Please anyone local that could help me
furbyPD100
Recommended Posts
Hi people
My fabia has recently developed a knock from the front passenger side and for the life of me I can not find what it is, happens when you turn right or even just knocks for no reason when you go in a straight line, and tends to be more apparent with more weight in the car
recently changed the antiroll bar links and bottom ball joint and it's still there, my anti roll bar feels solid but I haven't taken both links off and tried it without to see if it's loose, had the car up on my mates mot ramp and shook it and he and I could not see a thing,
Please is there anyone local that would get in my car and listen to the noise to shed some light on this for me I'm I sidcup kent and don't mind a little drive
Cheers Chris
Edited by furbyPD100
Link to comment
Share on other sites
Hhhhmmm recently change the passenger side outer cv as well and the inner was perfect so can't see it being that, took both anti roll bar links off this evening and had a good pull of the anti roll bar and it's solid no movement left n right and nice n tight up n Down
Link to comment
Lower ball joint?
  • Like 1
Link to comment
I honestly thought It was the bottom ball joint, so changed it and nothing still knocking
And the cv I had to change as mine was stuck in my hub when I wheel bearing went so changed it and did the bottom ball joint at the same time and it made no difference lol starting to really do my head in lol
Starting to wonder if it shock knock? Or could top mount do this? But I've even gone to extremes lol and sat on my slam panel with my bonnet open while my cuz has drove my car in my yard to see if my top mounts are moving and nothing looked solid
Bits I've done so far are: arb links, bottom ball joint, outer cv, A arm front a Bushes, console poly bushes, I've checked arb bushes, track rod ends, and there fine
Link to comment
Ide say shock suspension issue escpecially if it's everywhere u go turnin straight over humps etc etc. For what it worth try swapping them round on the front then if faults coming from the left presto that's your issue if not at least it's ruled out
Link to comment
Hi people guess what found the f**king noise/knock,
got to work and parked my car on a slope sideway and as I got out I heard the knock and I opened my bonnet and bounced on one side of the car and it's my antiroll bar bush squeaking!!! but in the car I sounds like a knock, so I absolutely covered them in ptfe spray grease and ordered some new ones from euros, for the sake of £6 quid I might aswell change em but after me spraying grease on em instantly the noise has gone lol
Honestly cannot believe what it was lol
Thanks tho everyone
  • Like 1
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
