A need the code for the Plug 4-Pin of coolant sensor
Gentlemen, yesterday i have found that the plug of the coolant sensor had a problem, 2 cables were inclined, one had a spot were the copper was visible and the other one was a little bit loose.
I want to change that 4 pin plug but the problem is that i don't know the code and some sell it with the coolant sensor but i already have 2 so i don't need another one.
for-vw-engine-water-coolant-temperature-
https://www.dhgate.com/product/for-vw-engine-water-coolant-temperature-sensor/523007034.html
https://www.amazon.com/Connector-Water-Temperature-Sensor-Volkswagen/dp/B011AR52U4
http://www.autolumination.com/wiring-electrical-connectors/automotive-engine-chassis-sockets-wiring-connectors-harnesses-plugs/vw-seat-audi-357-919-501-coolant-fan-radiator-pigtail-connector.htm
https://www.ebay.ie/itm/1x-Connector-4-way-for-Audi-Temperature-Sensor-A-C-357-919-501-A-/261942358352
https://www.ebay.com/itm/For-VW-Engine-Water-Coolant-Temperature-Sensor-Switch-357-919-501A-Plug-4-Pin-/133587324135?_ul=IL
Does any one knows the code for this part?
@Pete_Ex-Wino : Thank you buddy! 🍺
