Johngerard
Everything posted by Johngerard
  1. You are averaging ~ 82 miles/day and 27 stop/starts, seems a extraordinary number of stop/starts, you must spend a lot of hours in the car. Ordinarily, that sort of mileage should have no problem keeping the battery at 85% SOC but couldn't see the SOC increasing by 10% in a short drive, my alternator only seems to charge at 1 or 2 amps after a initial burst of 15/20A for 20 seconds or so after starting, I put a 5A smart charger on my 2026 Polo a few months ago and even though the SOC was down around 70%, the measured charging rate fell to 0.15A so would need a mighty long night to get any sort of charge into the battery, it might charge initially at ~ 1A or so but as soon as the voltage rises to 14.4V or so it immediately sees the battery as being "full" and reduces the voltage to ~ 12.8V + 0.1shA, a CTEK might do better??.
  2. Have you got VCDS or similar?, if so, can you record readings like these: Battery charge status (85 %) Battery internal resistance (8.0 mOhm) Usable battery charge (31 Ah) Battery voltage at rest (12.6 V) Battery internal resistance (8.0 mOhm)
  3. Car has been driven ~ 5,200 mils in past 6 months, readings taken today, below. 59AH EFB Battery Original from Jan 2019 11:41:09 Mileage: 31,734 miles IDE00019 Voltage terminal 30 12.4 V IDE01836 Battery current -4.372 A IDE01837 Temperature of battery sensor 24 °C IDE01839 Battery charge status 85 % IDE01841 Battery internal resistance 8.0 mOhm IDE01842 Usable battery charge 31 Ah IDE01843 Battery voltage at rest 12.6 V IDE01948 Battery internal resistance not normed 6.8 mOhm IDE07681-MAS06086 Battery total charging throughput-Total re-charge 4345.8 Ah IDE07681-MAS06087 Battery total charging throughput-Entire energy throughput 4535.9 Ah
  4. Correct, Voltage while actually cranking.
  5. 14000Ah is ~ 15.3Ah/day, won't knock a measurable dent in the battery's SOC even if it fell by this amount. Some blame the frequent starting in Stop/Start for a lot of battery problems but if you think of it, each start only takes a fraction of a AH, if you run a VCDS log on battery current, you will catch most of it, mine, shows between 179A and 200A, a 2sec crank will still only consume, 200*2/3600, 0.11AH, your (hot) diesel might pull say a max of 350A for a (we'll give it) 3sec crank, 350*3/3600, 0.29AH, the glow plugs will consume possibly as much even though only on very briefly, if at all, with a hot engine. Even though we all profess to hate this smart charging and a max of 85% SOC etc, I would only worry if the battery is deep discharged and also, more worrying, its internal resistance, which is inevitable. If you accept that say 9.5V is the minimum starting voltage required and on a cold morning your diesel requires 350A and that the standstill battery voltage is 12.5V, voltage drop is 3.0V, internal resistance would have to be, (3/350)*1000, 8.57mOhms, so maybe set somewhere around there as your warning flag. If you forget all that jazz above, just do what I have done for over 60 years, get someone to crank the engine while you watch the voltage on your multimeter with the probes on the battery terminals. I think the majority of damage done to batteries is done in the parking lots where the cars can sit for months with the batteries in deep discharge. I have a April 2026 Polo and I reckon the battery has suffered this fate.
  6. This almost exactly 8 year old (Jan 2019) petrol Polo with a 59AH EFB battery is working perfectly, last set of readings (below) taken last June after 7.5 years, all short runs up to passing it on to our daughter in April, only ~ 40K KMs on it then, now > 50K Kms, wife always inhibits stop/start, I use it as I see fit. IDE01834 Battery voltage 12.193 V IDE01836 Battery current -4.950 A IDE01839 Battery charge status 77 % IDE01841 Battery internal resistance 7.6 mOhm IDE01842 Usable battery charge 28 Ah IDE01948 Battery internal resistance not normed 6.0 mOhm IDE07681-MAS06086 Battery total charging throughput-Total re-charge 3890.7 Ah IDE07681-MAS06087 Battery total charging throughput-Entire energy throughput 4091.0 Ah
  7. Is there still pressure present if you open the header tank cap say a hour or two or longer after engine shut off?.
  8. I have a 2019 65BHP MPI (normally aspirated) petrol Polo and a 2026 95BHP TSI, both with 5 speed manual gear boxes, neither have any problem on clutch release, the 2019 idles at ~ 760RPM but as soon as you press the clutch the revs increase to ~1100 and you can pull away without pressing the accelerator but it doesn't cause any problems if you do. The 2026 idles at ~ 1000RPM with no increase when you press the clutch but again no problem in pulling away without pressing the accelerator or if it is pressed, I had it back in the dealers as I thought the idling speed was and is unecessarily high but was told (presumably after check out) that this is normal operation?
