Gabbo
Everything posted by Gabbo
  1. I've got a Bosch C3 charger which has an AGM regeneration mode. It seems to work pretty well as a few hours charging gives good starting performance the next day. Unfortunately as you state, the damage was already done letting the battery get to zero & leaving it too long. However, the charger has kept me going without any problems for 18 months & with regular driving everything is fine. I just put it on charge occaisonally if I've not used it for a week. https://www.amazon.co.uk/Bosch-intelligent-automatic-motorcycles-commercial/dp/B09C925GNQ My StopStart has not really worked for 18months with the current battery even during summer when I have no problems starting & no need for charging. I am driving around 130km (80miles) per day, 4 days a week, so when I using the car, it is warm & has plenty of time to recharge so seems clear the battery is past its best. In the winter when I start the car, the dashboard has many warnings during the first few seconds after starting (ACC Not Available, ABS Error (sometimes), Instrument Cluster resets) so Id expect there were be several DTCs stored for low battery voltage conditions. However, the car has been to the dealer for service twice in this time (they've checked the battery & told me everything is fine) so either they are not checking or they just assume every car has these & clear them. Its due another service in January 2023, so I will replace the battery tomorrow, leave it to see how long it takes for StopStart to work again & see if they mention it when its serviced. Gabbo
  2. I've got an old 2014 Octavia with Columbus MIB2. Recently, I've noticed an intermittent sort of white/noise interference when playing music from a digital source MP3 or Bluetooth (kind of like you used to get when listening to analog radio with a weak signal) It doesn't happen all the time & initially I thought it was perhaps some badly ripped mp3s but it also does this sometimes when the music is muted. It only seems to appear for a short time & then will disappear (so I'm assuming its hardware related, dry solder or warming up kind of problem with the Columbus). It doesn't seem to be getting any worse (its been like this for the last 6 months or so). Anyone had something similar & any possible root causes I could look into?
  3. I know the damage was done to my car during the summer of 2021, working from home & within walking distance to the schools meant long periods of time without use & proper driving to keep the battery charged. 6-9 months of short & infrequent journeys. (also pretty bad on the brake discs as well) When the winter hit, the battery performance had quite obviously deteriorated & I eventually bought a Bosch AGM charger to top up the battery the weeks I wasnt using it. Basically I've got to the point that in the winter (~0° overnight here currently) it needs charging (or keeping warmer in the garage) if its left for more than 3 or 4 days without proper driving otherwise it wont start (or will just start). Im back to driving ~80miles a day but even this is not enough with the current battery to enable StopStart anymore... After getting stuck at a filling station yesterday as the battery couldnt even start a warm engine I eventually decided to bite the bullet & buy a new battery.
  4. As a completely unscientific test, I will change my battery next week when it arrives & I'll keep an eye on how long it takes StopStart to work again. After charging my current battery with an AGM charger it took quite a long time even during the summer before StopStart was active again but this is perhaps because of the state of the old battery. Sitting on the driveway for months on end during the last 2 years weren't kind on it....
  5. There are ~10CHf cheaper directly from Swissbatt.ch if you have a creditcard or postfinance card. Varta N60 Blue Dynamic EFB 560 500 064 Autobatterie 60Ah | swissbatt24.ch I used Galaxus as I already have an account & can pay by invoice/twint. They sell almost everything, they are the Swiss equivelant of Amazon (with much better website) & have expanded recently to Germany & Austria.
  6. I found this thread look for a replacement battery for my Octavia VRS 2L diesel as the winter draws in as its not very good at holding charge if left for a few days. @Giff I am also in Switzerland but my car is fitted with 68Ah AGM battery. Seems like 68Ah is replaced by 70Ah as a standard now. I recommend Galaxus.ch to buy from. Very fast delivery & amazon quality customer service (available in English, German, French & Italian). Payment by invoice, twint, creditcard, postfinance etc. They have an AGM battery for 153CHF (from 3rd party swissbatt24) Varta Silver Dynamic AGM E39 (12 V, 70 Ah, 760 A) - kaufen bei Galaxus There is a filter on their website for Car Batteries where you can choose EFB type batteries: Fahrzeugbatterie · Autobatterie - kaufen bei Galaxus 60Ah Varta N60 Blue Dynamic (12 V, 60 Ah, 640 A) - kaufen bei Galaxus 110CHF 70Ah Varta N70 Blue Dynamic (12 V, 70 Ah, 760 A) - kaufen bei Galaxus 140CHF I have just ordered the Silver Dynamic for mine (AGM->AGM replacement). The garage wanted ~400CHF to change the battery & Im sure it would be a lesser brand than you can buy yourself..!!! Gabbo
  7. I would just run the car as it is until your new one turns up. When mine failed it occurred once or twice & then started more frequently but every time it was a temporary overheating warning & within 30s of cruising the thermostat would pop open & then temperature would go back down for the rest of the journey. They diagnosed the known component fault but I had to wait around 2-3 weeks for the part to arrive so I drove like this for 3-4 months in total. If you get a goodwill payment from the dealer (not sure if Skoda are still offering this) they'll pay around half but its still more than a few hundred quid in repairs. The temperature is just below the red line, as coolant can still flow past the thermostat when its closed, so as long as it doesnt go into the red section it should be fine until your new car arrives.
