ChoonDoode
Everything posted by ChoonDoode
  1. You're using obd11 though, not VCDS
  2. sooner fit a wooden wheel as a spare than use a can o' gunk. There's no guarantee of sealing it and it's a once only affair
  3. @ScoutCJB Yeah I've just hooked mine up and I get 31347. See below I'm sure you've already checked, but are you using the very latest version?
  4. Would have assumed it would have been Amundsen minimum. My centre speaker sometimes feels like it's vibrating, but I'm not sure if that's because I'm listening to something with a fair bit of bass in it
  5. Have you got the variable boot floor? If you have then I suppose having a wheel sticking slightly above in the lower section won't matter because it'll be under the floor. But I've had spacesavers in my last 2 cars and they're easy to have on to be able to limp to garage. Don't get any tyre goo crap. Loads of tyre fitters go spare if it's been used, especially if you want the tyre fixing. And it's not a fix all solution. Get a nick in the sidewall and it's not fixing that. And it's a once only affair.
  6. Now this is your stereotypical case of 'the devil makes work for ideal hands'........ and it appears to have gone sideways. After a while of thinking to do it, I've finally fitted an aftermarket dogbone mount bush; a Powerflex Front Lower Engine Mount Hybrid Bush (Large) PFF85-833BLK to be precise. I chose the black series just to get the 'best' I suppose, but I don't know if that's the root of the problem with it being more track orientated. Unless I've fitted it incorrectly and or bought the wrong one, it's vibrating like a right beepity beep. When you have the car idling, there's a little bit of an additional hum, but I was expecting that. The main issue appears when you go to move away and when the revs are between 1 and 1.5k, there is an almighty vibration which goes through the whole car. I drove the car up my close and the vibrations go away completely when you're over 1.75k. I've had the car back on the ramps to make sure I've not done a schoolboy error and forgotten to tighten it all up, but everything is as tight as it's recommended (I don't want to tighten it any more in case I break something) Now I had to go to work this morning (slightly knobbled car or not) and I was able to check it going through the gears properly, even up the motorway. Once your moving, it's fine. As is accelerating (which actually feels better). But go into the above rev range and it's god awful. I understand the rubber mounts are deliberately designed to get rid of any harshness, but deary me, if this is what a poly bush feels like, I've well and truly made a mistake fitting this. I'm at a bit of a loss because I had to 'chop' the old one out. Help. Advise. Please 😢