  9. I dont know why a 84AH adaptation is being flagged, the only battery adaptations I can see which can be changed are below which shows a 59AH one. IDE03256-MAS06105 Battery adaptation-Rated battery capacity 59 Ah IDE03256-MAS06106 Battery adaptation-Battery technology EFB IDE03256-MAS06107 Battery adaptation-Battery manufacturer JCB IDE03256-MAS06108 Battery adaptation-Battery Serial Number 1111111111
  10. Can’t find any Battery aging related info for the Jan 2019 Polo but the Jan 2026 one showed, after 2 months, 92% charge related and 89% performance related, 79% SOC. The Jan 2019 averaged 9.52miles/day, 66.7 miles/week, to 25,395 miles for the first 7.4 years and since hand down just over 6 months ago, 28.75miles/day, 201.3miles/week, 5407 miles, to a total of 30,802 miles VCDS Data Today 14/10/2026 for the Jan 2019 Polo IDE01834 Battery voltage 12.172 V IDE01836 Battery current -4.958 A IDE01837 Temperature of battery sensor 26 °C IDE01839 Battery charge status 74 % IDE01841 Battery internal resistance 7.6 mOhm IDE01842 Usable battery charge 29 Ah IDE01843 Battery voltage at rest 12.4 V IDE01948 Battery internal resistance not normed 6.4 mOhm IDE07681-MAS06086 Battery total charging throughput-Total re-charge 4228.4 Ah IDE07681-MAS06087 Battery total charging throughput-Entire energy throughput 4413.9 Ah IDE03256-MAS06105 Battery adaptation-Rated battery capacity 59 Ah IDE03256-MAS06106 Battery adaptation-Battery technology EFB IDE03256-MAS06107 Battery adaptation-Battery manufacturer JCB IDE03256-MAS06108 Battery adaptation-Battery Serial Number 1111111111 IDE08347 adapted battery capacity 84 Ah Edit, Hope this 84AH adapted battery capacity doesn't mean that the BMS thinks its charging a 84AH battery?,
  11. The first battery scan on this car was only a few days after purchase, April 2026 and its internal resistance was even then 6.8mOhms, it is was 7.4mOhms on 7th Oct (2026), 6 months later. My almost 8 year old January 2019 Polo wasn't scanned until Sept 2021, (2yrs 8 months old) and its resistance was 6.6mOhms, it was 7.6mOhms in June 2026 (7 yrs 5 months old). Both have 59AH EFB Batteries.
  12. That's interesting, one might imagine that the 2,4, 6 or 8 amp settings are maximum settings, otherwise, if the charge rate (amps) is constant then the voltage must be changing, once my SOC reaches ~ 75% SOC then the charging rate is down to a measured 0.38A as the charger effectively goes to maintenence mode at around 12.7V and the charging rate will fall still lower as the SOC increases so would take days to reach 90% SOC. I would expect your charger to behave similar to mine, below, at least in auto recharge.
  13. How long do you leave the battery on charge at each 2 month charging interval?, does it display the charging voltage and if so do you leave it charging until the voltage falls to some known/recommended level?.
  14. My less than a year old battery (and car) would makes a very big meal of trying to reach 85% SOC (don't even mention 100%), you can see below that it took 7.5hrs (smart charging) to get a tiny increases in SOC by 2% and a usable battery charge increase of 1AH, the battery energy counter shows a increase of a average of 2.8A over 7.5hrs, 0.37A per hour. My M.meter, in series with the charger showed a charging rate of < 0.2A for the majority of the 7.5 hr charging period. Also, later, on a 25 minute non stop run under varying driving conditions, the DVM showed that the charging voltage never went higher than 13.4V even on overrun and spent most of its time charging at 12.8V. Maybe a "smarter" smart charger than mine would get the SOC up to 100% eventually, if so, I'd like to see it confirmed by someone with VCDS. MAS16744-IDE01836 12-volt battery-Battery current -8.825 A MAS16744-IDE01839 12-volt battery-Battery charge status 75 % MAS16744-IDE01841 12-volt battery-Battery internal resistance 7.4 mOhm MAS16744-IDE01842 12-volt battery-Usable battery charge 26 Ah MAS16744-MAS06086 12-volt battery-Total re-charge 592.4 Ah MAS16744-MAS06087 12-volt battery-Entire energy throughput 598.1 Ah MAS16745-IDE01843 Quiescent current management-Battery voltage at rest 12.5 V After a further 7.5 hrs charging at 12.7, occasionally 13.4V. Charger is a Ultimate Speed ULGD 5.0 C1, (a 5.0A charger) MAS16744-IDE01836 12-volt battery-Battery current -6.729 A MAS16744-IDE01839 12-volt battery-Battery charge status 77 % MAS16744-IDE01841 12-volt battery-Battery internal resistance 7.4 mOhm MAS16744-IDE01842 12-volt battery-Usable battery charge 27 Ah MAS16744-MAS06086 12-volt battery-Total re-charge 594.3 Ah MAS16744-MAS06087 12-volt battery-Entire energy throughput 599.0 Ah MAS16745-IDE01843 Quiescent current management-Battery voltage at rest 12.5 V
  15. After exactly 2hrs (5A charger) the charging went from initially 13.2V to a max of 14.4V before reducing to 13.2V. SOC went from 53% to 77% Usable Battery Charge 16A to 27A Voltage at Rest 12.1V to 12.5V.
