DEL80Y
Everything posted by DEL80Y
  1. Thamks @pab567 πŸ‘ What model is currently in there Ive been away from them for too long 🀣
  2. Hi @pab567 My friend has just got a replacement Octavia as a taxi and cant connect to bluetooth I have tried to connect but not showing Skoda BT on any of my devices Would a firmware update help at all or what am I looking for pic below of unit and firmware Many Thanks DelπŸ‘
  3. Its completely unpractical for driving a car safely You check your mirrors before moving off Maybe its fitted on your past BMW but some BMW's also come with NO indicators🀣 And also no need for shoutingπŸ‘
  4. Don't think it can Why would you want this? If you parked and needed to reverse what would you do
  5. @CombatWombat I cant recommend Tayna enough for great prices and next day delivery for batteriesπŸ‘~ For the price and piece of mind your as well changing the other 3 glow plugs ....They will all be the same age
  6. Hi it will more than likely be where the wiring comes from bodywork to tailgate Its a common issue with the twin tailgate there is lot of posts about it read this oneπŸ‘ˆ
  7. Why not just change all the glow plugs with it having 148,000 miles on it Have you checked under fuse box Below link is for Octavia w link ios
  8. Plus one for the link above Fitted in mine and have been great
  9. @TasMan| Just bolted on side
  10. The sidewalls on the cross climates are really soft. Hence your steering A strut brace wont fix that
  11. Or take them off and retro fit Plain gas struts For Β£17
  12. For anybody else thinking of getting a scanner I can highly recommend Autel AP200 Its only Β£58.64 on Amazon the now
  13. Get the flexi section in exhaust checked for cracks Or a loose clamp Its basically positioned right underneath the front windscreen scuttle so any exhaust fumes escaping come right into the air intake of vehicle
  14. Align My Car use Hunter 4wheel Alignment Complete search system
  15. Why do you want stick on? Team Heko ones are good at their job
  16. My TeamHeko fit perfect on all four windows You do need to force fit them to get them in place Also the team heko can be polished out😁
  17. The Autel Ap200 is a cracking bit of kit for the money put it in Amazon and wait for the pride to fall to Β£58 (it often does) One time purchase gives you lifetime diagnostics for One manufacturer then each additional make is about Β£17
  18. Yes to both Support mode: allows you to keep the vehicle powered when changing the battery to keep the vehicle codes and settings.
  19. For home use there is nothing better than Autel AP200 available at Amazon for Β£58
  20. Just to be a pain Are you also flushing the ABS pump This doesnt get flushed with a standard flush | You need diagnostic equipment to get the pump to bleed itself I was amazed how dirty the fluid was coming out after doing the correct procedure
  21. How much did you pay for the lemforder bushes
