Posts
1,336 -
Joined
Last visited
Content Type
Profiles
Forums
Gallery
Shop
Events
Downloads
Everything posted by octavia5
Autoexpress have just done their annual Winter tyre test and included their best All Season tyre - Continental AllSeasonContact so they could be worth considering instead of the Michelin which were last years technology
Fault code u140600 static current too high
octavia5 replied to toni8b's topic in Skoda Octavia Mk III (2013 - 2020)
While modern miniature electronics are generally reliable they can partially fail and cause all sorts of odd issues, better to replace a plug in charger than have the car ripped apart to change an inbuilt charger. -
Winter wheel alternatives?
octavia5 replied to tinman80's topic in Skoda Octavia Mk III (2013 - 2020)
Hi, These are still for sale -
Did the car leak driving cross the Irish Sea? - seriously though have you plugged anything into the Ciggy Socket as this is live even when switched off and can drain the battery
I went from a Mk2 Octy TDI to a MK7 Golf GTipp DSG and loved the difference in power and comfort but very quickly regretted not going for the MK7 R so I took the hit and traded for a new DSG R and have never looked back. The R feels more planted than the GTi and grips far better - no more front axle tramp - just goes, its a mini super car, the GTi might be quicker when driven by a professional driver but for most of us the R just monsters it - I took both cars round Bedford in similar conditions and I was 15 second a lap faster in the R. On the road the extra grip and performance of the 4wd system gives a security and confidence you will never get from FWD motor. Surprisingly low insurance - less than the Octy - but much lower MPG, if MPG is an issue the GTi will do 5+ more mpg on average. Lastly suggest you go for an R with DCC and upgraded Audio and be prepared to never stop smiling.
Skotchguard it as soon as you take delivery - great stuff and came out top in Autoexpress upholstery protectors. Stains do not soak in and simply wipe off even ground in chocolate
haldex service intervals
octavia5 replied to 3rdoctavia's topic in Skoda Octavia Mk III (2013 - 2020)
Indys are normally quite happy to remove the pump and clean the filter - just needs flushing off or use a soft brush, they will have their methods. No fault codes and no need to removed the battery, just leave the car ignition turned off for 5 mins before disconnect. DIY instructions in links, most do not change the rubber seals or bolts but there is a 'service kit' available - all details in my link. Depending on miles done I would get it cleaned every couple of years, mine was filthy after just 7k miles and with no launches to stress the Haldex. -
Have a look at this thread on the Golf R forum. Having the Haldex oil changed does not normally include cleaning the filter and it is the build up on the filter that kills the pump or Haldex. I had my Haldex oil changed and the pump removed to clean the filter at 7k miles by an independant and it was amongst the dirtiest. If Skoda dealers are like VW dealers they say the filter does not need cleaning and will not removed the pump to do so - there is no separate filter on the R and I would assume the same on the Octy as it is screwed to the pump itself. VW seem to prefer to wait till either the pump fails or the Haldex packs up - normally outside warranty so will cost you a fortune. https://www.vwroc.com/forums/topic/24283-and-the-filthiest-haldex-filter-award-goes-to/?tab=comments#comment-388396 -
my2019 and throttle response ??
octavia5 replied to nitro2's topic in Skoda Octavia Mk III (2013 - 2020)
Best option is to fit a Pedal Box - little electronic unit that is installed between the throttle pedal and the ECU, is simple to fit and there are often units for sale from people who have had a full remap or are selling their car on. https://www.diesel-performance.co.uk/products-overview/?key=DTUK+Pedal+Box+Plus -
SOLD I no longer need these so grab a bargain before winter sets in. 4 genuine Borbet (German make who make wheels for the VAG group) wheels with quality Goodyear Ultragrip M&S winter tyres, 225/45/R17 91H These 17inch wheels easily fit over the 340mm brakes on my R so will fit all vehicles with these discs or smaller. They also give a very comfy ride. One tyre has had a professional repair for a screw through the tread – centre of the tread so an easy and legal repair. Tyres only covered 4734 miles and still have 6.5/7mm across the whole tyre. The wheels have very minor marks and no curbing. They are straight true and balanced. Wheels are 5x112, 57.1 bore, ET40 and use the original OEM bolts. You can still buy this combination from mrwinter wheels. https://www.mrwinterwheels.co.uk/17-vw-golf-vii-mark-7-alloy-winter-wheels.html I am only asking £380 collected from NN29 – thats half the current price.
