D.FYLAKTOS
  1. But you hold this specific hose in your hands in the video. Here in Greece we call those pipes as ''paper pipes'', an example Here Usually for air-induction kits, as you saw in the links i use it in a different way than the factory to bring more cool air inside my air-filter box.
  2. 6:08 Happened to me also in one side by a sloppy mechanic 22:14 I have removed the whole thing due to dirt-moisture,you can save some weight this way 23:21 You can make a cleaning with a/c spray.In the past i asked for a thoroughly evaporator-blower cleaning from a a/c specialist (he removed the cover) 23:51 You can find info about this in my attachments,was bringing hot air from the intake cover inside the air filter box to help the engine at cold starts in Winter. https://www.briskoda.net/forums/topic/499328-how-much-time-do-you-warm-up-your-felicia/page/19/#findComment-5638614 https://www.briskoda.net/forums/topic/499328-how-much-time-do-you-warm-up-your-felicia/page/18/ Now i use that hose for different purpose: https://www.briskoda.net/forums/topic/477677-skoda-felica-13-what-kind-of-air-filter-do-you-use/
  3. The links were to search the matter deeper. You already have the parts code to look in e-shops even for used parts,best of luck. 😉
  4. You lost that white teflon look Worm gear (cochlear atermonas) ? A mechanic may ''grab'' it with a special tool otherwise it will be shattered in pieces inside the gear box. Briskoda.net search 002409191B 002409191E Cost about 9 euro or 7,7 GBP
  5. Radiator Cover 6U0121283J ,differs from Radiator Support https://www.skoda-parts.com/spare-part/6u0121283j-radiator-cover-1-3mpi-china-3089.html https://www.naskodovku.cz/kryt-vodniho-chladice-vedeni-vzduchu-pro-skoda-felicia-facelift-6u0121283j--6u0-121-283-j/ @keywacat It's a very crucial part,it ''drives'' the incoming air on the radiator otherwise the incoming air will lost some amount inside the engine bay with no benefits.
  6. I use a spray cleaner,not a thoroughly job but i didn't had much time at the moment. I will make a check after few months.
  7. To be honest i didn't paid attention the first days but now seems there is no ''sping effect'' on the driver's lock. It works for both functions but there is no return in the vertican position as the passenger's door does. I don't know if it's a mechanic's error or not,deep inside me i want to swap lockers but this means money and time.
  8. I have 14" (factory were 13") wheels so dont know what options i have...
  9. From n RTL documentary about safety (crash) tests in a Felicia. Even with air-bag the passenger's head hits the windshield ! 😯
  10. Unfortunately, as we say here in Greece, "the joy didn't last long". I was in a provincial town with very narrow streets, in the middle of an intersection and I had to move backwards to make way for another car. I was in a hurry, it was a hot day,i didn't pay attention (because I thought I had enough space) and the damage was done. 😲 I scratched the rear bumper, the rear left wing and I also broke the brand new taillight. Today I went and got a new one HELLA and took the car to the body shop for painting.
  11. Update: I went before two weeks my Trusty in a car-body shop for these: https://www.briskoda.net/forums/uploads/monthly_2025_03/-.jpg.08c7608f834b9ca2c9c7fd3ebb06c0f7.jpg https://www.briskoda.net/forums/uploads/monthly_2025_03/IMG_20250319_074130.jpg.f32b896e5220d8d3d2dbead9be2a9cc2.jpg https://www.briskoda.net/forums/uploads/monthly_2025_09/NX-(1).jpg.3d8c48c115c2a1140e8ea10d94d2c892.jpg and this: A rubber (round shape) stopper covers the hole for the rear windscreen wiper. All fixed, the whole work was not perfect, just good but was in a very affordable price and took 3 days only.
  12. Which model? Parts code? I want to upgrade my brakes and they say this is the only way, i have 14" wheels and EBC Yellow staff braking pads and Brembo discs.
  13. https://kritosparts.gr/Part/KOLARO-TROMPAS-NEROU-ME-A-C-FELICIA-11211827101/e92511211827101 I don't know how but the new one isn't so close to the A/C hose as the previous, no touch no friction. As for the G12 plus (purple) coolant temperature according to the factory gauge, vacation trip 2 persons and the car full of luggages, hot summer external temperature in National Highway and Mountain Roads (normal driving) the needle reached this point 2-3 times (the photo is old) With G12 (red) was one click less,i don't know if it was better or not this way.
  14. Mine (I have an old car, Felicia) was stuck in the Off position after few tries while hearing a ''crack-crack-crack'' noise and I had it like that for years because my mechanic said it couldn't be fixed and of course there wasn't a new one in the market. I looked for used ones but the prices were very high. One day, disappointed, I told my story to an auto electrician from Moldova and he said he cold ''give a try''. He disassembled it, serviced it and called me "come on, it's ready to work!" I was surprised, I simply reassembled it but I made the mistake of putting a lubricant spray between the 2 gears, after a few attempts one gear "bounced" and didn't grip well on the other. Frustrated, I opened the side cover, cleaned the gears very well so that they were free of grease and I put a little bit of a spray that they use on serpantine belts when they make noise. This created a slightly "sticky" situation and now one gear grips well on the other, I've had it like this and it's been working (summer use mainly) great for about 6-7 years.
