How much time do you warm-up your Felicia?
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanDue to Covid restrictions plus 2 times Quarantine the car works for 2,5 years worst than a taxi because even a taxi can travel in a boulevard for 4th gear for some time. I work mainly 1st-2nd and a little bit the 3rd gear only for few seconds and all these 2 years i had the chance to make a trip only one time and even when the coolant was wrong i had a very good fuel consumption. The last days i read articles about Hot and Cold spark plugs and i see video where mechanics suggest one level to the Hot spark plugs for car which work mainly on city traffic. As for the coolant sensors i have tested 3 totally and the effect was the same, the 2nd cold start lasts 3:40-3:45 minutes which is absolutely unacceptable.
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanAnother night cold-start test, the result? DISASTER! 3,45 minutes from the start and 1100 rpm till the needle drops to 800. I have it on video, tomorrow i will post some photos. So it's not the coolant sensor nor the cables and the fuel consumption was 11,96 ltr / 100 km. I have to find the guilty for this terrible situation and now i am focused on spark-plugs, maybe it's time for a change and let the good old RC89PYC platinum aside....
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanOrdered a new from Aliexpress, will take a month to come. The factory cables repaired, in few hours at night cold start will see if these were the "guilty".
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanTC-6 has one fuel sensor and another one on the rpm gauge. He uses the factory floater sensor. It reads rpm and the fuel that sprayed and then makes calculations. I can see the Instant fuel consumption, the Average, the Total, the Remaining kilometres. TC-6 is not a scanner tool,can not adjust anything or interfere to correct anytging, it's just reads and shows to you. The coolant sensors were based the VW specifications, no overhearing problems, also the thermostat works fine. The "guilty" is something that has the power to make the ECU to make the fuel mixture rich at low-middle rpm but to perform very good at higher rpm (mountain road, national road).
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanI returned from the electrician at 9:45, parked my car and 13:30 i start it to go to work and guess what? The needle was on 1100 rpm for few minutes before drops to 800 ( i was on the move, i didn't use the timer). The car was not cooled down, the 2nd cool start of the day is always like this, i have changed the coolant sensor yesterday with a spare that i had so it's not his fault. The fuel consumption now is 12,2 ltr/ 100 km which is unexeptable for this car.
A need the code for the Plug 4-Pin of coolant sensor
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda Forman@Pete_Ex-Wino : Thank you buddy! 🍺
Gentlemen, yesterday i have found that the plug of the coolant sensor had a problem, 2 cables were inclined, one had a spot were the copper was visible and the other one was a little bit loose. I want to change that 4 pin plug but the problem is that i don't know the code and some sell it with the coolant sensor but i already have 2 so i don't need another one. https://www.dhgate.com/product/for-vw-engine-water-coolant-temperature-sensor/523007034.html https://www.amazon.com/Connector-Water-Temperature-Sensor-Volkswagen/dp/B011AR52U4 http://www.autolumination.com/wiring-electrical-connectors/automotive-engine-chassis-sockets-wiring-connectors-harnesses-plugs/vw-seat-audi-357-919-501-coolant-fan-radiator-pigtail-connector.htm https://www.ebay.ie/itm/1x-Connector-4-way-for-Audi-Temperature-Sensor-A-C-357-919-501-A-/261942358352 https://www.ebay.com/itm/For-VW-Engine-Water-Coolant-Temperature-Sensor-Switch-357-919-501A-Plug-4-Pin-/133587324135?_ul=IL Does any one knows the code for this part?
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanI have exactly the same issue for months now, it's not last night. My night cold start (at the parking garage) is far more different that the morning/noon cold start. https://i.imgur.com/6liowjL.mp4 This was few months ago and nothing changed till today. I have made a repair to the 4 cables of the coolant sensor plug (2 were bending too much, one was a naked spot plus one was a little bit loose). I can not compromise with the idea that a 1300cc car burns in city the same fuel as a Mitsubishi Lancer Evolution VIII.
- Felicia 1.3 MPI spark knock
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanThere is no possibility a Felicia 1300cc that has a fuel consumption of 5.3-6.8 ltr/ 100 Km in national road and sport driving then burn in mild city driving 12-13 ltr/ 100 Km. It does not make sense for a car to want 3.5 minutes idle at 1100 rpm while 6 hours before it needs almost half a minute. These two are world phenomenon!
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanTill 100 Km on the odometer everything seems to go well but latter things start changing. My ''late" cold start is at night when i am leaving from work to home, the car is 5 floors below earth on a parking garage (of course the air is different than outside but the temperature is one click higher) and always is different than the cold start at morning or noon when the car is parked outside on the road (fresh air but sometimes lower temperature). So last night i have made a test, nothing else On (radio, heater etc), start the car with no revving and counting the time till the needle drops to 800 rpm which is the idle level and the temperature will rise. Here are the results, the engine went at 1100 rpm and when dropped to the idle the timer wrote: I don't think this is normal.