Thanks, I do not use VCDS very often and forgot to scoll down the full scal, the detail IDs the problem, Address 10: Park/Steer Assist (J446) Labels:| 5Q0-919-294.clb Part No SW: 5Q0 919 294 K HW: 5Q0 919 294 A Component: PARKHILFE 8K H03 0054 Revision: -------- Serial number: 39331527805138 Coding: 0071151011 Shop #: WSC 01357 011 00200 ASAM Dataset: EV_EPHVA18AU3700000 002026 ROD: EV_EPHVA18AU3700000_002_VW37.rod VCID: 43854A93CA80C35286-8016 3 Faults Found: 1112084 - Front Left Center Parking Aid Sensor B10F8 14 [008] - Open or Short to Ground Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 3 Fault Frequency: 1 Reset counter: 213 Mileage: 12246 km Date: 2019.02.16 Time: 12:43:51 1112082 - Front Left Center Parking Aid Sensor B10F8 12 [008] - Short to Plus Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 3 Fault Frequency: 16 Reset counter: 175 Mileage: 12271 km Date: 2019.02.18 Time: 11:43:35 1112113 - Front Left Center Parking Aid Sensor B10F8 31 [008] - No Signal Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 3 Fault Frequency: 8 Reset counter: 215 Mileage: 12293 km Date: 2019.02.20 Time: 14:24:32
Yesterday I have a 'Park Assist Error' come up indicating a problem with the front sensors on my R - am hoping that this might still be relevant to Octy owners and that some knowledgeable person can help identify the problem, the scan:- Chassis Type: AU-VW37 (5Q0) Scan: 01 02 03 08 09 10 13 14 15 16 17 19 22 42 44 47 52 55 5F A9 VIN: WVW Mileage: 12293km-7638miles 01-Engine -- Status: OK 0000 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 10-Park/Steer Assist -- Status: Malfunction 0010 13-Auto Dist. Reg -- Status: OK 0000 14-Susp. Elect. -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 22-AWD -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 47-Sound System -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 55-Headlight Range -- Status: OK 0000 5F-Information Electr. -- Status: Malfunction 0010 A9-Struct. Borne Sound -- Status: OK 0000 I have looked on the Ross Tech site and can find no info to help. I am hoping that the code might indicate which sensor has failed. The radar cruise still works as do the rear camera and sensors. Any help/guidance would be appreciated
Rear Auto Wipe- Not Wanted In Winter
octavia5 replied to gregoir's topic in Skoda Octavia Mk III (2013 - 2020)
When did you last reverse on a motorway? -
1st to 2nd kick into gear
octavia5 replied to SkodaAsh's topic in Skoda Octavia Mk III (2013 - 2020)
Ah, I forgot you have a proper handbrake don't you, the system works differently on a Golf with an electronic HB, I have to press the throttle before the engine restarts. -
When stationary using Stop Start you must just caress the throttle to get an restart and then apply the throttle very slowly and smoothly if you push the throttle to far the instant you restart the engine will try to accelerate hard and this will cause a lurch when changing from 1st to 2nd whether you are in auto or manual, you are simply overloading the drive chain and need to moderate your technique. You would get the same issue with SS disabled if you applied too much throttle from the off, the change from 1st to 2nd can be quite a jolt, this is a 'feature' of the DSG and you just have to modify your driving style to get the best from the box. -
Issues to check out prior to conclusion of warranty
octavia5 replied to Gaius's topic in Skoda Octavia Mk III (2013 - 2020)
I am guessing that if you do not have an actual fault the dealer will simply say normal for age and refuse to do anything. There is no way they will return the car to as-new or change parts just because there may have been issues with a small number of cars. If you bought from a Skoda dealer did you not get a 12 month warranty? If you bough privately and are concerned about the future then take out an extended warranty. -
VRS - spare wheel and foam insert
octavia5 replied to magicpants's topic in Skoda Octavia Mk III (2013 - 2020)
A search on Ebay for 'Golf space saver' will though up a lot of kits and part kits from £50 and they have the same stud pattern as the VRS. -
Car Alarm/ DWA / Interior Monitoring
octavia5 replied to PeterEde's topic in Skoda Octavia Mk III (2013 - 2020)
Can you not press the remote lock button twice to turn off the interior protection while leaving the doors locked. -
Dynamic Chassis Control Experiences?
octavia5 replied to ExSEAT's topic in Skoda Octavia Mk III (2013 - 2020)
Does just this on my R - would not now buy a motor without it.
