may have been there, but weren't appearing as a matter of course and re-ran the scan with the same issue appearing for Engine: Malfunction 0010 as displayed in my OP.
The engine dying off at idle would suggest a fuel supply fault, however, as mentioned I had the car out on a test drive and it pull like a steam train throughout the gears.
My only suggestion that I could make at the time.... as ridiculous as some of you may find it..... would be Dave's driving style so to say. He's only had the car 8 months and previous to his Octy was a Mondeo. Now before anyone thinks about jumping on this as an insult I'll clarify my point.
After I bought my Octy F/L Vrs I suffered from "New car syndrome" where paranoia sets in at ever squeak, bump, rattle and stall at a set of lights. At one point I was convinced my DMF was gubbed at 20k purely because the car shuddered at take off when it was cold...... Long story short a bit more revs and better clutch control saw that problem away. The point I'm making is that we as owners sometimes become convinced there is a problem purely because we read into things too much, and start to create links to others experiences.
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