  16. Just noticed (Jan 2026 ) car charging at a constant 14.4V ish over the past few days, this car is only averaging ~ 7 miles/day but stop/start still operating perfectly at 53% SOC, will stick my smart (max) 5A charger on it over the next few nights and see can I restore it to around 80% SOC. 12:38:49 Jan 2026 Polo 95BHP TSI 2638kms,1639miles. Engine Idling for ~ 5 minutes. Think battery is a 59AH EFB. IDE00019 Voltage terminal 30 14.4 V MAS16744-IDE01836 12-volt battery-Battery current 24.612 A MAS16744-IDE01837 12-volt battery-Temperature of battery sensor 28 °C MAS16744-IDE01839 12-volt battery-Battery charge status 53 % MAS16744-IDE01841 12-volt battery-Battery internal resistance 7.6 mOhm MAS16744-IDE01842 12-volt battery-Usable battery charge 16 Ah MAS16744-MAS06086 12-volt battery-Total re-charge 569.2 Ah MAS16744-MAS06087 12-volt battery-Entire energy throughput 578.1 Ah MAS16744-MAS22232 12-volt battery-Battery aging: charge-related 88 % MAS16745-IDE01843 Quiescent current management-Battery voltage at rest 12.1 V IDE02756 Number of manual engine starts 936 IDE02757 Number of automatic engine starts 422
  17. I must have a look sometime to see if VCDS records the total engine starts. 24500 starts at say ~ 250A per 2sec (max)cranktime = 3406AH, if your figure refers to 14500AH each for battery truput and charging then ~ 11094AH used during ASS stopped time, ~ 0.45AH per stopped time??.
  18. Is that using VCDS??, what is your total mileage?.
  19. Trying to get the SOC back up by driving the car, especially with the present smart charging is not a great idea IMO and just a waste of fuel The family, Jan 2026 Polo,only seems to keep the SOC around 72/74% and a round trip last May dropping someone off at the Airport bears out the very low charging rates. The average charging ignoring engine off time and starting load was ~ 3.9A at 13.51V and, even after 23 miles the charging rate was less than 4A on overrun at 14.8V (SOC still only 72%). However, I will let it soldier on, the other 7.5 year Polo now passed down the line previously operated almost the same as this one and if I can get 8+ years out of the battery in both I will be happy enough I think, stop/start always works when requested so perhaps running at ~ 70% SOC isn't that such of a disaster after all?. LOG-261C10532-logged Airport Battery Data2 74%.xlsx
  20. SOC stands for State of Charge. Also, If ASS is not available when it should be then the symbol will still display but with a line through it.
  21. Suggest buying a DVM (digital Volt Meter) and plugging it into the cabin power point, permanently if not being used for anything else, and monitoring the voltage while driving normally, coasting etc. If the battery SOC is up around 80% then the DVV will show 14.5/14.8V on overrun and ~ 13.0/13.6V with accelerator pressed, if the SOC is down around 75% then its more than likely that the charging rate is 14.5/14.8V under all driving conditions. My over 7.5 year old Polo petrol 65BHP (Original) battery SOC has often been down around 75% but stop/start never failed to operate any time I care to use it. The max SOC is 85%. VCDS 10Friday,05,June,2026,10:45:58:555 42,715 kms/26,542miles. IDE01834 Battery voltage 12.193 V IDE01836 Battery current -4.950 A IDE01839 Battery charge status 77 % IDE01841 Battery internal resistance 7.6 mOhm IDE01842 Usable battery charge 28 Ah IDE01948 Battery internal resistance not normed 6.0 mOhm IDE07681-MAS06086 Battery total charging throughput-Total re-charge 3890.7 Ah IDE07681-MAS06087 Battery total charging throughput-Entire energy throughput 4091.0 Ah Battery Capacity 59AH.
  22. Its amazing how sensitive some of these engines seem to be when changing from 95 octane to 98 octane apparently cures the problem, mind you, in Spain there are at least 3 different choices of petrol, around here, its practically all E10 (95 octane) and you will have to travel to get E5.
  23. Under no circumstances whatsoever should 0.37kgs of sediment or whatever you wish to call it build up in 3 years and 23K miles, I have had 3 different family VWs, each well over 20 years old when scrapped and never had any problem like that, that canister is supposed to trap vapours, can only imagine that overfilling the tank at every refill might cause this in such a short period, it would be interesting though to see if all all new canisters are of equal weight.
  24. There might be another one in the door pocket.....His & Hers then?.
  25. I used to clean a 2005 Polo throttle body but I did it in situ, remove air cleaner, switch on ignition and put a "brick" on the accelerator, this will/should open the throttle valve fully to allow gentle cleaning of most of the throttle body, the revs used be on the high side after the clean for a few miles of driving but used to settle back down to normal. I have VCDS but never used it after cleaning. Your 2004 Fabia may have still had a cable operated throttle valve but the idling is/was still done electronically, the motor on these used to fail occasionally, I replaced them on a few friends 2000 Boras with used ones, again (and I didn't have VCDS then), idling speed would normalize after a few miles. Also, as suggested above......"check the brake servo vacuum hose for splits or cracks at the junctions of the hard plastic sections"
