DEL80Y
Everything posted by DEL80Y
  1. @Derbyshirebod I just bought Haynes Pro as I have access to it in the garage I help out at But wanted a copy on my own laptop as most the work i do is at weekends Am going to install tomorrow and see how it runs Will give you a heads up if its good👍
  2. look here Here are the relays: headlight washer, fuel pump, sound signal, glass heater, etc. It is also possible to arrange individual fuses, for example the memory control unit for the position of the cushion and backrest.
  3. If you can replace it with a Dual mass The solid conversions I have done on taxis were not very good they just dont feel right £325 from ebay for full kit
  4. yeah they are "Pish Catchers"😉 Mines are perforated leather so it just drains through😆
  5. Has it not got a button with a P in the top right position Like picture
  6. Apologies was thinking of Park assist button
  7. Is the parking sensor button working?
  8. Yow will find the other doors to be ok as the drivers door is the one getting used most Mines was a taxi for 3 years and all other doors were ok which I was suprised at because they get opened more than my drivers door
  9. Just watched a video on Skoda Trailer Assist which uses the park assist to reverse your trailer Modern technology
  10. Also adjusts the ESP with TSA (Trailer Stability Assist)
  11. These Vice grips are great at holding piston rod and anything circular or 3 sides of a nut without damaging surface
  12. I have been using these below to good effect solder and heatshrink in one
  13. Even Shell themselves recommended 0w30 as their Premium for fuel economy and 5w30 as Standard This is for a CFFB engine though You can put you r Reg in and see what comes up Data sheet is below ECT.pdf
  14. It will retain the green skoda as standard It will work with your old maps But you should really update them Are you putting in a SSD
  15. https://www.amazon.co.uk/febi-bilstein-38713-thermostat-transmission/dp/B00DZM877I/ref=sr_1_3?crid=3KMU6LBFTKXSJ&keywords=dsg+thermostat&qid=1643913346&sprefix=dsg+thermo%2Caps%2C91&sr=8-3 And look on this site Autodoc at the 3rd listing down delivery is quite dear but if you order a full service kit its worth it
  16. They torque settings are for new bolts (which should be replaced but even the dealers dont) Dont use them on on old bolts or you will snap them as they are stretch bolts You can go tight then a weee bit more and all shall be good😉
  17. have you actually connected a trailer board to check if working while connected
  18. There are plenty of posts about this use the search button on the top right 👍
  19. Look at this post You will most likely need to change the main bulbs as they loose power over the years To check the self levelling you can get under the car and check that the level sensors are ok as they are prone to filing Also this post
  20. Check the drivers door loom in the rubber grommet This powers all the other 3 doors dont just look for broken insulation as i had 1 wire broken inside but looked perfect on the insulation So continuity from Multi plug to inside of door loom on each wire on drivers side
  21. I had a failure of drivers rear door not working and checked every wire in harness for earth and continuity The failure was on the drivers door wiring harness it has the master door control module in it that powers the other 3 doors Drove me crazy Also for wiring diagrams you can use Haynes Online for about £26
  22. UP TO + 200% As advertised on the pack😉
  23. Thats what i thought till i seen the pic
  24. Aliexpress for £45 but it looks like km instead of MPH
  25. I used ebay and sent them a pick of my locking wheel nut sent out the next day for £18 Much better option than trying to remove with hammering on sockets and the like
