Everything posted by SkOmk4
New software available version 1989
Well, in fact there's a catch here... the Seat/Cupra never released a 1985 version for MiB3 as Skoda did. Instead, they released version 1988 with several months delay compared to the 1985 version of Skoda. This is making some users think that the "delayed" 1988 version of Seat/Cupra, is actually a combo of fixes/improvements included in 1985 and 1989 by Skoda. Whether we like it or not, all brands of VAG will run a (very) similar software on their cars (using the same hardware) - it's just the release dates and the UI that are different. That's why bugs and errors are the same over the entire group for cars sharing the same systems.
annoying message on startup
Do you have something newer than version 15.2.653614 (Sept. 16th on my phone)?
You can try at: [email protected] and / or [email protected] (I can't see where you're from)
You should be thankful that it threw out an Error, and you didn't brick your system. The software on the facelift models (Octavia, Golf, Leon/Formentor) has nothing to do with the pre-facelift, since the hardware is different. Check you software information - you should have a version close to 2650. Do NOT try to install an inferior number version! If you have annoying bugs on your system, try to discuss with the dealership. I've heard rumors about a major update for MiB4, but it's not yet released OTA.
I also think the problem is most likely to be AA. Those encountering the above mentioned issue - did you try to Clear Cache and Data in AA on your phone? (I'm not saying it will definitely help, but it's worth a try)
- Battery life on pre facelift cars
New settings are now available for your user account. Would you like to apply them?
I have the same "problem" on my Formentor facelift (same HW and basically the same software behind the UI). On average it "offers" the new settings about once a week; and yes, if you ignore it, it will keep popping up at each new start of the car. In my case it only changes the color of the ambient lights and the setting of the headlights sensitivity to "Medium" (I prefer to keep it on "Late"). It seems it imports the set of settings from the server; what I can't understand is why the car doesn't update the modified settings on the server. Once I change whatever I want to change, I go to User, select mine and tap "sync settings" - that should upload the new set to the server... I had a trip to the dealership (for a different issue) and also told them about this problem. They said they never heard anything similar (sure - we've all heard this argument before), they have no idea how to tackle it and they also concluded: "But it doesn't seem to be such an important problem - just ignore it and keep driving!" 🙄
2021 iV vRS 12 volt disconnect - Should i heed the warning or be brave?
Have a look at the attached Workshop Manual pages (I had to cut the original file, since it has ~70MB size and the limit here is 10MB). Seeing the procedure in the Manual, it seems to me there's no need to disconnect the HV system, but I'm no specialist. I'm guessing that when the 12V is disconnected, all the HV and high-power relays are off - so there's no actual risk. AFAIK, there's no need to code anything after - since the battery is the same. When it is replaced - that's a different story. The Manual is warning that errors are normal after 12V disconnect/reconnect, but most users mentioned those errors are gone after a couple of complete steering-wheel turns left-right and after several driven kilometers (or miles if you prefer 😁 ). 34_Electrical_system - Car Service Repair Manuals and Wiring Diagram_reduced.pdf
Users and personalisation
While playing with the 2 keys in & out - did you also check on the infotainment to see what User does the car "Welcome" when you open it? Is it the correct identification key-user? It might sound quite obvious, but while doing the above test with the 2 keys - did you make sure that there's only one key in the "detection area" of the car?
The black bolted-on plastic cover that you mention is hiding the 12V battery that you want to disconnect. Simply unbolt the plastic cover, and you'll have the access to the 12V battery connectors. FYI: what you consider to be "the high voltage battery" is in fact the fuel tank. The HV battery is under the floor under the rear seats - see screenshot of the Octavia PHEV Rescue Sheet and the legend therein...
Complete loss of power
If it opened normally, does the car still close/lock from remote? That would be a sign that 12V is still alive. With the steering on the proper side of the car ( I see you're in Finland) I suppose you can open the engine bay. Try to connect an external 12V there; there's a "+" connection point in the fuse box (no need to go directly to the 12V battery.
Skoda octavia sportline 2025 facelift and obdeleven
How did you turn off the speed warning? Is it managed by a module that is not SFD2-locked? I have the "good-old" SFD (not SFD2) on my Formentor, but I was just curios... I assume that by "speed warning" you're referring to chime that occurs when you go above the speed limit detected/seen by the car via TSR.
