karlos1987
Members-
Posts
63 -
Joined
Last visited
Content Type
Profiles
Forums
Gallery
Shop
Events
Downloads
Everything posted by karlos1987
Hello, I would like to ask if anyone has information about the functionality cruise control after replacing the gearbox 2.0 TDI BKD (PD) to a variant of the 2.0 TDI 103 kilowatts (CR). These transmissions have lower speed at the 5 and 6st, but so far I could not find what is "allowed" speed range of the engine ECU for proper function cruise. Thank you for anything
Audi A6 4F is on mechanical side in front without problem too :) Rear are not possible to fit at all...
Steering Wheel From Superb 2 Fl
karlos1987 replied to marekczek's topic in Skoda Octavia Mk II (2004 - 2013)
not, slip rings are fully compatible, problem is only between preFL and FL, because FL has angle sensor integrated in slip ring. -
Which kind of BSG/BCM do you have? We are talking about preFL or FL car?
Instrument Cluster differences ?
karlos1987 replied to andybristol's topic in Skoda Octavia Mk II (2004 - 2013)
index H means FAZIT4 security, there is no PIN and normally can be this cluister installed only with online acces to audi server or by someone who has knowledge... Index D is FAZIT3 with older pin security Both are prefacelift with same wiring harness. -
Yes, after that no problem:) -
Battery disconection is not neccesary, ifcar is in OK condition, all airbags are ruled by airbag main unit and without impact signal is no aibag ignition signal...
Are all Octavia Grilles the same?
karlos1987 replied to Vegasphil's topic in Skoda Octavia Mk II (2004 - 2013)
FL and preFL are different, but you are able to install it on prefl bumper etc... -
EA 189, 2.0 CR TDI engines since 2009 till 2014, Common rails diesels EURO5 and EURO5+
Hi CWARD:) That is not so complicated. Octavia MK1 is 1U, which means internal platform name of Skoda, so for skoda is Mk1 platform 1U, but not for VW, there is platform A4. Octavia MK2 is 1Z, but is builts on VW platform A5 ( Golf, Audi A3, Leon) Octavia MK3 is 5E, correct platform under MQB I don't know
Fitting Audi A6 seats in Octavia
karlos1987 replied to bf1's topic in Skoda Octavia Mk II (2004 - 2013)
If you have heating now, is better to do full retrofit with clima panel and so one... -
RED - lumbal support - only 12V Green - heating - seats have different imperance, but is not necessary to put additional resistor in serie black - driver/passager present, only 2 wires switch -
Good luck;) -
Hello Phil, technically it is not possible, because Octavia/Golf platform has different place for locks and so on, you only possibility is take the cover and place him on octavia seats, not more. Sadly, the rear armrest doesnt fit too, but is very nice (drink holders+storage). -
Facelift VRS seats vs Pre Facelift
karlos1987 replied to phil5556's topic in Skoda Octavia Mk II (2004 - 2013)
And really best are S-line (price/performace) -
1. No 2. No, external antenna is neccesary, but can be install in dashboard 3. No, only RNS310 (Amundsen+) has built-in BT. 4. Yes, yes, yes, yes and may be second FM/AM aerial instaled again in dashboard.
2008 Scout replacement engine options
karlos1987 replied to Scathel's topic in Skoda Octavia Mk II (2004 - 2013)
Engine swap is possible, it works etc, but for example in Czech republic, you cant change engine to different type or dismount DPF. For example BMM is 8V with DPF => EURO4, without DPF is not EURO4 and is out of homologation => not legal. Next, change of PD engine to CR with all things (DPF, ECU, exhaust...) is not possible, only 2008 RS was homologation with CR engine and only with 125kw... Technically, there is no problem, chassi is same, original parts are available, but it is restricted by law and Skoda too. So you cant passed trough STK (DEKRA/MOT) legally, and if you see any rebuilt car, it is sure it is not legal or must pass trough many tests (emission, brake tests etc.) wich are not gratis => nobody do it. Is very interesting, that UK is very similiar to USA and is open to customization of cars! -
I dont speak about warranty:) -
Change of engine type is not allow by Skoda Auto => there is no legal chance for it. Yes, devil Yeti exists and mechanically etc is there no problem, but problem is law, so you can re-built, but not use on the road as regular car. -
Change of engine is possible only with same type: BKD-BKD, BMM-BMM etc, no next option available at all. Skoda has no legal possibility. -
Pre fl 3 spoke hybrid wheel project
karlos1987 replied to Nikonite's topic in Skoda Octavia Mk II (2004 - 2013)
Why this? There is possibility of brand mark change only :/ -
07 Octavia - Replacement seat options
karlos1987 replied to mattupnorth's topic in Skoda Octavia Mk II (2004 - 2013)
I have A6 (4F) seats, with only electrical lumbal support, rest is mechanical, but are S-line, co better shape in shoulders area, good sides. I did one more hole in the floor of my car. Electric is very easy and heating is compatible too. Airbag connector is different in MY2008 too. -
Audi S3 -
Audi A6 4f S-line seats need only different connectors, but mechanically are same
