bigade1
Everything posted by bigade1
  1. @NZ100 The Skoda maps are are more or less a rebrand of the VW ( parent company ) maps and are usually put on the Skoda Update portal website a few months after they've appeared on the VW website. For instance, the current Skoda maps ( titled 2020/2021 ) were actually available from VW in November, 2019. I expect it will be sometime next year when Skoda will put up the latest version ( titled 2021 ) which were released last month on the VW website. If, like me, you want the latest map and can't be bothered to wait months for Skoda to upload it here's the direct download link from the VW website for the Europe 2021 map for the Amundsen MIB2 ( aka Discover Media ). Once downloaded It needs to be extracted using 7z compatible software ( I use Winrar myself ). then just place the entire " Maps " named folder onto your formatted Skoda sd card. The file size of the extracted folder is 14.4GB so it should just fit although I haven't tried it myself as I've recently upgraded to a 32GB sd card. https://navigation-maps.volkswagen.com/vw-maps/DiscoverMedia2_EU-AS_1520_V13.7z
  2. @LordRaiden Unfortunately it is a slightly complicated and time consuming process to add a specific poi. It can be done by editing the original database file using a poi editor before using the programme that converts all the complete files into the specific VW/Skoda format. Unfortunately I have to rely on the accuracy of any free database I can get hold of. Some are more accurate than others but aren't free or shared. Nevertheless, it is a bit unusual for you to hear an alert yet not see an accompanying icon. I've had a similar issue before and a hard reset of my infotainment unit resolved the issue. You could give that a try, it's pretty simple - you just press and keep holding the power button in to knock your infotainment system off and keep holding the power button pressed in until the display restarts. Takes about fifteen seconds.
  3. The only thing I would suggest is to completely unpair your phone and factory reset the carplay settings on your infotainment system and retry it. Make sure the phone is disconnected and do it the following way: Firstly on the iphone go to Settings - General - Carplay - Skoda ( or/and any other vehicles ) - Forget this car. Secondly, on your infotainment go to Menu - Settings - Scroll to Factory Reset - Scroll to Individual Factory Reset - Scroll to Mirrorlink and reset it. Then reconnect your device and try it. Remember to select yes if it gives you the option to use Carplay when iphone is locked. Might be worth a try. It could simply be a glitch in the settings.
  4. Step 1. Install the free VW Pre Compiled Database located on the download section of this site to your PC: https://free-speed-cam-updates.web2diz.net/ Step 2. Unzip/extract the files on your PC and copy the contents of the resulting folder onto a SD card. ( Important points to note: Only copy the contents of the main folder i.e. Do not copy the resulting extracted folder named Volkswagen PersonalPOI - just copy the contents that are displayed inside that folder which is a folder named PersonalPOI and a metainfo2.txt file. Delete the readme.txt file as well as that is unnecessary. Also further note that despite trying to use 2 different usb sticks unsuccessfully only an sd card would work for me. I used the sd card which contains my music files but remember to delete the copied files off afterwards as sometimes they may prevent your music from playing and they are no longer required as they have been copied to the internal memory of the Amundsen ). Step 3. Using the "manage memory option" of the nav settings upgrade the software. Step 4. In the "map" settings chose poi categories, scroll to the bottom and the newly added items should be displayed there. Tick these to activate them. Step 5. In the "nav announcement" settings of the nav settings make sure that there is a tick in the "My POI" item. This enables an audible speedcam alert. To sum up - it's pretty easy to do and it's free and there are monthly updates on the site. On the downside - I'm not sure how reliable and up to date the database is as I've already had to manually edit and remove an out of date camera from my location. IMO the audible alert is a bit feeble and can't be changed but it's better than nothing. I'm not too fussed on the camera icons either. I hope this post is of help to others and I would like to thank the contributors of the other threads regarding this topic on this forum from whom I have gained my insight. I have compiled my own version with my preferred choice of speedcam icons limited to UK fixed cameras and traffic light cameras using the VW database on the above site which I've attached below to share if anyone wants them. Remember to only copy the files as per the above instructions. My Uk Speedcams.zip
