Everything posted by Gabbo
Repeated daily Infotainment update issues
The first step is to get the 0334 update for the infotainment which then allows the other applications to update successfully... You can wait for the OTA to be offered with you but it seems this can take a long time and there's no way to force it. You can ask the dealer to start the update for you but it's probably not free unless your car is still in warranty. Or you can follow the instructions from PeterTr above to do the update manually yourself. Gabbo
Exhaust warning light
These are the 2 codes which are causing the engine light & what you should concentrate on: P06DA00 Engine Oil Pressure Control Circuit/Open static P064C00 Glow Plug Control Module static Checking the battery is cheap and simple but usually you have lots of other warnings & messages on the display with a bad battery (ACC, park assist, Tyre monitor, etc not available after starting). Next I'd check the fuses for both modules (or perhaps they have a shared fuse) to make sure it's not just one of them blown. Otherwise I'd suspect something electrical as they are not really related. When you charge the car at home, do you connect the ground off the charger to the charging point behind the battery (not into the terminal of the battery) ? Gabbo
- Exhaust warning light
If you have OBD11 you need to figure out how to use it and read the DTCs... It says there are 6 control modules with faults which means there are at least 6 Pcodes available. It's pointless guessing what the fault might by based on an icon in an app. The engine light can be related to lots of different faults from sensors to actuators, battery to communication. Gabbo
This thread has contains a nice guide from one user for how to do it and where you can download the FW files from... From memory there was another dedicated thread to this update but I can't seem to find it. The most important is to know the firmware you have and how many steps you need to get to the latest one. You also need a tool like OB11 or VCDS which can send the confirmation code after the firmware update... If I understand correctly, this last part is not mandatory but it will remove a permanent fault from the infotainment unit about the update.
My colleague had the update done at the dealers but his car is still under warrenty. As this is clearly a SW bug perhaps they would at least start the update for older cars?? Gabbo
There was a page somewhere on the forum where you could download the flash files for the infotainment (3rd party so comes with some risk) and instructions for how to do it. Does anyone know if this can be used for the Superb infotainment too?
If you can get the daily updates for the applications then I don't see why you wouldn't get the OTA infotainment update too.... It was released quite a long time ago so I assume that the roll out is slow. I'm not sure if there's a way to force it...
Yes the OTA update 0334 for the infotainment seems to fix the issue... If you have the "connect services" subscription then you should receive it automatically. If not, you can ask the dealer to do it, because of the daily updates they may accept as it's really a "Bugfix". Otherwise there is a manual way to update the firmware cus USB I think. There are some links on the forum somewhere. Gabbo
1.6 TDi Greenline glow plug replacement
This is my original thread. There are some pictures but not of the extraction but some helpful videos and general discussion... https://www.briskoda.net/forums/topic/528615-spare-parts-where-to-buy-from
I've changed 2 glow plugs on my Octavia 2L TDi in the last year. I have a bike torque wrench which goes up to 20Nm. The maximum removal torque is around 25Nm/30Nm depending on the manufacturer. Tightening torque was 12-15Nm which is basically nothing. Both glow plugs came out easily with just a little bit over 20Nm. I sprayed them with WD-40 the night before, drove it during the day and the replaced the glow plug a few hours after I came home. The electrical connector is easy to remove if you have the access to grip the plastic body lightly and pull up. In the Octavia forum there was a very helpful technician who said that, most problems removing the plugs occur when they have been changed by someone before who has overtightened them. From the factory they usually come out easily. He recommended not to overtighten when you refit them. There are some videos on YouTube that even say to only hand tighten them. I chose to tighten to the minimum and haven't had problems since. I used ceramic grease on mine, but I was surprised that, apart from the heating tip, the rest of the glow plug was pretty clean for 225k km and 12 years use. My advise, is don't worry too much, be gentle and slow applying pressure & if in doubt, stop. Spray some more and try again, leaving it to the next day if necessary. Gabbo
Sorry I meant the infotainment update 0334 Gabbo
My colleague was asked to bring his car in to have the update after he complained about the daily shop updates. If your car is still in warranty this seems like the quickest solution... Is the 323 update available for download and manual installation somewhere? Gabbo
On mine, after the update, the shop application is in a different tile position: top-row far right. Previously it was bottom row far right... After a week, I have had no further updates so it seems 0334 was the enabler to solving the issue for me. Gabbo
Do you have any notifications (number in a circle) in the to right of the infotainment? After the big 0334 update, I had 7 unique updates for different features including the shop application
Dashboard warning lights
There are some pictures on the Octavia MK3 forum from when I changed my left rear abs sensor. It's an easy enough job just a bit fiddly to remove the sensor and electrical connector. In the thread I also show how to diagnose a faulty sensor using Car scanner or equivalent OBD dongle to monitor the individual wheel speed sensors...
I've not been offered any new updates since my last post so fingers crossed it is finished now
This afternoon I had 7 updates, all for different things like 'background digital services", "application updater" etc Shop was also updated to a new version 338.322... So it does seem that 0334 is an enabler to release the next round of updates. Let's see in a few days, hopefully the constant updates will stop. I had a reply back from my dealer and he confirmed that the new 0334 OTA update would fix the problem. Gabbo
I have the new 0334 update installed 2 days ago & this morning I had another popup for "application updates".... I clicked ok so let's see if it comes back again or if it is really fixed now. I'm not convinced it is really resolved by 0334 infotainment update...
Online Logbook - How to access?
Yes that's correct. 3 different garages but all official Skoda/VAG dealerships in Switzerland... I think I'm going to write to Skoda Switzerland directly... Drop a bit of heat on the dealership at the same time. Gabbo
I'm in the process of selling my 2014 Octavia and would like to access the online logbook of the car... (This online version replaced the book with dealer stamps in it) I contacted my current Skoda garage and they sent me only the last 4 years of service/warranty information & said that that was all the information they had. I've used 3 different Skoda garages in the lifetime if the car. I cannot add the add the Octavia to the My Skoda app because it says it's not supported by the app. How can I get a list of all the work performed on the car? Services I have the invoices, however, I've had several warranty/free work done where they didn't provide any paperwork because Skoda paid for the work? ( TIBs - xenon ballasts, door rubber seals, air bags, water pump) Shouldn't an approved Skoda dealer be able to give me the full history despite using different garages in the past or do I need to request this from Skoda directly? Gabbo
The update didn't trigger immediately when you start the car. You need to come to a stop for some seconds (like at a traffic light) and probably the previous days I didn't need to stop on my journey to work...
I spoke too soon...... 😪 This morning I had another update & it put the same version of the shop application....
Open the shop application from the main menu. Wait for it to load & then click the settings icon (bottom right). At the last screen click information... It displays the shop application version
A couple of days ago, I had a new update for the Shop application. This new update seems to have changed the version number and since then I've not had any new requests for "application updates" so far.... The new shop application version is: 3.15.1-336.321 Previously I had the update repeatedly for: 3.15.1-334.320 Fingers crossed this is the update that fixes this issue.... Gabbo
