Felicia with Heat Shield in the Intake Manifold
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanHere is today with the metal zip ties or Stainless Steel Cable Ties. Except the air condition hose (older heat sleeve modification) i put in the throttle sensor cables and a small part in the vacuum hose-fuel line. I bought a digital thermometer and this is the first test with the aluminium tape that i had. The difference is 3 'C only but keep in mind that the car has left after a ride about 4 hours parked in the road, the measurements are not when i just finished the ride so are not final. Now that the Heat Shield-Sleeve procedure finished i will take some measurements immediately when i finish the trip so the results would be more valid.
Locked out of Felicia - Help!
Don't break anything, there are easiest ways. Car unlock when you have lost your key.
Felicia Gearbox oil level?
If there is a big leak those additives are not going to save you. They supposed keep the O rings-gaskets-bushings etc soft so they seal as they should be so no leaks. Don't relay on them, in the past some use them to "patch things" so they will sell the car to the next byer as "used but with no problems".
Thermostat Housing - 1.6
D.FYLAKTOS replied to TrentBarton's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanYou have to remove yours to see the shape-code on it,type etc and then to buy the same.
D.FYLAKTOS replied to TrentBarton's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda Forman032121110B must be your part code. In the end before the trip remove any possible air bubbles and make a pressure test to see if there are any possible leaks.
D.FYLAKTOS replied to TrentBarton's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanProfited is better than buy it separately. The ring on the thermostat sensor in your car was yellow or blue? A brand one (with the same colour ring) is much better than a no name or VIKA. The differences are in the 'C range, always i had problem with the yellow ones.
D.FYLAKTOS replied to TrentBarton's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanSome examples: https://www.skoda-parts.com/spare-part/032121111d-thermostat-housing-1-6mpi-china-23867.html https://kritosparts.gr/Part/THERMOSTATIS-VERNET-62741287J/e21562741287J I have the 1.3 but i have learned that it's better to buy it with housing (gasket included) and not separately. As for the ring (yellow or blue) mine works betetr with the blue. Change the coolant too, now it's an A' class chance.
Engine cover, do we really need it?
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanHere is how they solve the problem. Warm air intake? https://www.grcorollaforum.com/threads/warm-air-intake.1479/ So even in modern cars an small modification can do the difference. Same here too?
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanHere is what i found today, Toyota GR Corolla Ownership | Good and Bad Times Ahead. At 16:50 till 18:02 says for bad factory design that sucks hot air, see? the engineers are not ''perfect" guys and always there is room for improvement.
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanHere is the first part of the Heat Shield and i add another onein front area only. Here is as the engine bay looks now, the metal tie wraps arrived and i will install them in few days.
https://youtu.be/3z11DfAZwWs?si=ZuM9rUoyAo1WygXv
My Felicia has a broken windshield wiper
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanI don't trust any more anything from that VIKA motor, not even a washer. Both motors are recycled now.
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanDo you remember what H.Ford said (at 1963) before Le Man 1966 race?
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanI already have done 4 tests and i will do another one before my summer vacation trip. I have seen (and i expect) positive results but in winter i will have a complete image.
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanThe thread is almost completely damaged.
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanHere is the video from that modification. Take a look at 0:53 the Anemometer which installed to take measures.
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanWhere the green is i put the Heat Sleeve, unfortunately the 2 spots with threads (yellow) restrict me so i had to put 2 ''stripes'' for each side and not one piece. In the back side i use wire (red) but this temporary till i find another way. I didn't had metal tie wraps that time but i ordered for future installation. As for the endurance of the aluminium heat tape here is a sample that i had at least for 2,5 years in the intake manifold just for test. By accident can be seen in a photo with the gear oil leak that i had, it was in the back of the intake in purpose to get the most of the heat from the exhaust manifold. 2,5 years and never moved, was still sticky when i try to remove it by hand, very durable.
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanI am not so sure that the underpressure from the throttle could pull inside drops of water (which must pass the gauze filter).
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda Formanhttps://thermalcontrolproducts.com/products/aluminized-fiberglass The temperatures are not so hi, no need for something extreme.
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda Forman047253041A is the part code, it's for exhaust manifold and not for air intake. I had it abut 20+ years ago, was lost when i wrapped my exhaust headers.
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanThere must be a drain hole inside the air filter box, mine has but for sure it's not enough if the front of the car dives into water (big pothole or stagnant water).
And if comes out while you driving what's going to happen? Gear oil all around. No way ! Let it soak for a day and then very gently knock it a bit with the rubber hammer.