48v System Failures in wet weather
Ok, that's not great. You'll need to take pictures or a video of the error message if/when it happens again. It's really surprising that yesterday evening someone was reporting an identical situation on a Formentor facelift (same platform - 1.5 eTSI DSG): car about 5.000 km and it happened twice; once while driving and once stationary. As in your case, the dealership said they have no errors stored and can't diagnose the issue. (also not easy to reproduce - as it happens randomly...) This story looks to me very similar to the problem VAG had when they launched the facelift (Octavia, Formentor, Golf, even the new Tiguan). Every once in a while, the car was refusing to start (get in, press Start - no reaction). It was happening randomly, not on all cars, and mostly in wet weather - the dealership told me it was happening on some of the new cars after they were washing them for delivery preparations!!! The dealership would scan the car immediately and there were no errors to be found. Meanwhile, after plenty (I assume) of reports for that error/fault, I read that VAG released a SW update to address that issue. If I'm not mistaking it was a Gateway related problem. I'm guessing it will be a similar situation with the problem you reported, they need feedback from the users to identify and solve the root-cause of the issue. Just remember to record the fault...
Yes, that might also help, even though I'm not sure how well that works... So far I've read about several different situations: car throwing an on-board (major) error/fault (e.g. drivetrain), requesting immediate visit to the workshop - but no notification received by the "favorite service" - those seem to be most of the cases; car having no problem while driving and no fault in the "car status" on the infotainment, but owner receiving a call from the service saying the car reported some error, "visit us so we can check the car" - very few cases. Mine initiated 2 or 3 times a "breakdown call" - but that was clearly the faulty roof control panel with it's well-known problems. However, my "favorite service" never called me... 🥲
Indeed, there are plenty of glitches on the control-electronics side with this VAG generation (also affecting the platform "step-brothers" Golf, Leon/Formentor etc.). I am assuming that when the error occurred, the ICE was at zero rpm, and the driving situation needed it to be restarted - was it? And 48V failure implied that the starter/generator could not be used/energized at that moment... It is highly unlikely that it happens the other way around: the ICE is running and the 48V-failure stops the ICE. However, a failure of the 48V system - makes the ICE starting impossible. The big question is: did this failure leave any error messages stored on the car? That's what the dealership will look for when you report the problem. In some cases reported online, similar issues (such as failure to start the car and recovery after several minutes of waiting) - did not leave any stored-errors, which makes it difficult (if not impossible) - for the dealership to diagnose/fix the problem.
Is it a PHEV, or a mild-hybrid? The 48V message would indicate a mHEV... AFAIK the Facelift Octavia no longer offers a PHEV drivetrain.
Media In cable for Ipod on Mk4
Keep searching, there's definitely a usb-C & usb-A version - since I have it in my car - also a Sandisk IIRC. Unfortunately I don't have a link for you, since I have it from a local online seller, more than 2 years ago. L.E.: I was wrong, it's actually a Kingston. I love the shape - very compact for a double connector; here it is: https://www.kingston.com/en/usb-flash-drives/datatraveler-microduo-3c-g3
Apply Park but not handbrake
To add to the confusion of some users, have a look at the message I get on my VC when I disengage the Auto-Hold in my car... talk about idiots in charge of SW-development at VAG... 🤔
You need to pay more attention to that space between the front seats! The post-facelift model also has a "P" - next to the gearbox selector, for gearbox-park (pin-locking the transmission) and also a second "P" - next to the "Auto Hold" button, for the Electronic Parking Brake (EPB). So DO NOT press the blue-marked button in the attached picture, but DO press the red-marked one... note: having the Auto-Hold engaged when you stop the car, will automatically apply the EPB also; therefore, if you want to have the EPB-OFF, disengage the Auto-Hold before stopping the car...
Is this meant to do something?????
Mine had a functioning LED in that position - produced Sept.'22, MY23
Engine Cover
AFAIK that was the case for the 2.0 TSI engines, in the early years of the pre-facelft mk4 Octavia. As for the facelift model with the "revised" version of the 1.5 TSI model, all pictures/videos I saw were showing there's no more engine cover. It's just a small plastic around the oil plug - as in the picture below. Can you post a picture of your engine bay?
Flat battery yesterday
Yep, I mentioned that in the enumeration a few posts above...
Yep, with ignition on, I don't know how the 12V systems take/drane power from the HV battery - if it goes through the 12V battery or not. My previous statement was related to the "car parked and turned off" (e.g. overnight) - when most of the reported 12V battery drain occurred.
No, not only for the systems in the cabin; there are plenty of relays and low-voltage components powered by the 12V battery. Unfortunately there's no scenario which allows the HV battery to directly charge the 12 V battery. AFAIK the 12 V battery on our cars can be charged while: - driving in EV-mode; - driving on ICE; - charging the HV battery. I remember seeing such a diagram on some technical documentation posted on this Forum if I remember correctly.
Strange clunk
I noticed that the switching to P (the gearbox park, not the EPB) might be noisier sometimes - single clunk as you say - depending on how you proceed: - if you press directly the STOP button while gearbox is in D/S or R, the noise will be louder; - if you press P (gearbox Park) before pressing STOP - the entire process will be quieter. Depending on the "flatness" of the surface you parked the car onto, if there's some slope, it might be better to first engage the EPB, press P after that, and press STOP at the end.
