MartiniB
FREEDOMTech
Everything posted by MartiniB
  1. tire size is optimal, but don't think it will fit on the OEM spare disc just illustration, this online tool doesn't allow set with 125 and doesn't move tire on offset change https://www.wheel-size.com/calc/?wheel1=135-70-18X4ET35&wheel2=195-55-18X6ET40&fcl=50mm&scl=50mm&wcl=30mm&sr=0mm 195 tire will require 6J disc while OEM 125 looks about 4"
  2. yes, that was OEM 18" spare, i posted it as tool kit illustration edges cutting must help to fit it also in full size disc
  3. why do focusing on disc inches? when most important is circumference, which depends on tire size OEM sizes Diameter/Circum. mm 215/55r17 - 668 2098 0% 235/45r18 - 668 2101 0% 235/40r19 - 671 2106 +0.4% 215/60r16 - 665 2085 -0.4% 215/50r18 - 673 2111 +0.8% 235/50r17 - 668 2093 0% 235/35r20 - 673 2111 +0.8% out of manufacturer approval 225/55r17 - 678 2134 +1.5% my choice 235/50r17 - 668 2093 0% 240/45r18 - 673 2113 +0.8% 245/45r18 - 678 2129 +1.5% 245/40r19 - 678 2131 +1.5% 245/35r20 - 681 2134 +1.9% Spare Wheels: OEM 125/70r18 - 632 1986 -5.3% 205/55r16 - 632 1984 -5.3% optimal, out of manufacturer approval 195/65r16 - 660 2073 -1.1% 205/65r16 - 673 2113 +0.8% 205/60r17 - 678 2129 +1.5% 195/55r18 - 671 2108 +0.4% 205/50r18 - 663 2080 -0.8% i think that foam edges can be easily cut OEM 18"
  4. this cut can be made invisible, here is lost just bottom part of L trim damaged regular, +1.5% oversized, 225/55r17 on 7.5J alloy as spare i took 205/60r17, but currently it is mounted on same 7.5J alloy and it pushes up floor for ~20mm later will replace disc to 6.5J ?metal? with same tire
  5. @Summerhillred look to pictures, rear plastic trim must be cut
  6. @Dieselgate Google for 'Haldex and different sized wheels' i found recommendation, 4% between axles, if you have time, do some deeper research and share us info about % between Left/Right
  7. @JDEE threads are more than enough by simple board search "full diameter spare wheel" i can't even find my posts in the first list -> https://www.briskoda.net/forums/search/?q=full diameter spare wheel&quick=1&type=forums_topic&nodes=299 i found one of several -> https://www.briskoda.net/forums/topic/509471-would-you-take-a-superb-estate-over-passat-estate-if-passat-is-cheaper/?do=findComment&comment=5719561 diameter comparison to regular 215/55r17 and 225/55r17: OEM 205/55r16 _ -5.3% _ -6.7%, this huge size difference cancels usage of cruise control custom 195/65r16_ -1.1% _ -2.6% custom 205/65r16_ +0.8% -0.7% custom 205/60r17 +1.5% 0.0% Spare Wheel options, pros and cons: a) same size as all other wheels -> https://www.briskoda.net/forums/topic/493502-full-sized-tyre-as-spare/ + can be installed on any axle + can be used for unlimited distances + no size diff = no speed limits + Cruise control will be available - boot floor will be pushed few cm up - most expensive b) custom 205/65r16, full diameter (my choice for 220ps) -> https://www.briskoda.net/forums/topic/442912-full-size-spare-wheel/page/2/?tab=comments#comment-5040470 + minor width diff will provide safe driving on + 30% of speed printed on spare disc. Important note, when installed on rear axle. + can be used for longer distances + minor circumference diff will provide ability of Cruise control usage. In theory, i haven't had to test it after OEM 205/55r16 were replaced. + fits in it's place, doesn't