  15. According to the ETKA https://nemigaparts.com/cat_spares/etka/skoda/fel/101/121000/ Which is this coolant hose, the No21 (6U0 121 038 and 6U0 121 051 F) or the No29 (115 691 976 and 6U0 819 371 D) ? The No22 has two other ends.
  16. Thank you @Former The gaskets are the original. I show this to the mechanic-check it and said ''No leaks", it's normal dirt (maybe not perfect cleaning job from older valve adjustment,fumes from engine etc) so in few days i will clean the whole area with degreaser spray them a wet cloth cleaning and check it after few weeks to see if there is any signs of dirt in the area. In the next valve clearence task i will buy a new gasket for the valve cover because now it's the stock (26 years old).
  17. Here is the patch,as a final thought not a good idea and i won't do it again Here is the HEPU G12 plus https://www.trodo.com/antifreeze-hepu-p999-g12plus-005 https://www.old.ac-93.com/files/HEPU%20P999-G12%20MSDS%20e.pdf As for the record: Brake fluid 19 € ,coolant hose 25 €, antifreeze 15 € labour for the change plus air bubbles remover procedure and labour for the coolant change plus pressure test and air bubbles removing 40 €, check for the steering wheel-CV boots-wheel bearings-oil leaks etc Free (no charge) so i paid total 99 € or 85 £. What's next? An MPG test with the G12 plus plus monitoring the coolant temperature via console gauge in Highway-Mountain roads because the Summer vacations are approaching and yes i still wondering about the coolant hose brand...
  18. Looks like the 6U0819371D that @Former posted here: https://www.briskoda.net/forums/topic/538952-skoda-felicia-pipes/ but in the end is different (yellow arrow) here as it is now on the car: The stock was one click close to an a/c hose that's why i had a layer of heat insulation patch on it. I don't see any marks on the coolant hose,even VIKA has and i wonder if it's indeed new or a used one in very good condition. 🤨
  19. The problems continued,while preparing my car for Summer vacations i asked from my 2nd mechanic a brake fluid change and a thoroughly check ''below'' (steering wheel-CV boots-wheel bearing etc). The 2nd mechanic is in some points better that the 1st one but has two drawbacks, 1st even when finishes the job does not call you immediately to pick it up but the next day's morning and some times changes parts which thinks that will cause you problems without call you first. Does good job,clean,not sloppy but... I left the car early in the morning with the idea that i will take it next day,at noon i saw it parked outside the repair-shop,entered asked him "everything OK i changed a hose plus the coolant". I was surprised because he didn't informed me first (e.g i could have a spare coolant hose and a plastic can of my preferable coolant mixture) and then showed my the coolant hose and the coolant,he put G12 plus although i had G12 (i didn't liked the G12+ from previous test). 😡 At least he used the same brand that i like, the HEPU. Here is the original coolant hose, 26 years old.
  20. After lot of effort the old guy came out and the new came in. The old was from 9 of 2020 so lasted 5 years and 9 months, i could charge it one more time and last exactly 6 years but since the Summer vacations are approaching i didn't want to risk it. I had the chance to save ''some battery'' at Winters while i am on work but from the other hand at Summers the car was outside many days with alarm On without to use it (due to heat and traffic i used a small motorcycle to go to work). A realistic life limit for this battery i think is 4,5 years.
  21. I found a photo from mine few months ago. Many years back i installed a cheap led bulb for Reverse (nothing special) and later a Led bulb for turn signal, that's it's very bright !
  22. No need to open a new thread for this reason that's why i will post here no matter in the existing is very old. CarCareKioskBattery Replacement: 1997 Skoda Felicia LXi 1.3L 4 Cyl. https://d2n97g4vasjwsk.cloudfront.net/1997%20Skoda%20Felicia%20LXi%201.3L%204%20Cyl.%2FBattery%20Replace.mp4 Things are easy when there is no alarm unit and not strut brace, if those 2 exist then it's a nightmare. I face the same situation every time a change the battery, the strut brace makes me to bent the battery end pull it out forcing a bit the black plastic cover of the wind shield wipers (red arrow). Another 2 issues are: 1) The battery is not very stable and has some mm tolerance of moving that's why i put a piece of adhesive hard felt for furniture (yellow arrow) long as the battery and in the spot that the battery ''sits'' on it's place and then i tighten the bolts. Then the bracket holds the battery more steady. 2) After so many screw-unscrew efforts the thread starts showing signs of wear (blue arrow) so in the next time i had to make a small repair on this.
  23. OK, "case closed" otherwise the @somean49 thread will ruined.
