Binx1310
Everything posted by Binx1310
  1. Yes. There is even cheaper Chinese copy but I’m not sure. I can live without seat memory. Was hoping it was an easy/cheap fix!
  2. Ah it does. It says: Car Scanner ELM OBD2 Version: 1.121.0/1.121.0/iOS DTC report Connection profile: Skoda MQB, PQ26: Diesel DPF var.1 [EA288]Date: 2/21/2026 10:16:27 PM VIN: xxxxxxx ============================ OBD-II No DTC found. ============================ 36. Driver seat adjustment36. Driver seat adjustment DTCs: 3 ---------------------------- 9654868 [0x935254] Archive (inactive) B135254: Lumbar support fore/aft adjustment motor, No basic setting lumbar_support_longitudinal_adjustment_motor_no_basic_setting Status bits: 1 Priority: 4 Frequency: 1 Unlearning index: 172 Odometer: 198818 km Date, time: 2025.11.27 21:34:06 Status: Confirmed ---------------------------- 9654612 [0x935154] Archive (inactive) B135154: Lumbar support height adjustment motor, No basic setting lumbar_support_height_adjustment_motor_no_basic_setting Status bits: 1 Priority: 4 Frequency: 1 Unlearning index: 172 Odometer: 198818 km Date, time: 2025.11.27 21:34:07 Status: Confirmed ---------------------------- 10489856 [0xA01000] Archive (inactive) B2F0100: Development code 1 positioning_error Status bits: 1 Priority: 7 Frequency: 1 Unlearning index: 172 Odometer: 198818 km Date, time: 2025.11.27 21:34:07 Status: Confirmed
  3. I don’t know. I only have carscanner not vcds and it doesn’t show faults on the set module I don’t think. I’ll have another look. Mirror may have worked previously I just didn’t know to leave the knob on L, but turning off the lumbar support coding worked in allowing some bongs
  4. Hi. I hope you can help me with this. I did the long coding as suggested here using carscanner. I got 2 bongs. Lovely. I can select seat adjustment to key in the menu. Lovely. But it won’t save seat position. I’ve done the all the way forwards, all the way back etc. (and cracked my visor mirror in the process) Still no joy. The mirror setting for reversing works. If I push and hold number 1 the mirror moves to a new position. But the seat doesn’t. So there is some memory stored. It’s almost as if the set button doesn’t work. I fear it may need a new module but that’s £220 plus coding! Any other thoughts?
  5. It seems the MIB2 unit doesn’t output phantom power I think as the OEM has an amplifier. So for £10 thought I would give this a go to see if it can make the aftermarket radio work as it requires phantom power. https://amzn.eu/d/0hEhdrry I will tap the power from my switched power tap I use for the dashcam.
  6. I think there’s some tutorials on you tube. Otherwise would be google search or forums I would guess.
  7. MIB2 high https://github.com/jilleb/mib2-toolbox MIB2 standard https://github.com/olli991/mib-std2-pq-zr-toolbox Pretty good instructions along with the files to download. I only want it to change the button assignment but I have seen posts of people use it to change the image of the car in the car menu to match theirs
  8. Thanks. I suspected that was the case. I had seen that it was possible to map the buttons for mib 2 standard but couldn’t find it for high. Oh well. I’ll just have to stick to what im doing now.
  9. has anyone here played with MIB toolkit much? I’m keen to reprogram the “Traffic” button to be “APP” and this seems possible with MIB toolkit. My unit is the MIB 2 Harman and from what I can work out that’s not supported by the toolkit but I’m not certain. I’m not sure if the inconvenience of the menu or using the voice button to prompt Siri and then press the be button is worth the risk of bricking the radio.