change size of boot. - !!! doesn't fit on 272/280ps even on rear axle !!! c) custom 205/60r17, full diameter (my choice for 280ps) -> https://www.briskoda.net/forums/topic/520234-superb-mk3-spare-wheel/?do=findComment&comment=5818139 Pros are equal to b and fits on 272/280ps, which has bigger brake discs, 340/310, while all rest have 310/298 (front/rear) d) OEM 205/55r16 + lot wider than 'd' = safer than 'd', but don't think printed speed limit can be exceed more than + 10%, even when installed on rear axle. + fits in it's place, doesn't change size of boot - huge circumference difference disables usage of Cruise Control - huge circumference difference isn't healthy for 4x4 e) OEM 125/70r18 + fits in it's place, doesn't change size of boot - huge width difference = absolutely unsafe, even when installed or rear axle. - huge circumference difference disables usage of Cruise Control - huge circumference difference isn't healthy for 4x4
  8. sometimes my OBDEleven Gen1 has been left connected for months long maximum days when car was standstill were ~ 4 ~
  9. i don't expect it, newer nowadays means less functionality for extra fee this year abonement i'll pay not for maps, but for remote access to Auxiliary heater haven't checked price yet
  10. With Mib3 and higher this could change depending on users interest at annual online subscription
  11. that times are coming 😞 2023.10.09 VW stopped support of Discover Care what were exe for checking and download updates by selected car/infotainment model, similar as their web i haven't use it ever, but it's information source, xml page, were perfect source to fix published date and all files in one list this part of catching code became useless DiscoverCare) # =========== DiscoverCare # =========== check filenames in the XML file # 2021/2022 2021.06.30 # 2022 2021.11.25 # 2022/2023 2022.06.27 # 2023 2022.12.15 # - - - 2023.10.09 Sorry, no more updates here. Please use myVolkswagen fTMP=/tmp/vw_discovercare.xml wget -O $fTMP -q https://www.volkswagen.com/content/medialib/vwd4/global/discovercare/files/configuration/_jcr_content/renditions/rendition.file/discovercare.xml if [ "$?" = "0" ]; then if [ -s $fTMP ]; then tDATE=`grep -si " last update " $fTMP| head -n1| sed -e s/.*update// -e s/--.*// -e s/\ //g` if [ ${tDATE:8:2}${tDATE:3:2}${tDATE:0:2} -gt "221215" ]; then for tFILE in `grep -s "http.*vw-maps.*.7z" $fTMP| sed -e s/.*https/http/ -e s/\<.*//`; do if grep -qsE $tFILE $cCAUGHT; then echo -e "file is known \t"$tFILE echo -e "file is known \t"$tFILE>>$cLogFILE else echo -e "new file \t"$tFILE echo -e "new file \t"$tFILE>>$cLogFILE echo -e "----.--.--\t"$cMibID"\t"$tFILE>>$cCAUGHT_Today IsFound=1 IsCAUGHT=1 fi done else echo "XML last update: "${tDATE:6:4}.${tDATE:3:2}.${tDATE:0:2} echo "XML last update: "${tDATE:6:4}.${tDATE:3:2}.${tDATE:0:2}>>$cLogFILE fi else echo Zero len $fTMP echo Zero len $fTMP>>$cLogFILE fi else echo !!! Download $fTMP failed !!! echo !!! Download $fTMP failed !!!>>$cLogFILE fi
  12. but i were sure, i haven't dreamed it, few sec Google search ->
