vran22
Everything posted by vran22
  1. Hi, What is latest version for infotainment? I had updated to version: 2768, because of bug if you increase/decrese temperature and then change were air needs to blow it throw to main scree
  2. Just put lubricant where it fold on both sides..
  3. I used wurth silikon spray. Its okay from then.
  4. This version dont have leds inside..
  5. My Kodiaq 2025 sportline have travel assist. So if you have 2026 sportline you should also have it. You need to select in cruise travel assist and activate then control at that time car take control over speed and steering.
  6. Is this normal sound for Kodiaq 1.5TSI mHEV? While showing ti dealer they said its normal behaviour. But this sound is making while moving car forward or reverse od maneuring on parking. 20260307_124301_1.mp4
  7. I am not avoiding them. I already contacted my dealer. I have some opet topics with my car where dealer need to fix them in warranty and i have also pointed to them that i saw recall and we need to fix this with all open points.
  8. Picture of mine Kodiaq Sportline.
  9. It shows only that my VIN is effected. But dont know what have to be done. I already wrote to my dealer and waiting.
  10. For mine i see also other recall. I will check tomorrow with dealer what is about.
  11. With thoose errors i had to replace infotainment. No new software fixed issues. But they had to tried ti update to newer version before replacment in warranty.
  12. How do you mean now on second one? Was your car replaced? I have also strange brake on my mild hybrid and have to apologize to passengers as if i dont know how to brake.
  13. Hi, Also experiencing thoose: Main issues: • Assisted systems failures (Travel Assist, Lane Assist, Front Assist, ESC, etc.) – keeps coming back even after software updates, battery replacement, and rewiring • Sticky auto handbrake And also steering wheel shakes between 110 - 130.. They dont find issue. Its shaking on summer 20' and winter 17' wheels.
  14. I am having same issues on Kodiaq 2025.. My mechanic which is not allowed to touch car also immediatly said that brake discs are making strange noise while moving the car. Also when i check rear disc i see that it started making strange lines
  15. If it comes on when car is locked it must be issue with display, because turn on button and all is connected to display.. Did you try to clean surface when power on button is?
  16. Random black screens Locked car and infotainment was playing Draining battery Volume automatically goes to max I Have video all errors and send it to skoda dealer and they pushed to skoda to get new display. Not any version update fix this issue.
  17. On mine it did not solve issue.. Issue was solved when display was replaced in warranty. After replacement there were no more issue.
  18. Problem is if you dont use correct ET and specs as skoda requested for 17inch,18inc etc wheels.. If you use all correct there is no problem. I have 20inch for summer tyres and 17inch for winter tyres.
  19. Today i noticed that in dashboard there is some not nice line fitting. Is this only on mine? Or all Kodiaq have this failure.. Because now when i saw it i cannot unseen it :(
  20. I have done three time balancing wheels and it not fix issue..
  21. Did you fix issue with steering wheel?
  22. Its working compleatly normal for me (in Slovenia)
  23. Is anyone experiencing steering wheel vibration while driving between 100–130 km/h? The issue occurs on both the 20-inch summer wheels and the 17-inch winter wheels. The 20-inch wheels have been checked for balancing and everything is fine. On SKODA service says that its normal for vibration 🤦 for my point it cannot be normaln that steering wheel is shaking on 2 different wheels. I hope that i am not only one, because they said that they checked suspension and all is OK, but i also see that od higway car is getting pulled always to the right. Car is Kodiaq 1.5 TSI mHEV DSG 2025
  24. FL version, is having different software.. Not same as first edition of MK4 octavia.
  25. Hi, I have some issues on Kodiaq sportline. When i am driving it recognize speed limit for ex. 30km/h but when its over it dont read as end, but i am keep driving with 30km/h. When i was testing kodiaq selection it was working far better that on my sportline and i dont want to use ACC because its not reading end of signs. Also while checking selection it had speed sign on left side mine has on right side.
