SkodaKing
Everything posted by SkodaKing
  1. Hi all, My nearside rear light has a dimmer area than the rest of the C shape (the bottom section) I can see the lamp is on but dimmer than the rest. Is this a bulb replacement job or something to do with me activating the second rear fog light. The rear fog light works as it should, and when i activated it via OBD Eleven, i made sure all the lamps were set to 100% light output as per instructions. I'm not sure if this is something new or has happened since i activated the rear fog. I am slightly confused to which lamp it would be, is that one the w5w or the H21W ? Access looks tricky, there dosen't seem to be an opening flap within the boot to get inside? Thank you
  2. Stick your finger in and give it a wiggle. Mine was in there but i couldn't see it. I managed to persuade mine out without tools
  3. With a 2.0 diesel. Dang, i bet it's not even warm by the time you get to work! Good luck with the regens.
  4. I've finally ordered a black painted grill to replace my peeling plastidip one. £56 delivered is still too much but better with the 20% off