  13. @Tell I reported at ~2017 about missing logos in my Mib2H Columbus, at ~2018.05 i got them after whole fw update by dealer last story started on 2023.12 first answers were thanks for info, but their db is up to date and Škoda responds outdated db in my Mib3 Amundsen then i made visit to VW's dealer and checked situation on Tiguan; ID.4 and noted exactly same situation. after second report, which included table with situation on VW head units, they send me link where to download latest Phonostar's dbs, i forwarded info about newer dbs and update instructions to VW dealer, but still have no response i din't tried new db immediately in my Škoda's head unit, just because bad opinion with years ago found database RSDB_VW_Multi_EU_v1.10.10.7z which contained -VW- restriction in it's metainfo file, just weeks later i decided tryout and were positively surprised, then i more carefully browsed whole archive, where found metainfo with -SK- too, what explains success yes, PI must be important key, because all the stations where logo gone, had changed it. but at same time, BBC World in Riga doesn't transmit any RDS, but logo is present
  14. @enisz What was the weather, i believe it could be disabled at low temperature
  15. can't say about rear, haven't it, but front "tear drops wipe" works only at speed ?0+ kmh
  16. just in case, they ask for device number: Mib2 3Q0 035 824 C Golf 2018 Mib3 3G5 035 820 Q Tiguan 2023 Mib? 10A 035 816 R ID.4 2023
  17. some came by self after update, but one i had to add through Settings -> ~ Logos ~ -> . . . before update choice list of this station were empty
  18. similar, incompetent, answer i got from Czech's helpline: most obvious messed to DAB/DAB+, because by FM's RDS standard can't be transferred any logos use then first, Mib2 link, more over it contains also -SE- while other twos only -VW- and -SK- and renamed stl.1vw to stl.sqlite form Mib2 archive can be opened by DB Browser (SQLite) while other twos not, as You mentioned
  19. after 11 months also left side did the same 😞 5E3 052 133 E
  20. Wrong, That is completely different story - 1. content of these archives stopped refreshing several years ago. i checked them regularly for my previous 2016. Superb Mk3 20160609; 20161020; 20171123; 20180509; 20181213; 20200331; no more new releases 2. they are useless for Mib3 and all newer head unit devices, only Mib2 and Mib2H had functionality to upload logos individually for each favorite station. example of single logo update procedure: 3. upload procedure were different, for each station individually, this thread is about update whole built in database at once 4. individually uploaded by user were displayed smaller than from internal head unit database even identical files -> https://www.briskoda.net/forums/topic/415291-columbus-radio-icons/ 5. one were better - individually upload method gave ability use whatever logo picture, even selfmade
  21. managed to find how to update radio stations logos database -> https://www.briskoda.net/forums/topic/520105-radio-stations-logos-database-updates/
  22. Database is maintained by Phonostar.de and Škoda doesn't hide that but one of their answer sounded similar to . . . "Škoda's users don't have to contact to Phonostar" . . . life hack, if you have any questions to stations @ phonostar.de, write them as VW user updates can be downloaded from https://www.phonostar.de/vw/en/download https://www.phonostar.de/vw/de/download by enter VW's head units part number Mib2 (Superb Mk3 and similar) Golf Mk7.5 3Q0 035 824 C "FM2-H-*-EU-SE-MQB" "FM2-H-*-EU-SK-MQB" "FM2-H-*-EU-VW-MQB" "FM2-H-*-RW-SK-MQB" "FM2-H-*-RW-VW-MQB" Content; Downloadable; Size; 2023.11.09 