Everything posted by Colin170CR
Supply & fit new Water Pump & Thermostat assembly = £734.26 And that was at a VAG independent / specialist in M.Keynes. At the same time I had a interim service = £130 & Supply & fit new rear disks & pads = £190. Sub Total = £1,054.26 +Vat = £210.85 Total = £1,265.11p - 😖
Not sure but I had mine replaced earlier this year (55k) due to a small leak - same year as yours. Not cheap.
I got mine powder coated here (Milton Keynes). Choice of colours & customisation options. Mine were repaired, black powder coated, balanced with new valves for £67/wheel excl Vat. Cash is King.😉 They also put on two new tyres which I left in the boot & disposed of old ones. No extra for leaving car with them. 2-3 day turn around. They are very busy so 7-10 day lead in time is normal. I gather most of the local car dealerships use them.
I feel your pain & apprehension. After refurbing a couple of my diamond cut alloys after my wife managed to curb them, I decided to get them power coated instead (same cost). I now have gloss black Trinity wheels to go with the Black Magic bodywork. Well, they would be gloss if they were not currently covered in brake dust & road grim which makes them look matt black. I call that a result because they don't look obviously dirty like a silver alloy would. No excuse really the car does need a clean but can't quite bring myself to do it when I know that within a day it will be dirty again.
Out of interest what LED bulb did you use as a replacement?
Always good to see symmetrical pipes. Are you with or without exhaust Flaps? Is the 280 badged as a VRS in Aus?
Wish mine was looking like that. Not worth cleaning it now that winter has set in & there's a building site down the road from me which is dragging mud onto the roads. I drove past it the other day & now my car now looks like its done a Welsh rally stage.😖
Coolant leak thermostat housing 1.4tsi
Not a 1.4TSi here but I had a coolant leak (very small / almost non-existent) on my 2.0TSi. My car went in for a routine service & the garage found a low coolant fault code in the ECU memory. I remembered topping up the coolant 6 months earlier & the reservoir level had not changed since. The garage (independent VAG specialist) explained that it was a fairly common issue on many VAG engines related to connected plastic / metal parts leaking due to differing expansion / contraction rates & water pump corrosion / bearing issues. They changed the pump, thermostat housing & thermostat with a revised set of factory parts in a kit which confirms it is a known issue. Be prepared for a big bill🤑. My "routine / intermediate" service landed up costing £1,250 - & that's not main dealer pricing. New rear discs & pads were also included in my bill.
Nice job. I envy the space you have to get a car inside your garage with enough space to work on it under cover. My single attached garage is rammed & has become my workshop. Even if my garage was totally clear it's still not wide enough to get a modern car in it.
Impressive results for a self confessed beginner with a DA. What products did you use? e.g. cutting compound, polish etc. I'm interested in doing something similar on my car which has swirls & a few bird lime marks.
Yep, it's a mains powered DA. 1500-6400rpm with 150 &130mm dia pads. Cost about £75 from Amazon. I plan to test it on something before I use it on the car. I have an old beer fridge in the garage that could be a good test piece.
I know what you mean. I had a go at some scratches on my roof back in the summer. They needed filling with a body coloured paint pen first (black), then polishing by hand. I do have a random orbital polisher but decided not to use it this time. The result was reasonable but it only served to highlight other swirls elsewhere on the roof. Black shows every imperfection. There is a chance that I might sell my 280 when we get an EV for my wife next year so it would make sense to have the whole car detailed to make it look it's best before the sale. Alternatively I could take it to a detailer to have the whole car done professionally. If I do sell my 280 I would take over my wife's current 1.5 Karoq but I would badly miss the power of the Superb. Decisions decisions!
Chipped windscreens are like busses. Get one & another comes along soon after. I dread having to replace my screen as it is a heated one. Insurance will cover it (minus the excess) but I've heard that there are often problems with the heated elements after fitting a new screen.
Interesting. I wonder if there is an upgrade option available which could be added on to my next service maybe? I think I will enquire with my local Revo VAG independent when the time comes. Having said that, some of those features mentioned under "gauge config" look like they are related to a digital dash which I don't have so this latest revision of the software may not be backwards compatible with older Superb III models. I might just ask Revo directly & see what they say.
That must be a new feature because I don't have that on my Revo stg1 which was installed in 2020.
EVC Throttle Controller - Great upgrade
Thanks for that. It's tempting. But after some expensive recent purchases I really do need to tighten my belt. Next project is 57m2 of extra insulation in my loft + a raised chipboard floor over the top of it for storage of all the existing stuff I have up there now. As such all unnecessary spending is on hold for now.
No issues at all. Fitted / programmed by a local VAG independent & authorised Revo specialist in 2020 & all coded up (whatever that entailed). https://www.vagtech.co.uk/ Mine's a 2016 (66 plate) 280 L&K estate. New water pump & thermostat fitted earlier this year but that was nothing to do with the remap, just a naff VW designed plastic / metal leaking joint issue which I'm told is common to many VW engines. Insured (with remap declared) with LV for little or not much more than the std car. I might have to switch next year as like all insurers they have a habit of increasing their premiums on a depreciating value car which is a particular bug bare of mine. That said, 280's are not that common & seem to hold their value better than others.
Mine is a Revo remap. Torque is between 450 & 480nm. Revo
You're probably right. The pedals & connections are probably the same on the Superb & Karoq so I will have a look to see if a swap is possible. I was thinking about getting one for my Superb but due to all the price increases lately I've had to cut back on all unnecessary spending for the time being.
Superb wagon variable floor
Necessity is the mother of all inventions & in this case a cheap one too 👍
What make / model of throttle pedal did you get? Earlier this year I put a RaceChip XLR throttle pedal box on my wife's Karoq 1.5 DSG 4 x 4 & it certainly livened it up no end & took out the biblical hesitation it had. It even feels like it now has an extra 20-30hp which of course it doesn't. Like all DSG equipped cars my 280 (now running stage 1 360) does hesitate a bit from take off as well. Sport mode improves it a bit but there's still an underlying delay between the right foot & any forward motion until it gets into it's stride when it's inner hooligan takes over. Sounds like a a cost effective solution to the hesitation problem that all DSG's seem to have without having to resort to a DSG remap.
Power Consumption is High
I'm surprised the battery lasted as long as it did. The cheap OEM batteries fitted at the factory normally only last 3-4 years at best. FYI changing an AGM stop start battery needs a coding reprogram so if you don't have the kit to do it, it needs to go to a garage. It's really annoying that a simple battery change is no longer errr, simple😖. After shopping around I took my 2016 280 L&K to a local Kwik Fit who supplied & fitted a Platinum battery at short notice for £186 in March 2021. Price included coding, fitting & disposal of old battery & a 3 year warranty. I'm guessing your would probably be a bit cheaper.
Impressive. I'm on my 2nd battery after the original died on my drive during lockdown 1. 3-4 years is about all you seem to get out of the cheap OEM batteries.
Tyre Wear - Karoq Sportline 1.5 tsi 2020
Well the plot deepens. I had the tracking done this morning at the local Kwik Fit & sure enough the left front was out of wack - but only a little bit. It got adjusted. I think the tyre wear issue on my wife's Karoq can only be down to the local "MK roundabout factor" (apparently we have 130 of them) not enough longer journeys on straight roads driving style - it's my wife's car🤔 I'll swap the front & rear wheels to even up the tyre wear & keep an eye on the fronts. Don't know what else I can do really. Interestingly I do not get this problem on my Superb tyres.
What product did you use?
