How much time do you warm-up your Felicia?
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanHere is the connection, the flap has an U shape and the rod a Π shape, it clicks and thus controls it. That air filter sensor is very sensitive, a little bit of rubbing by hand and immediately reacts. The crucial point is ''for how long"?
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanThe Mediterranean people when the joking do it obviously and in internet they add a LOL or an emoticon with smile. As @Pete_Ex-Wino said it's not a reliable item, as you can see below there is no ETKA number for this part, it's not something you can buy it separately. So if after a years or two the flap stay in the closed position blocking the cool air and allowing only the hot air HOW how will you find out? Let's say you are in a highway and the car start showing signs of poor performance, the last thing that will come to your mind is that flap. IF that air filter thermostat was reliable there would be no worry by me.
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanThe thermostat with the pin pushes the rod and opens the flap and when withdraws the flap goes back to normal position (which closes the cool air). Hot air->thermostat warm->pushes pin->rod goes front->opens the flap. Since has wax inside soon or later there will be a leak and the rod will not moved (front or back) and will stay in one position and ''game over''. The rod is something like this: In the end has a hook and it grabs the flap so it controls the movement (Front-back). I wonder if i make a simple flap with lighter plastic or with aluminum tape, the incoming cool air after (for example) 40 Km speed could be capable to push it back and close the Hot air hole? Let's say it can, then in city traffic when the flap is back the Hot air from the manifold can push it to open a little bit?
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanI live in 3rd floor, i can't do this at home. I wonder if i make this flap work as manually, the strength of the incoming air (from the front grille) would be capable to make it close? I mean at 40Km speed could make it go back and ''seal'' the hole of the hot air?
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanYes i saw that pin, is flat in one and and pointed at the other end. The Warm position must be blocked 100% ?
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanAfter 20 years the original air filter box is in my hands again, take a look of the mechanism. Upper entrance: hot air from the exhaust manifold Right entrance: fresh air from the grille The initial position is with the clapet closed which means the throttle gets air only from the upper entrance (hot air) and later the clapet will removed and the throttle will get fresh air from the right entrance. As you can see from my finger the spring is strong so how the clapet will open? The fresh air would have the capability to do this? The temperature of the hot air from the exhaust will make the mechanism to make the spring get shrink? And every time the car stops (no incoming air) the clapet will close and the throttle will get hot air? Is this good for the engine?
Pentosin CHF 7.1 alternative for Felicia? (G002000 mineral oil)
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanI don't remember if i mention it before but when i said to the mechanic to remove the reservoir and clean it with a spray and then use compressed air or a clean rag to clean it inside said immediately ''NO''. I was against of use of any chemical way, i asked why and he insisted that there is a possibility to remain something and this will make a chemical reaction with the Hydraulic Oil and soon or later i will have a problem with the seals. He preferred the ''flush with new oil" method.
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanI can find a new Skoda Original air filter box from a local parts shop so everything would be as the 1st day. It was a mistake from that i believed a guy then ''Hey, you have a ECU chip and free air filter so you don't need that system". Maybe the density of air plays some part, the oxygen is different, no fresh air down there.
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanI didn't said the car is colder in that case, i said that my worst cold start are in that occasion so except if something ''magic'' is happening then this situation must be the cause. Keep in mind that for 17 years the car was parked outside (not in a garage) in the road so after finishing my shift at night the 2nd cold start of the day was with the car cold (as in the morning/noon when i was starting from home). The last 4years allow me to park my car in the garage to the end of it which is 5 floors below earth, has many benefits and only one drawback that 3:45 minutes of waiting. So it's worth to reinstall that system as it was from the factory?
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanWhen the engine starts the exhaust manifold starts getting hot thus some quantity of warmer air from the hose is transferred to the air box, there must be a reason for this isn't it? I suspect that is to help the cold start that's why the clapet closes after a while. After 6-7 hours i don't know how much heat can remain in the engine bay. My best cold starts is when the car was outside in the road for all night and the worst are when the car is parked inside a building.
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanAbove the exhaust manifold there is a cover (yellow arrow) which has a socket where fits the hose which brings hot air inside the air filter box (green arrow) those first minutes. Is this hot air except the better emissions can make the cold start easier? I have removed that hose many years so i can not remember if the ''second" cold starts of 2000-2001 were with a delay of 3:45 as i have the latest years.
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanMy next task is to replace the ''clapet'' on the air filter box , below is the lower part VAG 6U0129607B When you start the car hot air (red arrow) comes from the exhaust manifold and when the temperature rises (if i remember correct at 30 'C) then the clapet opens and allow cool air (blue arrow) to come inside the box while closing the entrance of the hot air. According to theory those first minutes the hot air will make the starting process easier, the fuel-air ratio will be better etc. As a young driver (No internet back then) i follow the advise of a guy and remove it, i can't find it now so i had to buy a new air filter box or the lower part as Used. Few weeks back another Felician mention it, i can't remember if it was @Papez @J.R. @Pete_Ex-Wino
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanDue to Covid restrictions and 2 times Quarantine period there were no options except home-work-home. Few years back things weren't this way, i could go to a boulevard or make short trips to national roads that's why i was seeing better fuel consumption. I will try to go the highway and later i will make a detour to a quiet mountain road, so far the spark plus turn out to be an excellent choice!