Air Intake Manifold cleaning (not removed from the engine)
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda Formanhttps://www.youtube.com/watch?v=PkUq5mp2plc&t=314s (Italian tune-up)
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanThe solution is to remove the Air Manifold and clean it thoroughly but i will not do it. I wonder if i spary a lot (from upper and lower position) let it soak and then start the car, i will see white smoke from the exhaust etc but this procedure won't affect even a little bit the spark plugs? After this ''petroleum storm'' will remain intact?
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanI bought from an e-store a feeler blade plus a coin gap tool, i want to measure the gap from my spark plugs so any suspicion will let go. Still waiting for the courier to come. At cold start in the morning or at noon the needle rises normally and stays a little bit at 1100 rpm returning to 800 rpm At night inside the parking lot refuses to let the 1100 rpm for few minutes and then returns to 800 rpm. Why at night only? I don't know and this makes me nervous.
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda Formanhttps://www.denso-am.co.uk/e-catalogue/ K16TT and K16PR-U are Nickel IK16TT is Iridium (which means NO WAY) No Copper spark plugs by Denso for me.
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanThen i will need a new gasket plus a reset from a VAG-Com plus at least 50Km route so the ECU will read the new data then again a visit to mechanic for another scanning. It's too much job for me. When the weather gets warmer i have the thought to spray from both sides (vacuum hoses) plus from a full open throttle inside the manifold and let it soak enough before i start the car (far away from house due to the white smoke).
If you do it by yourself yes a little bit with a lifting jack or other way, you need some space to reach the oil drain plug. Take the new oil filter, apply some oil on his gasket and then screw it ,put some oil from above and start the car for 4-5 seconds so it will soak some inside, then fill till the stick shows the level reached the Max (total will take about 4,3 till 4,5 litres)
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanYes but year after year, cleaning after cleaning something will have been remain at the bottom of the manifold? Doesn't restrict a little bit the flow of the air? And if all of that dirt (with the spray) is driven at the combustion chamber will be completely burned or can make things worst?
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanSkoda manual says Champion RC89PYC, the same is on Haynes manual that's why i hesitate to make any change (the NGK didn't work, some Iridium didn't work) but nor me or the mechanic measure the gap ever. Just plug and play and there is a rumour that those which have that protective cap are already been adjusted from the factory.
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanEvery time you open the throttle for cleaning you can see that some dirt is on the disk so after 22 years some kind of dirt wouldn't be inside that manifold?
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanIt's a risk that i can not take it by myself, i have to ask the programmer, i don't want to make experiments with sparks plugs. As for the change of brand it's a mess, here is an example from an Uk store: https://www.sparkplugs.co.uk/compatible-parts/spark-glow-ignition/spark-plug-100151?ktype=11193&vtype=P and as for cross-reference then it's a huge mess: https://www.sparkplug-crossreference.com/convert/CHAMP_PN/RC89PYC 😲
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanThe parts e-shops give those Champion as an option and to be honest i forgot to ask the programmer if i need a different type of spark plugs. I have the SKODA FELICIA II (6U1) 1.3 with AMH motor code. I still wonder.
https://www.ebay.it/itm/403354612195?hash=item5de9cef1e3:g:kHAAAOSwTWRhvDwL https://www.amazon.it/Sea-Foam-Motor-Tune-confezione/dp/B004NPUR38/ref=sr_1_1?__mk_it_IT=ÅMÅŽÕÑ&crid=3PZND70WZLSOR&keywords=Sea+Foam+motor+tune&qid=1644152194&sprefix=sea+foam+motor+tune%2Caps%2C204&sr=8-1 https://www.ebay.com/b/Sea-Foam-Automotive-Fuel-Additives-Treatments/179492/bn_7114964332 https://www.ebay.co.uk/p/15032166538 https://www.amazon.co.uk/s?k=sea+foam+motor+tune&i=automotive&crid=9SEKB2DRHNM1&sprefix=sea+foam+motor+tune%2Cautomotive%2C158&ref=nb_sb_noss https://www.amazon.co.uk/Motor-Treatment/dp/B00Y4TL95I/ref=sr_1_23?crid=9SEKB2DRHNM1&keywords=sea+foam+motor+tune&qid=1644152077&s=automotive&sprefix=sea+foam+motor+tune%2Cautomotive%2C158&sr=1-23 😉
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanSkoda gives the Champion RC89PYC as ''factory spark plugs" for Felicia. An NGK Copper never worked for me, i have a specific thread for those. https://www.briskoda.net/forums/topic/491830-ngk-bkur5et-10-your-opinion-about-them/ No LPG.
I had a major problem with those spark plugs, take look https://www.briskoda.net/forums/topic/491830-ngk-bkur5et-10-your-opinion-about-them/ The 1st and the 2nd method are for professionals, don't try it by yourself The look of your piston's head match to those which Chris Fix has uploaded for Seafoam use. As i read you have neglected your car too much in some sectors and i wonder how you manage to drive in such a bad situation.
