Everything posted by Nab93
DPF Differential Pressure Sensor P2456
They get moved when taking the housing off for timing belt
Abit late to the party but it seems when a Campbeltown is changed they rmeovee the metal pipes and iv had gloss of power etc last few days and low and behold one of the dpf garages starlight away asked what I had done and the pipe was snapped off the sensorlucky i didn't burn my car most people dont check the sensor after a Campbelt replacement
- OIL LIGHTS COMES ON BUT I HAVE 5L OF OIL IN THE CAR
Diesel judder
2.0 tdi crlb engine and the battery is fairly new
Hi so recently I went for a oil service few days before I had put 1l of oil in as it came up as low oil so I got the service done 5l of oil all done and it took a fair few tries before the oil came up on the dip stick now 500 miles after the service light comes up and it shows oil low on the dipstick yet after putting 1l in no light so far and iv done about 400 miles so ov been told it could be the oil pump or oil pressure sensor has anyone had any of these problems or failures before?
Diesel judder
Hi I get a constant judder when I leave my car on but it's only just started
P2000 code skoda superb crlb 2.0l diesel
Hi guys so iv hd this comeup showing low threshold on the nox sensor now mines a 2016 crlb engine skoda superb mk3 with no adblue but with dpf I'm having high oil and fuel consumption and constant regens for the dpf im wondering if anyone can shed any light on this I will attach the most recent values and the codes I had done up
SKODA SUPERB MK3 2016 2.0L DIESEL OIL CONSUMPTION
So 1l per 1500 miles isn't too bad then ?
What type of oil or brand would you recommend atm I'm using 5 30 longline castrol which cost about £45 per 5l
Hi I put in a liter and I got to 3/4 on the oil dipstick when the light came onnit was on level with the low point of the dipstick and I had the service done with 5l and it was full on the dipstick iv got 205k on the car it's a 2 litre diesel
- NOX readings - do I replace sensor?
So for a update iv done 3356 miles since a full oil service done with new one oil filter and 5l of castrol oil now the check engine oil light has come on surely this isn't normal as like I said it has only started doing this for the past couple of months
It was okay before but recently saw that it's burning oil as before I could go 10k without any light or anything but last 3 months had the service done at every 7500 miles because it was low on the dip stick
P2000
I have the same problem can anyone help with this
Hi I have a skoda superb 2.0 diesel it has 205k miles and I'm a taxi driver recently it's started to drink oil every 3k miles the dip stick shows a quarter less i had a oil service done with genuine oil filter from tps and 5l of castrol oil there's no oil leak just burning it what can be the cause and also what could be the fix can a 5 40w oil do the job I use 5 30 atm
SKODA SUPERB 2016 TPMS FAULT
All the tyres are same size and pressure iv had a puncture today but it didn't throw up any loss of pressure just had that sorted will drive and see if it throws anything up I have reset the tpms in the multimedia aswell let's hope it's okay now No fault codes
Yh i keep getting error even though the pressures are okay
Still have problems with these damn tpms might change all 4 tyres to a single company and thread and see if that work
I have scanned it with a few different scanners and when the light goes off no error but normally the error alternates with all the tyres
How do I install these just put them in the valve and also what or how do I deactivate the current indirect system?
Keep getting the warning coming up and a new tyre was fitted Iv tried looking at the post and clicked on the links they don't work might be because the links are no longer there
Hi iv got a skoda superb 2016 uk model and after a puncture iv had a nightmare with my tpms keeps going off and keeps showing a tpms sensor fault even after reset and tire pressure check is there any way to deactivate it or install new sensors and it's the one attached to the abs sensor aswell any help would be great thanks
Skoda octavia mk3 excessive oil consumption after dpf removal
No