  10. Also. You have no idea how much this annoyed me. Not any more!
  11. Installed wireless charger and AC vent covers and discovered rear AC vent adjusters broken. Also continued playing about with a few bits of coding with CarScanner -Undertaking prevention turned off -Auto Unlocking of doors when shifting to P enabled -Throttle pedal algorithm changed to "Direct" - I assume this is similar setting to changing it to "Audi" with VCDS. This has made such a difference to the driving feel of the car. Now feels like the accelerator pedal is actually attached to the engine! Full details and pics on the project thread:
  12. So today after much deliberation over how/where to install the wireless magsafe charger I have settled on a location and wiring solution. My phone was just a bit too big to fit in front of the gearstick in the cubby, and it wouldnt have sat flat on the bottom so I would have had to build up the underside of the wireless charger to make it fit. I did consider putting it inside the arm rest but it just felt a bit too awkward getting it in and out. In the end I settled on putting it on the left side of the centre console. 99% of the time I am in the car on my own, and even with a passenger in situ it isnt really in the way. Its nice and easy to put down and pick up from the driving position and you can move the passenger seat all the way forwards without it fouling the charger, although you wouldnt be able to have a phone on it at the time (and these cars are so huge why would you want to move the front seat all the way forwards anyway! I wasn't overly keen on chopping in to the OEM wiring to connect it, so I opted for the same solution as I used to get the charging cable into the armrest. Slimline USB adaptor in the 12v socket and flat 90 degree USB C to USB C cable. It routed nicely to the side trim of the centre console and emerges just below the charger for a neat finish. I had to trim the edge of the cubby under the 12v socket ever so slightly but its well hidden by the USB/12v panel. and the cubby cover can still close over the top of it for a nice clean look. All in all really pleased with the solution, and its easily removable/upgradeable, shouldn't generate any heat problems being out in the open, and I still have the wire in the centre console if I want to plug it in rather than charge wirelessly at all. I shall ask my wife nicely to borrow her phone later to take a picture of my phone in situ. Wireless charger https://www.amazon.co.uk/dp/B0DL6ZBC3F USB adaptor https://www.aliexpress.com/item/1005007174454597.html USB Cable https://www.aliexpress.com/item/1005009553372728.html I also installed the underseat vent grills to prevent items getting lost into the ventilation. A nice easy fit and suits the job perfectly. https://www.aliexpress.com/item/32904629443.html Whilst in the back fitting these I noticed the rear AC vents had lost the clip part from the adjusters. I will go fishing for the bits inside the ducting, if I can't find them I will order the Mercedes replacement parts as recommended by @zedman https://www.aliexpress.com/item/1005005874666828.html Also continued playing about with a few bits of coding with CarScanner -Undertaking prevention turned off -Unlocking of doors when shifting to P -Throttle pedal algorithm changed to "Direct" - I assume this is similar setting to changing it to "Audi" with VCDS. This has made such a difference to the driving feel of the car. Now feels like the accelerator pedal is actually attached to the engine!
  13. 100% I haven't had a car that I've worked on myself for 6 years or so, and to have AliExpress and other sources of cheap OEM copy parts is an absolute game changer.
  14. Part 3 - Coming soon. All the below currently awaiting delivery. Wireless charging pad - Keen to try to add a magsafe wireless pad to the slot next to the USB port. Hopefully won't generate too much heat. https://www.amazon.co.uk/dp/B0DL6ZBC3F Planning on supplying it using this https://www.amazon.co.uk/dp/B0FP5FBTB7 connected to the back of the front 12v socket via a fused line. Parts should be coming today and will look to install tomorrow/this weekend. Will add some photos once I do. Stainless pedals and footrest - I had been searching AliExpress for some RHD pedals for some time. Thanks to @JR RS for pointing me in the right direction. https://www.aliexpress.com/item/1005005130384423.html?spm=a2g0o.order_list.order_list_main.23.23f6180240IXhV LED rear indicator bulbs https://www.aliexpress.com/item/1005005102438682.html LED reversing bulbs https://www.aliexpress.com/item/1005006067983978.html LED fog light bulbs https://www.aliexpress.com/item/1005010051387090.html
