Posts
783 -
Joined
Last visited
Content Type
Profiles
Forums
Gallery
Shop
Events
Downloads
Everything posted by FLAPPERJACK7
Another door lock mechanism thread...
FLAPPERJACK7 replied to skaarlaw's topic in Skoda Fabia Mk I (1999-2007)
It's definitely deadlocked. You really have made a lot of work for yourself. I drill the barrel cover of and destroy the deadlock spring from the barrel side. I'm usually in and open in under 5 minutes. You must be in at your wit's end doing it that way. I thing I would of angle grinded the door before I got to that stage. Got any skin left on your knuckles? Sent from my SM-G900F using Tapatalk -
Workshop 'repair' policy
FLAPPERJACK7 replied to RicardoM's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda Forman
I agree that's not right. In the garages I have worked in. .We would be fixing it for free if we had made a **** up. Sounds more like a brothel than a garage. Sent from my SM-G900F using Tapatalk -
Did he pay for the diagnosis? is there a labour line for diagnosis. If there's no charge ..then it was a guess. Either way it would be extremely unlikely to be a lambda sensor for a misfire on just cylinder. Most of my work is from "been to another garage ". Sent from my SM-G900F using Tapatalk -
Bodyshop Staff Possibly Using My Vehicle For Their Own Use
FLAPPERJACK7 replied to a topic in General Automotive Chat
So would I. The tracker alarm wiring comes out of the box with 40 cm of wiring. So it doesn't take a genius to work out how to remove the tracker and the fact it's position is within 30 to 40 cm of the obd port. Sent from my SM-G900F using Tapatalk -
Trackers are now and also quite recently interfaced from the obd port. So its mostly obvious if it has a tracker fitted to those in the motor trade. Sent from my SM-G900F using Tapatalk -
5 year's ago when I worked for a Volkswagen dealer we had a valeter who took a car home. Nobody knew about it. Luckily it was only a trade in vehicle. He had been using it for 3 months till he was found out. Instant dismissal. Sent from my SM-G900F using Tapatalk -
Diesel Sidelight bulb change - HOW?
FLAPPERJACK7 replied to TheVWDoc's topic in Skoda Fabia Mk II (2007-2014)
There are 2 or 3 torx bolts if I remember correctly they are either t30 or t45 torx. You have unclipped and lifted the filter. But you need to unbolt the filter holder bracket. I have done loads and this is the only way unless you have teeny tiny hands and buckets of patience. Sent from my SM-G900F using Tapatalk -
Or just un bolt the fuel filter and move it... it's easy. Sent from my SM-G900F using Tapatalk -
I do feel sorry for you. From what you have said they sound like a bunch of bell end's. I would be thinking along the line's of taking it elsewhere. Maybe even small claims court. I think they have been rather heavy handed in having to carry out the rectification work. Sent from my SM-G900F using Tapatalk
800 sounds like they have knackered your DPF. There is a tool for going around the flexi. It's only a plastic tool. But it stops it from stretching and knackering it. Guess they never had or used this tool. Sent from my SM-G900F using Tapatalk
Have not really looked much further than cam and crank speeds. This t5 tdi is common rail so think it's a bit more advanced on the fault code side. Another thing to check on yours is n75 and hose block. I had one a few year's back. The owner had a turbo fitted and it still had no power by another garage. I found that there was a corroded pin for the live for n75. This pin was in a multi plug under the air filter housing and above the gearbox. Have also seen a lot of broken wires above the gearbox in the past in the loom. Sent from my SM-G900F using Tapatalk
Had a vw t5 tdi common rail in during the week . Engine workshop coming up on dashboard. Checked with vcds. Fault was cam and crank incorrect correlation. In measured value's was getting very similar reading as yours on this log. Don't know end result yet as it's booked in next couple of weeks for me to check valve timing. Sent from my SM-G900F using Tapatalk
Shouldn't cam speed be half of crank ? group 51 looks slightly out to me ..? Who changed the belt? 0.8l per hour consumption sounds a bit high as well. Sent from my SM-G900F using Tapatalk
G450 Exhaust Pressure Sensor
FLAPPERJACK7 replied to Anddenton's topic in Skoda Octavia Mk II (2004 - 2013)
The MOT test will soon be changing to include a test for diesel particulates and soot. This test measure the effectiveness of your DPF and your vehicle will fail it’s MOT if you’ve been naughty. Supposed to be a crackdown planned for 2016/2017. The government are also thinking along the lines of ved evasion and void insurance on this issue. Still some way to go here and no im not wanting to start a "bun fight " but might be worth some careful consideration before reaching for the angle grinder. Sent from my SM-G900F using Tapatalk -
VAG group "fixed" prices
FLAPPERJACK7 replied to nickgpfc's topic in Skoda Octavia Mk II (2004 - 2013)
They also hiccup in your tyre's and spit in your coolant if you take it to a good dealer. Sent from my SM-G900F using Tapatalk -
£159 for an oil change! Could do it yourself for £30 all in. Sent from my SM-G900F using Tapatalk -
Or when they undone the 17mm feed pipe the 14mm union came undone...seen that one before. As for the return pipe gasket. Probably not and probably not the union banjo bolt seals. Check your invoice for what part's are on it. Sent from my SM-G900F using Tapatalk
They might be able to do it in less than 20 hour's this time. Sent from my SM-G900F using Tapatalk
Does anyone have ETKA access?
FLAPPERJACK7 replied to paddy wagon's topic in Skoda Octavia Mk III (2013 - 2020)
Well spotted. Sent from my SM-G900F using Tapatalk -
http://partscatalog.info/ here you can in future look at it to your hearts content. Sent from my SM-G900F using Tapatalk -
Looks like the tank pump is working then and like you said my underpants are good for a while. You could disconnect the fuel pipe at the bulkhead put the ignition on to make sure it's being lifted to the fuel filter. It is the black pipe you want to disconnect. Black is feed and blue is return . Really a dtc code would be ideal. See how you get on. Update when you can. An injector failure can happen at any time. The ecu on this engine if it sees a fault from the injectors will shut it down immediately. I may be jumping to conclusions here. Could be an earth problem like you said. Main earth points will be in the scuttle near the ecu. One high on the chassis nsf. About 3 nsf lower chassis leg all connected together. Possible one on osf chassis leg. Should also be a small one on the engine itself from the engine wiring loom. Wire breakage is common especially around starter motor and any sharp points on the engine. Sent from my SM-G900F using Tapatalk
Try disconnecting battery 1st. It costs nothing and has fixed many a non start for me. It's just like turning off and restarting a computer and you know that normally works at home. If that does not work with starting it might with communication. Other than that maybe can bus has gone down. Or my next thought would be a faulty injector. If one goes down it will not start. But it's way easier if we can access fault codes. Sent from my SM-G900F using Tapatalk
