Everything posted by Binx1310
Seat memory height problem
You might not have driving profiles. Have a look at: Car Setup Seats Vehicle key activated It’s a known “feature” that the seats don’t like being saved at the top or bottom end of extremes of settings. If you can store and recall memories then it’s not a software issue with the memory module.
I prefer the look of the white lights than the yellower ones. I’ve coded them to be on with full beam only. And they come on for corner lights. Throw out a nice spread of white light. Shouldn’t annoy or dazzle anyone.
No that’s what I thought. Hence the £7 white only LEDs!
White isn’t so good for fog. You can get ones that switch between white and yellow so you get best of both worlds but they’re much more expensive. Might be a future upgrade if I find the white to be problematic for the few foggy days we have. https://autobeam.co.uk/collections/switchback-fog/products/led-h8-switchback-fog-unit
Not sure as I don’t have it. @tombee ?
Turn off personalisation so it’s not saved to the key. It doesn’t like being at the extreme of adjustment so moves every time it repositions when you unlock with the key. @tombee had the opposite problem as he likes it all the way down.
Superb Mk3 Estate 190PS TDI DSG MY2015 SE L Executive - Moon White
- What have you done to your Superb III today?
slightly regretting not saving up a bit more and getting a high spec petrol particularly to do some of the performance (and exhaust note) modifications, but then I look at the MPG and the fact it accelerates plenty fast enough for me and im a bit more content- What have you done to your Superb III today?
They are all the same fitment. "The primary differences are wattage and brightness: H8 is 35W (fog lights), H11 is 55W (low beams), and H9 is 65W (high beams)" according to google.- What have you done to your Superb III today?
very white bulbs arent as good as fog lights compared to the more yellow colour. I have got some before pictures I took last night, will get some more with the new bulbs tonight.- What have you done to your Superb III today?
I just went for cheap bulbs from AliExpress. https://a.aliexpress.com/_ExCMD4y Fitting is easy. Remove adjacent trim, undo two torx screw then whole unit comes out. Undo plug and twist out bulb. Then the reverse to install.- What have you done to your Superb III today?
fitted the LED fog light bulbs this morning. No errors or flickers. Really pleased with the look. Will take some pics in the dark tonight Can you guess which one has been changed so far?- Seat adjustment, resets when getting in
awesome. It suddenly occurred to me this morning that if you had personalisation, everytime you unlock the car it automatically moves the seat to your settings. If it doesn’t like the extreme it means it’s moving that 1cm away from what you want. Without personalisation it doesn’t try to move each time so therefore stays in your position. If you wife does then program her own setting onto position 2 you will just have to push 1 for your setting and then the 1cm extra. But it should then stay at that until she uses it again.- Seat adjustment, resets when getting in
I had a thought on this, this morning. Have you got the setting saved to the key? I wonder if you save the position on the button, but don't link it to the key, whether it will stay where you want it to be, because everytime you unlock with the key it is repositioning. And then on the occassion your wife drives it, if she pushes the memory button for her setting with the door open before getting in, it will move to her position with one press. When you go to get in after, do the same, and you may need to push the button for that last 1cm that time, but for the majority of the time if its just you driving it stays where you want it to be.- Rough idle in eco mode
- Retrofit Aux Heater
Have a read through of this thread. Includes adding aux heater to rhd, amongst many many other things.- What have you done to your Superb III today?
I did it manly to protect glasses. But as it’s returned up the front edge too it should prevent rattles. Mine is a diesel so everything vibrates and rattles at certain rpm’s. I just turn the music louder!- Skoda Sportline Exhaust
You could just mount tip over the end of the pipe and not feed it in directly but not sure if it would pass MOT like that as I think it would mean exhaust gases aren’t coming out of the intended place I.e the very top Of exhaust.- Superb Mk3 Estate 190PS TDI DSG MY2015 SE L Executive - Moon White
Inspired by a very very minor part of the epic @ApertureS thread, I have installed self adhesive felt inside the sunglasses holder. I was hoping for black or light grey but they only have Red, Pink or white on the shelf, so went with the white. Doesnt look too bad and is nice and smooth for my sunglasses! Felt was from Hobbycraft: https://www.hobbycraft.co.uk/white-self-adhesive-felt-sheet-a4/5728371002.html LED fog lights arrived today but I'm not sure when I will get an opportunity to install them. LED indicator bulbs have arrived but the reversing bulbs were the wrong ones, so waiting on delivery of those.- What have you done to your Superb III today?
Inspired by a very very minor part of the epic @ApertureS thread, I have installed self adhesive felt inside the sunglasses holder. I was hoping for black or light grey but they only have Red, Pink or white on the shelf, so went with the white. Doesnt look too bad and is nice and smooth for my sunglasses! Felt was from Hobbycraft: https://www.hobbycraft.co.uk/white-self-adhesive-felt-sheet-a4/5728371002.html- Skoda Sportline Exhaust
A decent exhaust shop could make up an adaptor from that oval to the round of the tailpipe. The real issue might be how much room there is for it. How far under the car is the first silencer?- Seat adjustment, resets when getting in
Point taken. I’m obviously too short!- Seat adjustment, resets when getting in
does the 1cm make that much difference? - What have you done to your Superb III today?