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanUpdate: Today noon after finishing work i found a boulevard and finally manage to put the 3rd-4th gear even for few seconds, i reached the U turn and turn back again having the chance to put 3rd-4th gear again but for a little bit. Unfortunately the city traffic ''caught me'' and after one kilometre i returned home because i didn't had enough time. The TC-6 showed fuel consumption 10,68 ltr for that small trip which means: 1) My Trusty as is isn't for hard city traffic 2) the Air Intake Manifold cleaning, the correction on the thermostat Coolant Sensor and the new Iridium spark plugs were worth it. The new plug for the Coolant sensor is coming soon, i can't leave the old cables because after so many years are hardened and i don't trust them.
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanI use the car for house to work and work to house, steady hours same route and the road conditions are 95% the same. I know when the temperature will start rising, when it will reach the 91 'C when the fan will start spinning for 1st time etc and the weather all these days was the same except a light rain today. The 2nd cold start of the day is from the same spot 5 floors below earth almost the same time and i follow the same rout to exit, one road block, turn right, main road, here is the 1st traffic light etc. I began with 13,1 ltr fuel consumption and now i am on 11,02 (same road conditions) and when i pushed it few days back in the mountain (Champion spark plugs) i was in 10,8 ltr. The car is one click better when i start from the traffic light plus on the acceleration after change from 1st to 2nd gear in the alleys close to home. I want to find a boulevard with minimum traffic to push the car at higher rpm or one evening to go out to the national road to see the difference with the iridium spark plugs.
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanAs a matter of fact no one ever told me to change that part as "precautionary". They only thing that mention over decades here to pay attenrion for any signs of moisture (and do anything to prevent it) inside that plastic pipes. I measure the gap, was 0,33 inch which is 0.8382 cm so OK. The fuel consumption slowly degreases, now i am 11,02 ltr which brings a light smile in my face.
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanThese are my previous Champion, only for 3175 Km on use but the majority of them on slow city traffic.
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanSkoda Felicia has DIS Here is it on the engine bay The factory one is from Champion, it's ''plug and play'' with 2 allen screws and 1 clip.
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanI am moderately optimistic but i have not forgotten what happened with those Denso iridium many years back. I need at least a month with the new NGK ''on'' to feel reassured. My car is a little bit upgrated, those Champion were old technology and the city traffic was ''choking'' them. What worried me was that the engineer asked me if i had changed the Ignition Coil, i said no this is the factory and he told me sooner or later i will have an issue with one of the cylinders because of him. He said it's statistically sure that at least one (at the base of that plastic tube which here we call it ''Spark plug pipe'') will have a problem and the car will start tremble. Skoda 047905104 Yes mine it's 21 years on duty for about 84.800 km of use but is this true?
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanI change them today, first words of the mechanic "oh, these are good, now it revs better". Small test from me (house to work): Yes indeed especially when the traffic light goes green and i start plus the sound of the engine at low-medioum rpm (not enough road for high rpm moving). I kept the previous Champion, look good and i will post a photo ot them tomorrow.
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanI have put that chart with link before because i thought was better (no time to reduse the size on the smartphone). If things are far better in city traffic i will keep them, as for their high rpm attitude i don't dare to say anything, the test will begin very slow monitoring the fuel consumption-coolant temperature-acceleration feeling etc because i am afraid. If i had bought the BKR6 i would feel more assured but maybe the performance was the same with Champion so for what all the trouble? I am in agony....
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanPlus another one from Champion: https://www.championiridiumplugs.com/heat-range-conversion-chart-2 Today i notice these Heat range crossreference chart and i am thinking: I have Champion 89 (which in NGK was let's say 6,5) and now i bought the NGK BKR5 EIX11 which is (let's say) 1,5 scales Hotter, is it a significant difference? On the other hand if i had bought the BKR6EIX-11 the difference would be so small that i doubt if i could notice any difference in performance.
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanThe set of NGK IRIDIUM BKR5EIX-11 is in my hand, i check them one by one (not counterfeit), i measured the gap and it's 1,1mm so i feel reassured about these factors. In few days i will install them and let's pray that they work fine and not as those damned Denso did.
Rust beneath my crankshaft sensor, is it normal?
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanThat ''timing gap" or as i read it elsewhere ''missing teeth" or ''empty space" here in Greece the mechanics on their slang call it ''Eye" because the sensor 'sees it". I will use a tough paintbrush and a spray (not strong) to remove the light oxidation and i wipe it with a clean rag. Then i will put a new inox bolt with a washer.
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanLacking accurate timing information from the crankshaft position sensor, fuel injectors won't pump gas into the engine efficiently. The engine will use more gas than it needs on short and long drives, reducing overall fuel economy. Have a mechanic inspect the sensor — as insufficient fuel economy can occur from other issues as well. https://www.yourmechanic.com/article/symptoms-of-a-bad-or-failing-crankshaft-position-sensor The rust is fragile, the spot is from my finger because i touch it. The sensor has not a gasket so it's relative easy after 22 years for some drops of water to bypass the plastic housing especially from the left side.