2023.12.13 89 MB https://www.phonostar.de/download/vw/MQB2_Europe_v1.10.48.zip 2024.07.17 2024.08.05 93 MB https://www.phonostar.de/download/vw/MQB2_Europe_v1.10.52.zip 2025.07.07 2025.07.08 93 MB https://www.phonostar.de/download/vw/MQB2_Europe_v1.10.60.zip 2025.12.01 2026.03.09 95 MB https://www.phonostar.de/download/vw/MQB2_Europe_v1.10.64.zip 2026.05.16 2026.07.13 97 MB https://www.phonostar.de/download/vw/MQB2_Europe_v1.10.66.zip 2026.09.26 2026.10.15 98.5 MB https://www.phonostar.de/download/vw/MQB2_Europe_v1.10.70.zip Mib3 (Superb Mk3.FL and similar) Tiguan 3G5 035 820 Q "FM3-E3-DWBC4-EU-SE-MQB-PC", "FM3-E3-DWBC4-EU-SK-MQB-PC", "FM3-E3-DWBC4-EU-VW-MQB-PC", "FM3-E3-WBC4-RW-SE-MQB-PC", "FM3-E3-WBC4-RW-SK-MQB-PC", "FM3-E3-WBC4-RW-VW-MQB-PC", "FM3-E3-WBC4-US-VW-MQB-PC", "FM3-E3-DWBY4-EU-FO-MQ2-PC", "FM3-E3-DWBY4-EU-SK-MQ2-PC", "FM3-E3-DWBY4-EU-VW-MQ2-PC", "FM3-E3-DWBY4-W2-FO-MQ2-PC", "FM3-E3-DWBY4-W2-SK-MQ2-PC", "FM3-E3-DWBY4-W2-VW-MQ2-PC", "FM3-E3-HWBC4-RW-VW-MQ2-PC", "FM3-S-NDWBY4-EE-SK-MQ2-PC", "FM3-S-NDWBY4-EE-VW-MQ2-PC", "FM3-S-NDWBY4-EU-SK-MQ2-PC", "FM3-S-NDWBY4-EU-VW-MQ2-PC", "FM3-S-NWBY4-R2-SK-MQ2-PC", "FM3-S-NWBY4-R2-VW-MQ2-PC", "FM3-S-NWBY4-RW-SK-MQ2-PC", "FM3-S-NWBY4-RW-VW-MQ2-PC", "FM3-S-NWBY4-W2-SK-MQ2-PC", "FM3-S-NWBY4-W2-VW-MQ2-PC", "FM3-S-NWBY4-W3-SK-MQ2-PC", "FM3-SM-NDWBY4-EE-SK-MQ2-PC", "FM3-SM-NDWBY4-EE-VW-MQ2-PC", "FM3-SM-NDWBY4-EU-SK-MQ2-PC", "FM3-SM-NDWBY4-EU-VW-MQ2-PC", "FM3-SM-NWBY4-R2-SK-MQ2-PC", "FM3-SM-NWBY4-R2-VW-MQ2-PC", "FM3-SM-NWBY4-RW-SK-MQ2-PC", "FM3-SM-NWBY4-RW-VW-MQ2-PC", "FM3-SM-NWBY4-W2-SK-MQ2-PC", "FM3-SM-NWBY4-W2-VW-MQ2-PC", "FM3-SM-NWBY4-W3-SK-MQ2-PC", "FM3-S-NWBY4-RW-SK-MQB-PC", "FM3-S-NWBY4-RW-VW-MQB-PC", "FM3-SM-NDWBY4-EE-SK-MQB-PC", "FM3-SM-NDWBY4-EE-VW-MQB-PC", "FM3-SM-NDWBY4-EU-SK-MQB-PC", "FM3-SM-NDWBY4-EU-VW-MQB-PC", "FM3-SM-NDWBY4-RW-SK-MQB-PC", "FM3-SM-NDWBY4-RW-VW-MQB-PC", "FM3-SM-NDWBY4-W2-SK-MQB-PC", "FM3-SM-NDWBY4-W2-VW-MQB-PC", "FM3-SM-NWBY4-R2-SK-MQB-PC", "FM3-SM-NWBY4-R2-VW-MQB-PC", "FM3-SM-NWBY4-RW-SK-MQB-PC", "FM3-SM-NWBY4-RW-VW-MQB-PC", "FM3-SM-NWBY4-W2-SK-MQB-PC", "FM3-SM-NWBY4-W2-VW-MQB-PC", "FM3-SM-NWBY4-W3-SK-MQB-PC", "FM3-S-NDWBY4-EE-SE-MQB-PC", "FM3-S-NDWBY4-EE-SK-MQB-PC", "FM3-S-NDWBY4-EE-VW-MQB-PC", "FM3-S-NDWBY4-EU-SE-MQB-PC", "FM3-S-NDWBY4-EU-SK-MQB-PC", "FM3-S-NDWBY4-EU-VW-MQB-PC", "FM3-S-NDWBY4-R2-SE-MQB-PC", "FM3-S-NDWBY4-R2-SK-MQB-PC", "FM3-S-NDWBY4-R2-VW-MQB-PC", "FM3-S-NDWBY4-RW-SK-MQB-PC", "FM3-S-NDWBY4-RW-VW-MQB-PC", "FM3-S-NDWBY4-W2-SE-MQB-PC", "FM3-S-NDWBY4-W2-SK-MQB-PC", "FM3-S-NDWBY4-W2-VW-MQB-PC", "FM3-S-NWBY4-R2-SE-MQB-PC", "FM3-S-NWBY4-R2-SK-MQB-PC", "FM3-S-NWBY4-R2-VW-MQB-PC", "FM3-S-NWBY4-W2-SE-MQB-PC", "FM3-S-NWBY4-W2-SK-MQB-PC", "FM3-S-NWBY4-W2-VW-MQB-PC", "FM3-S-NWBY4-W3-SK-MQB-PC" Content; Downloadable; Size; 2023.12.20 2023.12.20 162 MB https://www.phonostar.de/download/vw/MQB3_OI_JND_Europe_v1.31.48b.zip 2024.05.17 2024.11.07 1,13 GB https://www.phonostar.de/download/vw/MQB3_OI_JND_Europe_v1.31.50.zip 2025.01.14 2025.02.20 166 MB https://www.phonostar.de/download/vw/MQB3_OI_NonGP_JND_Europe_v1.31.56.zip 2025.01.08 2025.05.26 833 MB https://www.phonostar.de/download/vw/MQB3_OI_JND_Europe_v1.31.56.zip 2025.03.19 2025.06.11 167 MB https://www.phonostar.de/download/vw/MQB3_OI_JND_Europe_v1.31.58.zip 2026.02.16 2026.03.09 174 MB https://www.phonostar.de/download/vw/MQB3_JND_Europe_v1.31.64.zip 2026.05.15 2026.07.13 182 MB https://www.phonostar.de/download/vw/MQB3_JND_Europe_v1.31.66.zip 2026.09.27 2026.10.15 185 MB https://www.phonostar.de/download/vw/MQB3_JND_Europe_v1.31.70.zip Mib3 (Multivan) Multiv. 