Everything posted by Me-109
Replacing front struts
Haven't YouTubed anything yet. Mine's a 61 plate so heading on for 10 years old. Looks reasonable decent condition so hoping for just a quick wire brush of the bolts, rattle the nuts off and see if I can get one of my trusty chisel in as a spreader.
Front wheel bearing
Not sure if either of you can help with this one, but have just put up a related post/thread about strut replacement Strut replacement
Got a broken spring on the offside and previous MoTs have sometimes identified a light misting on the nearside strut. I don't think the offside is much better so going to replace both struts, springs and top mounts (while I'm there). At least that means I can fully assemble them on the bench, so to speak, and speed up the strip/install. So the question is, can I pull the strut without having to pull the driveshaft? These are 50mm struts, if that makes a difference (it might with length)? Ball joint and/or track rod end to get wiggle room, is that all that's required? Bonus question, can you fit a new spring just using the threaded-bar type spring compressors? When I did the Fabia's springs last year I ended up taking them to the local tyre-and-exhaust type places for them to use their hydraulic compressor. Just the wrong size or spacing of coils for both sets I have.
Front wheel bearing
Did mine on the car. Can't remember if 3 or 4 bolt fixing. Think one of them was slightly more difficult to get at but generally straightforward. Run some emery cloth or similar around the carrier where the hub sits prior to fitting up the new one. A smear of copper grease may not harm either.
Front axle nut rusted solid, any ideas please
I think a method my brother has used is to fit the socket and breaker so the tip of the bar is on or near the ground, then engage 1st/reverse to suit so that as the car moves it levers the bar enough to crack the nut off. It might depends on the surface you have to work with - you don't really want the tip digging in.
I've had to use a short scaffold bar slipped over the end of a 30 or 36 inch breaker bar. The scaffold bar used to be my dad's, no idea how he got it.
Anyone heard of Mannol Oil or used it
Bought a big drum off the Bay for something like 40 quid. Specs checked out on website and worked across three cars in the fleet. Done a change for each one and all running fine (as far as anything oil related).
Looking for spare parts
UK cluster would be primarily MPH Speedo dial. This is mostly a UK forum so that's what you're likely to get by asking here. Would that be a problem with KSA registration?
Torque for caliper bolts?
Visually they are very different calipers - one has a ribbed top, the other smooth and rounded. A quick eBay search will reveal that you can buy a new one for nothing more than the cost of a rebuild kit. That will also tell you which size it is. Buy another one of those. For the correct side since they are handed. I'd agree on the rigid lines as well. Try some local motor factors instead of a garage as they may well be able to make them up for the cost of a couple of ends and five minutes of time.
How does the engine know the caliper is removed?
If so I wonder if the incorrect discs have been fitted and are contacting the carrier (incorrect depth rather than incorrect OD). That wouldn't explain the fault light, which I suspect is linked to the wheel speed sensor as above. Either disturbed rust or cable damaged during the brake job.
Headgasket
There is still probably more value in the car than the cost of the job. Only you in your particular circumstances can decide if it is worth doing, or just scrap it.
Parts For Sale: Pagid rear discs and pads - brand new!
I've just recently bought a disc and pad set from them via their eBay shop, checking via message that they were the right pads. After fitting the discs I opened the pads box and found they were incorrect. They might be correct for some Mk2s as per the box, but they need to be Lucas calipers. See the Pagid brakebook: https://www.brakebook.com/bb/pagid/en_GB/articleSearch.xhtml?result=1607301027716&showResult=1 Just saw the last post after posting this. Indeed 282mm rear discs fitted to Octy2 vRS, Leon Cupras, a raft of Golfs (not just GTis). Again the Pagid list can help identify.
Skoda Octavia MK2 vrs for a young driver?
Only you can price up insurance and know if you are prepared to pay it. My lad's insurance on the Fab VRS, Fiesta ST and Mini Cooper S have all been eye watering. Makes my eyes water 'cos I've paid most of it. It's a family hatch, so a jump in size and may seem a bit 'old man' if you're a young 'un. Do you want petrol or diesel? Petrol models come with their own issues. Diesel versions have typical diesel issues that can get expensive once they get to that age/mileage - DPFs, cambelts, the fact they are often bought to do high miles in the first place or end up with an owner or two that only goes to the shops and then it's back to DPFs...
Mot fail.... dpf removal
Result!
Water Moving About - Any Ideas?
I had this in a Mazda 6 once. Worth checking the sill drains.