  15. Part 2 The car was originally supplied with a pump and goo repair kit. The goo was now out of date and I travel quite a bit for work so it makes me nervous not having a spare. I was keen on having a spare that was a close as possible to the rolling diameter of the existing wheels so it could be used without any speed or time restrictions, whilst also fitting under the boot floor. Following the advice shared from @Carlston on a few posts, I chose a 6Jx16 steel wheel with 215/60 R16 tyre which resulted in a less than 0.5% difference in rolling diameter. It fits in the wheel well really well, and fits perfectly on the car. Unfortunately the jack doesn't quite fit inside the wheel, but does fit in the side storage section. Spare wheel - https://www.ebay.co.uk/itm/364188522719 Breaker bar and socket - https://www.ebay.co.uk/itm/403816977765 Jack - https://www.amazon.co.uk/dp/B08FTH8N1T Spare wheel fixing screw - https://www.amazon.co.uk/dp/B0FP91RLPK Gear gator leather - Thanks to @tombee for his cast off leather gaitor when he upgraded to alcantara. It was from a Mk7 golf so needed some fettling and gluing but is a great improvement on the previous which was damaged and cracked in a few places. Vanity mirror lights - These were the only interior lights that weren't white LED. These ones from AliExpress are VERY bright and they may well prove to be too bright. I have kept the old bulb holders and may change them for standard fit LED bulbs rather than whole units. https://www.aliexpress.com/item/1005006755056171.html Parking brake switch - The OEM one the car came with had a chip in the chrome. 2nd hand spares were a similar price to AliExpress new, so I went with that. Perfect fit and a nice tidy up job. https://www.aliexpress.com/item/1005006998838766.html Rubber boot mat - My daughter is the goalkeeper for a local team. With that comes A LOT of mud. So I wanted something washable to line the boot. I went for the cheapest one I could find on Amazon and its proven to be a really nice fit. https://www.amazon.co.uk/dp/B088FVXYC2 DAB aerial - This one is a bit of a pain. I dont use the radio much, but the DAB signal is terrible in this car. I know the local signal is ok as its fine in our Kodiaq. Following advice from @Cairus I bought the following, and unfortunately it hasn't improved things. I did notice the plug itself was loose when changing the connector so suspect there is something damaged inside the main unit. At some point I will take it out and take the case off and have a look inside. https://www.amazon.co.uk/dp/B09ZPHHBNL AC vent covers - Advice from @travs to install these so kids detritus doesnt get lost into the AC vents. Now installed on this car and our Kodiaq. https://www.aliexpress.com/item/32904629443.html Clear plastic polish - The dash had a strange cloudy mark on it. From a tip from @Lee01 I tried the Meguiars Plast-RX and it worked wonders. Highly recommended for any clear plastic issues. OBD reader - I had a cheap OBD reader using CarScanner app, and was keen to experiment with some coding which the cheap dongle couldnt support. Based on the advice on the CarScanner website I chose the following. It is brilliant and works seemelessly. Its a really cost effective way to achieve the basic coding tweaks. Allegedly can also do long coding but I haven't ventured into that realm just yet. https://www.amazon.co.uk/dp/B06XGB4873 So far I have succesfully coded the following: Teardrop wipe front and rear - I have noticed this only works in the dry, as any amount of moisture on the screen and the auto wiping seems to take over. Curtosey indicator blinks from 3 to 5 Refuel level in Maxidot Fog lights on with full beam and mainbeam flash Blower power level showing in auto mode Changed headlight washer interval to 20 from 10 Changed autohold and hill hold to "early". This has made a significant difference to the car, it was quite jerky when coming off autohold and its now silky smooth. Wipers return to park when ignition turned off
  16. When I got the car back in November I was trading in a 21 Plate Fabia wanting an upgrade in terms of spec and size. I had previously had a 150PS TDI Superb 3 so knew thats what I wanted again. It had 123,000 miles and a few age related tatty marks and body marks. Most of the interior lights had been changed to White LED and it had some hideous quilted floor mats. The wheels had been refurbed in dark metallic grey and the calipers painted red. The reversing sensors were not working and the dealer fixed those before collection. It also had a glow plug fail which was replaced under warranty. As the list on my phone of minor changes is getting longer and longer I thought its about time I started a thread on the projects page. Nothing major, just tarting up and simple improvements. Most of these things are well documented here already by others but I'll provide links for those wanting to do similar changes. Gear selector switch - To fix intermittent "Return to workshop" error www.aliexpress.com/item/1005009808126126.html Number plates and frameless holders - Existing ones were faded and I hate screws through number plates https://mr-plates.co.uk/ Floor Mats - To replace the hideous quilted ones it came with https://www.amazon.co.uk/dp/B0FP5WPKVL Bumper protector trim - To cover some scratches and cracks on top of the bumper, and to protect from future ones https://www.ebay.co.uk/itm/374297644198 Stop start memory module - I've never had an issue with start/stop previously but on this DSG version it seemed to be quite agressive and stop the car too much for my liking. https://www.aliexpress.com/item/1005009424334938.html DSG lever top chrome - Original had chips in the chrome https://www.aliexpress.com/item/1005008748111292.html Reversing camera - Not something I particularly needed but for the price and ease of install felt like a nice addition https://www.aliexpress.com/item/4000230897829.html Front speakers and fittings - Originals had the issue with the magnets falling off and there was a severe lack of bass! Speakers - https://incartec.co.uk/product/pioneer-ts-g1710f-6-5-g-series-dual-cone-car-speakers-280w Fitting kit - https://caraudiocentre.co.uk/products/blam-sfku-sko01-165-front-or-rear-door-speaker-upgrade-fitting-kit-for-skoda-165mm-6-5-inch