Everything posted by Pixels
Front knocking sound but not around corners.
Thank you.. I have heard it could be them. still not had time to get it looked at. did you do the repair yourself or a garage?
So my 2009 superb has developed a knocking sound over bumps and uneven roads. now when I turn a corner left or right there is no sound when moving. just putting the question out there before I get it looked at. Could be top mount struts? droplinks? balljoints? any idea before I get it looked at when I’m free? thanks in advance.
Boot won’t open with fob or boot button.
Ahhhh I see…I did remove 2 metal pins the gas’s sections moves up a little bit but I still can’t get the black hooks out 😞
So I had a Quick Look… got into the boot via the back seats dead easy! so thanks for the info. so small boot opened fine..closed it and it works via the remote now. reversing lights and fog lights all working. very strange.. I’ve had a go to on the second part of the boot. Removed both bolts and now I’m trying to wiggle the black hook out of each side.. no luck yet 😞 Who repaired it and may I ask how much the repair? thanks
Hi and thank you peter. yes when I looked in the boot you can’t see the cut out, I guess it’s there if you look hard enough. how the good news you say is that the boot locks itself so I could still use the boot if I need to. so can I ask… what did you do to you’re wiring/boot in the end? cheers steve
Thank you so much. yes I believe that is the issue with the wires it’s a common fault on the superb! it’s just when I can get it open I will try have a go and fix it, the guide on here looks so in depth which is great. so how did you open the boot in the end? as I can’t get to the plastic shroud you see. thanks
Just been out to the car..not been moved for 2 days.. tried remote and the boot opened. strange. wonder if it’s not the wires and the micro switch
- Boot won’t open with fob or boot button.
Just been out to the car… nowhere for my key to go there is no slot which is worrying 😞- Boot won’t open with fob or boot button.
there is a fault in the central locking, you can open the boot lid as follows: – Fold the backrest of the rear seat forwards ⇒ page 76. – Guide the key into the slot in the trim panel as far as the stop ⇒ fig. 23. – You can unlock the lid by moving it in the direction of the arrow. – Open the boot lid/luggage compartment door. Emergency unlocking of the boot lid will give it a go now! thanks for the helpful advice 👍👍- Boot won’t open with fob or boot button.
Some codes I have found… 01506 - Right rear fog light bulb: Electrical error in circuit 01518 - Left back-up light bulb: Open circuit/short circuit to B+ 01519 - Right back-up light bulb: Open circuit/short circuit to B+ 02394 - Bulb for left front parking light: Open circuit/short circuit to B+ 00896 - Rear lid lock unit: Implausible signal 00950 - Central locking motor: Rear lid, UNLOCK: Short circuit to ground Reset- Boot won’t open with fob or boot button.
Hiya folks, Went to open my boot this morning and nothing,no sounds nowt! no im presuming it’s the twin door broken wires mission. i had no reverse/or rear fog lights pop up the other day which I was going to change today but then this… my question is how can I open the boot to attempt the repair as in the guide on the forum? is there an emergency pull/lever? I presume scanning the car won’t bring any faults for the wires too? Thanks in advance. ste- Skoda Superb Elegance umbrella
Wow!! If you are sure.. will do now! thanks so much!- Skoda Superb Elegance umbrella
Hi how much do you want for it? Beer tokens maybe? Ha- Skoda Superb Elegance umbrella
Hiya, do you wanna dm please about it. Cheers ste- Cleaning in Around the Badges
Bilt Hamber for me! sprayed onto a soft detailing brush and around the badges and agitate then rinse . Surfex HD- Another DSG issue
I would certainly get this checked out… this was the last Symptom I had on my car. in the end it was a new clutch and some solenoids changed and runs like a dream! I did have codes showing up when I scanned the car too.- Dsg issue/knocking
Hiya mate it was £1600 for me I’m afraid! but don’t forget I got a few other bits done also! cant fault their workmanship at all!! briliant job!- Dsg issue/knocking
So the issues was the clutch pack!! gearbox out all cleaned 2 new dsg filters ( internal ) and the outside one! new tranny oil! couple of solenoids changed! New clutch pack smooth as butter now!!- Noise outside car - videos attached with help needed please.
So…update.. car lost all gears on a drive! managed to get the car home after switching it on and off! ran a scan and it looks like it’s my mechatronics have gone! Need somebody to check the wiring etc but most likely will need a rebuild!- Noise outside car - videos attached with help needed please.
So I’m thinking next step is to get somebody to take the mechatronics off to get them checked over as it’s cheaper then taking the box off again and go from there!!- Noise outside car - videos attached with help needed please.
So car done!! dsg oil change and filter qkso the flywheel. but car still jumps etc!! Gutted must be somewhere in the gearbox! can anybody shed any light on this on the forum at all? thanks guys- Noise outside car - videos attached with help needed please.
So garage has got to my flywheel! video below Flywheel- Noise outside car - videos attached with help needed please.
Update… garage won’t do the job for what ever reason they said it could be in the gearbox? me personally still thinks it’s the flywheel. any recommendations for a garage on the Wirral or near by folks? thanks in advance ste- Noise outside car - videos attached with help needed please.
hi everybody… So car started making these noises on startup ( like rattles ) see videos Also when selecting drive or reverse ( see videos ) car would lurch through an odd gear etc…but when I would brake hard going down the gears it wouldn’t. i personally think it’s the flywheel as I’ve seen lots of videos on it online. now the garage called me today to say it’s most likely not the flywheel but can’t say for sure! And don’t want to strip the box to find out it isn’t! car is on 92k so I’m ringing with an answer in what to do tmorrow. me personally thinks it is the flywheel and then they open the box will see it is.. if it isn’t it’s plan B but as most of the labour is done that shouldn’t be a problem? Any thoughts people it’s kindly appreciated. I have Links to 2 videos! cheers Skoda superb flywheel sound <<< click Skoda superb flywheel sounds << click - Boot won’t open with fob or boot button.
