eribaMotters
Everything posted by eribaMotters
  1. Whilst silicon and talk will both work, talk would be the best route. Silicon can leave a sticky residue that would attract dirt. Dry lubricants are always preferable at times like this. The classic situation is a door lock where you slide the key in. These respond best to foliac [graphite powder] or a ptfe spray. If you squirted silicon or an oil, even WD40 in dirt would eventually stick and the situation could be worse. Colin
  2. How old is your Yetii and has it had the fix? It should have a sticker in the boot if the fix has been carried out and may still be covered. A Skoda main dealer should be able to look this up over the phone. Colin
  3. Back to your original question. I sold my 2014 110bhp 2.0L diesel Yeti in March 2019. It had done done37K. It had been "fixed" and I saw a slight difference as a result. Higher revs to get the same performance, no real difference in mpg and initially slightly more frequent regens, As the engine learnt I don't think there was much difference. I had one false alarm with dash warning lights about a 18 months prior to sale. At 4 years old I had zinc inclusions done on the front doors under warranty without any problem. I swapped to the 1.5 petrol in an Audi A3. I've had no issues. The engine is very flexible and willing. Fuel consumption is similar to the diesel Yeti. in fact I have seen near 70mpg on a brim to brim tank filling. Yes the A3 does not have the aerodynamics of brick like the Yeti but I was not prepared for the results. I loved my Yeti but I have to admit in hindsight it now seems primitive to more modern vehicles such as the Karoq. Colin
  4. The above can be read several ways. If referring to a remap of the 110bhp to 180-185bhp then this would be inadvisable. I had a 110bhp and it had the 5 speed box. This will not cope well with the far higher torque levels that come with the extra bhp. Colin
  5. The best I managed was when coming back from France with the caravan. In the boot I had table top fridge, table top freezer, 2 clothes maidens and odd bits. In place of the rear seats, down into the footwells and up to shoulder height were two camping tables, three stacker boxes, 36 kg awning and the vast majority of the 3L wine boxes in the photo. You will note the back of the Yeti was a bit low if you look at the distance between top of tyre and wheel arch. Colin
  6. I was in a Kia Ceed yesterday. The neighbour has owned it for a year having stepped down from a 2L diesel to this 1L petrol. I was very surprised. Fit and finish are good although some plastics as in every vehicle now a bit hard. Nice seats, comfortable, lots of toys, boot about same as Yeti. Foe a 1L petrol I was amazed at how refined and willing the engine was. The 1.4L would be worth a look if you are not after 4wd. Colin
  7. When I used to run winter steel wheels I looked for decent aftermarket wheeltrims and they all looked cheap and nasty. I bit the bullet and bought genuine and expensive Skoda. I do not regret it. You may find a friendly dealer on e-bay. I also replaced my locking wheelbolts. It is a very good idea. Try these:- https://www.eurocarparts.com/wheel-bolts Local Skoda garage managed to fit original locking so tightly that when I tried to swap wheels over I could not get them off. I had to go elsewhere to get them removed. Colin
  8. I miss my heated screen, mostly for the ability it had to de-fog the windscreen as this was a far more common need than for frost in my case . But remember a petrol engine does heat up a lot quicker so a petrol without heated screen clears a lot faster than a diesel without heated screen. The element was visible at times in certain lighting conditions, but never a distraction. If I was ordering a new car now it would be the first available option I would tick. Colin
  9. Would a Fixed Tow Snap Shackle give more clearance. https://www.amazon.co.uk/stainless-Stainless-Shackle-corrosion-resistant/dp/B08D8ZGT3B Colin
  10. I would not worry about crash damage. If you are going to hit something that hard that the bike wants to move around you'll already have done major damage to the car. Also in design and manufacture the carrier will have met strict regulations and testing. As regard van weight, current van shown was 830kg empty when new with max load of 1200kg. I usually run at about 1150kg when away for a 4-6 week European trip and typically 60kg noseweight. This gives a very stable tow. The great surprise to me is how well my petrol A3 Yeti replacement tows. It has more go, a bigger boot and still returns up to 40mpg. If I'd not had the 110bhp tune of diesel I probably would still have had the Yeti.
  11. StickMicky, I shared your scepticism about the security of the clamp on towball type carrier until recently. I fitted a towball onto the drawbar jockey wheel mount of my caravan so I could use one of the cheaper Thule Express carriers to transport a bike on the front of the caravan. I used bracing bars from this to the front of the van handles and tried it out on a run from Liverpool to Conway earlier in the summer. It became obvious the bars offered nothing apart from my initial perceived piece of mind. Over August/September I did a 900 mile trip without the braces and confirmed my earlier observation that the extra bars were not needed. The clamp on towball type carrier are an excellent bit of kit. This shows fitment on previous van. Colin
  12. They do differ, this is from my 2014 brochure:- 2.0 TDI CR 140PS 4x4 DPF 152 G 2.0 TDI CR 140PS 4x4 DSG DPF 164 G 2.0 TDI CR 170PS 4x4 DPF 149 F 2.0 TDI CR 170PS 4x4 DSG DPF 164 G Colin
  13. The circular metal clip is for removing the rear light cluster so you can change a bulb. Check in the owners manual and all should be clear. Colin
  14. Broken springs are not uncommon. Prior to Yeti ownership I had two go on my VW Touran which has the same floorpan. A friend at the time who was an Audi service manager replaced them for me, telling me VAG had several thousand in stock. As regards the cambelt, go to a good independent and get it done, along with the water pump. It is not worth the risk of it failing. Colin
  15. I owned my Yeti for nearly five years. I learnt about the Hatchbag towards the end and looked out for a discount one on there website, but no luck. When I bought my Audi A3 in March last year I managed to get one. They are excellent and wouldn't waste my time trying to find anything else. I managed to trim my reverse sided carpet/rubber boot mat to fit on top of it as boot floor obviously nearly identical. Colin
  16. Sorry, I have to disagree. I have towed in France each summer since 1999, doing up to 3,000 miles some years. I've found open roads, less congestion and more tolerant drivers. I'm guessing the later is because they see the GB plate and a caravan and give me a bit of space. The first time I ventured over with the Yeti was a near 600 mile trip in one go. Every couple of hours I could pull over at an aire, stretch my legs, go the loo and have a drink. You cannot do that in the UK. What an absolute joy. Colin
