Everything posted by Bud
Front assist Sensor and Bracket. Superb3
Has anybody tried repairing the bracket?
Paint Correction and Ceramic. Less than 1 year old.
Excellent work Mine looked like that once😪
- Help required to correctly identify the paint on my car please?
Bracket is made of cheap frangible sugar! I would consider if they were made from brandy snap at least you would having something nice to eat when they disintegrate. Top RH corner failed behind adjuster but just look at the corrosion, outrageous really that they can be so poorly designed and manufactured 😱 £53 for new bracket and quoted over £300 for calibration. I'll be trying, no power whilst disconnected and M1 Southbound>50 mph. I'll let you know. https://www.theskodashop.co.uk/products/skoda-holder-for-the-front-radar-3q0998561#gallery
Alloy Wheels with Winter Tyres
I have since but new tyres on ~£600 and I don't think you'd want to be covering the cost of those.
Sump plug stripped
But that requires skill, knowledge and competence, not just being a box changer. I wonder even if stud extraction, cleaning out blind holes and using inserts is taught to mechanics now.
Tyres problem
Not that it helps but I am amazed that anybody would keep P7s on for that long. I found them to have the feel, grip and feedback one might associate with having solid rubber. Was extremely happy to ditch them fairly early on. Are they on the correct size wheel?
Goodbye Superb, hello Kodiaq
I trust you have verified the towing capability. I understand that there were some issues with Kodiaks being rated at Zero KG but that might be historic situation but I would want to be certain.
Snow Chains for 18-inch Wheels
That appears to be quite a difference in speed ~5.4% I can confirm MYTRES are woeful, tyres seemed like a good price but despite getting an anticipated delivery date before my trip they were not delivered in time. I cancelled before travelling, sourcing an alternative tyre, and when I got back they had been left on my doorstep. They advised that they were delivered before I cancelled! Muppets! Never use them again.
See here: https://www.willtheyfit.com/index.php?width=235&aspect=45&diameter=18&wheelwidth=8&offset=44&width2=225&aspect2=55&wheel_size=17&wheel_width=7&offset2=46
Did you steel those from my garage? I'm off outside to check🤔 In fact I am not sure that you've not stolen my car!
Drive Modes - Reset on each new start?
Just taken this sorry it's not the best but yes I leave the settings as individual and if needed just use the stick to go into Sport mode or very occasionally rock it sideways to use manual I know I have 2 warnings one for service and one for Front Assist not Available so if anybody has any clues on the second that would be great. Ta Eco.mov
Works OK on mine, same engine and MY as OP. 🤷♂️
If you set up "Individual" this should retain the settings.
If you are travelling that frequently I would invest in wheels and winter tyres. Also bear in mind that whilst you may need chains to get up the mountain there might be much snow in the valley and the route into the bottom of the resort. So if safety is really your priority then consider spare wheels and winter tyres. Once you have used them you will be amazed at how good they are see blow only a short distance from the main road but parked safely Habitually change summers for winters and have been for a few years now, since living in Munich, even when I don't go skiing. A 215/55/17 is a direct change for 235/45/18 and will enable chain fitment as well although I don't have chains.
tyre repair kit
I'd be worried if they weren't doing that as standard! But yes the goop does bring about "I don't want to" rather than "It can't be done."
What size wheels/tyres will fit to Superb III
I have a set of Audi badged whees with winter tyres they currently have alloy spigot rings fitted for use on Škoda 57.1mm vice Audi 66mm. See here for details:
As we approach another winter consider if you are as safe as you could be. These wheels and tyres will enhance you safety, not only in snow but also when temperatures are lower. Have a look! Have a think! Make me an offer!
Boot Accessories
Superb iV vs 2.0TSi pros and cons
But if the system should be sealed any fluid loss will degrade the performance it will just take longer! Like equating an engine that burns oil to a total loss system or a 2-stroke. It wasn't designed that way so it's wrong!
Estate Parcel Shelf
Mine seems to react differently in differing temps, like most of us, quicker when warmer.
Automatic gear shift handle
No worse than other cars does not indicate it is good just means others are worse! Maybe there is scope for differences in the specification or numerous vendors are making the part slightly differently, I don't know but as different people have different experience something's going wrong. I do not wear rings and find it has degraded as have the wheel centre caps.
Boot Accessories
Got the net set form new, along with the velcro dividers can be used t stop thing moving about, the boot is quite large after all. Can string it across and keep hat, coats just below the retractable cover. Could try these: https://www.skoda-parts.com/catalog/superb-3/spare-parts/accessories/glovebox-nets-luggage-compartment-covers-156.html
- 2.0 TSI vs 2.0 TDI
All of the above, still cannot get an answer about when misting becomes a leak!