5H0 035 816 S "FM3-*-*-EU-SK-*-LG", "FM3-*-*-RW-SK-*-LG", "FM3-*-*-W2-SK-*-LG", "FM3-*-*-EU-VW-*-LG", "FM3-*-*-RW-VW-*-LG", "FM3-*-*-W2-VW-*-LG" Content; Downloadable; Size; Vers; 2024.10.07 2024.11.07 167 MB 2024Q4 https://www.phonostar.de/download/vw/MQB3_LGe_Europe_v1.31.54.zip 2024.11.12 2025.01.14 166 MB 2024Q4 https://www.phonostar.de/download/vw/MQB3_LGe_Europe_v1.31.56.zip 2025.03.19 2025.05.26 167 MB 2025Q1 https://www.phonostar.de/download/vw/MQB3_LGe_Europe_v1.31.58.zip 2026.01.29 2026.03.09 174 MB 2026Q1 https://www.phonostar.de/download/vw/MQB3_LGe_Europe_v1.31.64.zip 2026.05.15 2026.07.13 182 MB 2026Q2 https://www.phonostar.de/download/vw/MQB3_LGe_Europe_v1.31.66.zip 2026.09.27 2026.10.15 185 MB 2026Q3 https://www.phonostar.de/download/vw/MQB3_LGe_Europe_v1.31.70.zip Mib? (Enyaq, ID* and ??) ID.4 10A 035 816 R "I31-*-*-EU-SK-MEB-LG", "I31-*-*-EU-VW-MEB-LG" Content; Downloadable; Size; Vers; 2023.11.09 2023.12.13 162 MB 2023Q4 https://www.phonostar.de/download/vw/ICAS3_LGe_Europe_v1.31.48.zip 2024.07.15 2024.08.05 167 MB 2024Q3 https://www.phonostar.de/download/vw/ICAS3_LGe_Europe_v1.31.52.zip 2024.11.12 2025.01.14 166 MB 2024Q4 https://www.phonostar.de/download/vw/ICAS3_LGe_Europe_v1.31.56.zip 2025.03.19 2025.05.26 167 MB 2025Q1 https://www.phonostar.de/download/vw/ICAS3_LGe_Europe_v1.31.58.zip 2026.01.29 2026.03.09 174 MB 2026Q1 https://www.phonostar.de/download/vw/ICAS3_LGe_Europe_v1.31.64.zip 2026.05.15 2026.07.13 182 MB 2026Q2 https://www.phonostar.de/download/vw/ICAS3_LGe_Europe_v1.31.66.zip 2026.09.27 2026.10.15 185 MB 2026Q3 https://www.phonostar.de/download/vw/ICAS3_LGe_Europe_v1.31.70.zip update instructions: Mib2 https://www.phonostar.de/download/vw/MQB2_Stationlogos_CustomerUpdate.pdf Mib3 https://www.phonostar.de/download/vw/MQB3_Stationlogos_CustomerUpdate.pdf Mib3+ https://www.phonostar.de/download/vw/37W_Stationlogos_CustomerUpdate.pdf from the factory mine 2023.01 Mib3 Amundsen had database v1.30.36. and 14 of 29 Riga's FM stations had none logo, what especially annoyed, because all Mib3 and newer head units have lost option of manual upload logos, what were possible in my previous 2016.02 Mib2H Columbus -> https://www.briskoda.net/forums/topic/415291-columbus-radio-icons/ with new database only 7 of 29 are missing, missing stations are equal in both tested databases (Superb Mk3.FL and Enyaq) but last one contains more relevant logos -> solution Superb Mk3.FL 2023 Enyaq 2022
  23. which type of head unit? on my previous MY16 Mk3 Columbus 8" Mib2H Canton BT had acceptable sounding, but MY23 Mk3.FL Amundsen 8" Mib3 Canton BT gives huge amount of compression artefacts on the highs, while FM sounds richer, especial in mid bass range. (can't say right now, which exact codec is selected on Galaxy S22 Ultra, but other tried didn't work anyway) so sceptical looking to migrate to AA, because Waze then will lose a lot of functionality has anyone come across any information, what equipment must be installed, to activate this option? changing of first parameter in this screen, didn't give any noticeable changes
  24. not directly `09 Central Electrics` -> `Long coding`, but 09 . . . -> `Subsystems` -> `48x LL 221122` -> `Long coding`