Foam rings - https://www.aliexpress.com/item/1005007457007431.html (To direct sound through door card and mimic the OEM speakers) Superb puddle lights - Because why not! https://www.aliexpress.com/item/1005009118825485.html LED tailgate lights - It already had LED bulbs in the original holders but these are significantly brighter and really light up the whole boot area. https://www.aliexpress.com/item/1005006419747360.html While fitting the rear camera I managed to break a wire for the interior lights where it goes through the rubber gaiter to the tailgate, and everytime the tailgate opened to full height all the interior lights would flicker and go off. So, the next task was to replace this cable. I pulled in a new 22AWG cable and connected it into the wire close to the plug within the tailgate, and the other end at the plug just below the D pillar. Lights all working again and no further issues. Washer bottle funnel lid - I really like the one we have on our Kodiaq so this is a nice addition https://www.aliexpress.com/item/1005009730287325.html Boot torch batteries - Original removable torch was working in when in situ but didnt work when out of the car. Pleased to find they are 3x standard AAA rechargeable batteries. https://www.amazon.co.uk/dp/B00HZV9XKU Wireless CarPlay adaptor - I love the wireless carplay in our Kodiaq. Its so handy when jumping in the car quickly and not needing to plug the cable in. I was sceptical of such a cheap unit but I have to say it has been flawless. A slight lag between changes on the screen and changes in audio, but no worse lag than the OEM wireless in the Kodiaq. It is also small enough to allow the cover to be closed with it in situ. https://www.aliexpress.com/item/1005010493905846.html Route usb from rear charging port to armrest - as the front port is occupied with the wireless dongle, and to have the wire coming out in the armrest and allows the rear ashtray to be closed with it in situ - Based on the solution by @JR RS Slimline 12v to USB adaptor - https://www.aliexpress.com/item/1005007463964127.html DO NOT USE THESE ONES - It interrupts the DAB, see lower down the thread for replacements. 90 degree USB C to Lightning flat cable - https://www.aliexpress.com/item/1005009346861759.html (I also bought the USB C version in anticipation of the next phone upgrade being USB C not lightning) Parking ticket clip - Its amazing how I didn't notice this was missing until I went to put a parking ticket in it. Having had Skodas for the last 6 years it was such a natural thing to stick the ticket into it. Had to go OEM for this one. I am sure I could have got it cheaper from a local dealer, but for the convenience I ordered from Skoda Parts. https://www.skoda-parts.com/spare-part/3v0867333-parking-ticket-holder-skoda-15521.html Wheel nut caps - There were none on the car when I got it and they just looked a bit shabby. I haven't fitted these yet as the ones for the locking bolt are a bit tight and need the ridges sanding off from the inside. https://www.aliexpress.com/item/1005007215903363.html Mud flaps - UK countryside roads make for a very dirty car and I feel they save the sills from a lot of grime. These ones are significantly cheaper than OEM and not a perfect fit, but good enough. https://www.aliexpress.com/item/1005001393849257.html
  17. Ah ok. Hopefully they can fix under warranty. I suspect it may be an aftermarket camera and if so may not be covered. There are some very good cheap aftermarket cameras which are quite easy to fit so if they won’t replace it there are options. Some good guides on here of how to fit.
  18. Did you hear back from the dealer on this at all?
  19. Definitely agree. Having had a new car under warranty for the last 4 years, I had forgotten how much fun fixing up and self maintaining older cars was! Parts are so cheap and readily available now. Even through major outlets. Euro car parts used to have 2 or 3 choices max. Now for brakes for example there’s 6 different options. And I’m certain expensive doesn’t equal better! And having aliexpress for small trim parts and pattern OEM parts is game changing too!
  20. Another job done on the interior repairs. Replacing the hand brake switch which had a chip in the chrome. £30 from AliExpress and a 5 min task to swap it. Also realise how shiny the old one had got from use. Before After Just waiting on deliver of LED tail light and fog light bulbs, and pedal covers then I’m pretty much done for now…
  21. Not at all but it’s a defence!
  22. The only other thing I noticed that I’ve just remembered was one of the wheel bolts was very tight. I had to hang on the end of a 2ft breaker to undo it. I wonder if one is much tighter than the others it pulls the disc out of alignment. Everything is such solid metal I can’t believe that it would. I’ll get them to check the runout on the discs when it gets serviced in case there’s something in it.
  23. Haha. Luckily for me there are as many parcels arriving from shein for her as there are from AliExpress for me!
  24. Installed white LED vanity mirror lights. Now all interior lights are white LED. Except the removable torch but that requires SMD soldering new LEDs onto the board which is beyond my capabilities. The lights are VERY bright and may well prove to be too bright. But they hardly ever get used. I just didn’t like how yellow they were on the odd occasion that they did get used! A few more bits waiting to be delivered then I’m done…..
