Everything posted by SkOmk4
New software available version 1989
The update they mention for the facelift versions is more that the infotainment unit - it's a package with software updates for many other ECUs on the car - called PV4RC. The update is worth doing - the general opinion is that it addresses several SW gremlins, even though I still have some issues trailing after the update. AFAIK the latest update for the infotainment unit is 2768 for Seat/Cupra - the Skoda one should have the last digit +/-1 - otherwise they are "labeled" the same for VAG siblings sharing the same hardware. There was no major version update for the infotainment over the past year, unless the new models coming out of the factory have a newer version that's still unreleased OTA.
Octavia 2021 1.4 TSI iV electric A/C unit switch
A PHEV is never running out of battery completely... When your battery state of charge reaches 0% on the dashboard there's actually a battery capacity (not accessible by the user) that still has some charge left such that your car is still able to drive like a simple HEV - using electric or combustion-engine propulsion in a way that is fully decided by the hybrid system. That battery capacity is sufficient to run the AC as the user/driver demands. When it gets too low, the ICE kicks in and generates some more electricity...
I've never heard of such a modification - it should be next-to-impossible because there's other functions that electric compressor is used for - other than climate. E.g. the hybrid system uses it to manage the HV-system temperature. So there would be lots of special coding to be done on various units that were not already done from the factory. The main reason for this platform to use an electric compressor is that the PHEV concept is also intended to be used exclusively electric over short distances; this purpose would be unachievable if the compressor would be driven by the ICE. The AC compressor is only used to cool the car or dry the air/interior, it's never used to heat the car. For that purpose the VAG PHEV platform uses a PTC heating element - which is obviously draining the HV battery. That's of course valid until the cooling liquid of the thermal engine heats up - and then it takes over the heating function. I'm not sure, but I think the rear window and the seat heating most likely use the 12V battery of the car as is the case on non-hybrid variants. I'm constantly using the App to cool or heat the cabin when exterior temperatures are too high or too low. I'm also using it to control (start/stop) the charging process in some cases.
Tire size conundrum
If the tire size is not specified in the car's official papers (e.g. Certificate of Conformity), just don't use that size - there are plenty of reasons for that. BTW - if you're looking for a winter setup, why are you searching for All Season tires?
Long life servicing
On my first Formentor (same engine and gearbox) there was a fixed service interval: 15.ooo km / 1 year. The facelift Formentor (same gearbox but the 1.5 TSI engine) came with a variable 30.ooo km / 2 years oil service. However, I did service the oil after 1 year and ~14.ooo km - less than half on ICE, since Monday-Friday I'm 100% EV. You should ask for the gearbox service history, since the DQ400e is well-known for it's mechatronic failure caused by an oil filter/mesh that fails and blocks one of the actuators. The 100k km "barrier" is quite often mentioned as higher risk mileage.
Another way to enable/disable that option is via the mobile App. Do you still have a valid subscription?
OBD11 Coding list for Octavia MK4 / IV
Precisely what they were discussing on the other topic mentioned above... No cover on most of the new cars; probably one might find covered OBD port on some premium models.
It seems you're looking on the wrong side - try looking on the driver's right side, not left: ('cause you like driving on the wrong side of the road... 😁 ) https://www.askthemechanic.co.uk/diagnostic-socket-location/skoda
Kantelen rechter buitenspiegel
It only dips upwards, probably because you need to configure it to go down. Look for the setting procedure in the manual or online. AFAIK you have to put the mirror switch to the "R" position, select Reverse on the gearbox, and then adjust from the mirror knob how low you want it to tilt. Did you already go through this process? If you already did, try doing it again.
- OBD 11 with the facelift model
Android auto connection
Yes, problem is still there after PV4RC updates on the car (including SW 2768 on MiB); phone is also an S25 Ultra. It works flawlessly for several days/weeks, but sometimes it just fails several times a day...
Octavia 1.4 TSI iV 13kWh vRS compared to 2.0 TDI vRS DSG
If most of your trips are motorway, I would suggest you go for the TDI; if I'm not mistaking the vRS TDI is also AWD... However, since you mentioned it's on a 19 plate - wouldn't that make it an Octavia 3 facelift? AFAIK Octavia 4 started with '20. The mileage on the 1.4 TSI iV is quite high for a PHEV, you should pay special attention to the service history - those are prone to quite a few gearbox-related issues. The DQ400e is not the smartest/most reliable thing VAG has built. indeed, if you tend to drive it like you stole it (alternating a lot between "pedal-to-the-metal" and "hard-braking") - yes, the gearbox will be jerky, noisy and sometimes seem to hesitate more than you would like... I found the flappy paddles on the VAG phev are only useful in two scenarios: you drive in EV and you want to force/increase regenerative braking, OR when you're in hybrid sport mode and want/need to have control over the gear change while driving spirited; when you really want to know what gear it’s in, simply put the DSG in S instead of D; to see the engine revs you have a few dashboard view options - at least one with a rev-meter; true, you get a lot of wheel spin with this PHEV configuration (on all VAG models that use it), since they poorly manage the electric motor torque when starting from a standstill, even on dry surfaces. The key is NOT to floor it when the wheel is completely stationary; first let the car move a bit and then you can "launch" it - you'll find this changes the car response dramatically. Also, having a grippy tire helps a lot! Mine was delivered with LRR tires and those were loosing grip quite often; I replaced them as soon as I could.
Mk4.5 random errors
Indeed, it'a a SW package called PV4RC that includes (potential) updates for all control units as you mentioned - only for the facelift versions of various cars in VAG group: Golf, Octavia, Leon, Formentor etc. The newer the car, the less updates to be performed; e.g. mine was manufactured mid-2025 and still they found a few updates to install.
Car Not Activated
The "disabling" message you received is referring to some functionalities that were removed from the App - independent of what your privacy settings were. Those who used older versions of VAG Apps (VW, Skoda, Seat/Cupra) will know that sometime last year during one of the updates we were notified that the honk and flash functions were removed. For ICE vehicles the App might not seem to be a big deal and probably not worth to pay for. However, for those with PHEV it is really a big deal: not only you can remotely start/stop the HV battery charging, but it's really convenient to precondition the cabin before departure (cooling in hot summer days, heating in cold weather).
- MIB3 randomly going in the hidden menu
Particulate filter regeneration required on a 1.4 TSi PHEV
The air conditioning should not impact this process, since it uses an electric compressor, not a "mechanical" one, and electric heating before the engine water heats up. Did you check the temperatures (water/oil/gearbox) during your trip? If you drive 30/day I'm assuming it's 15 km each way, and it's possible that temperatures are still not optimal at the end of your trip, given the cold weather outside... (just an assumption)
Well, on a fast road section (90-100 km/h and above) you know the ICE will run to maintain speed (unless the road is downhill). Furthermore, if you put the gearbox in S you will have complete manual control of the gear, therefore control over the rpms. However, getting the GPF warning on a PHEV is quite rare, I'm assuming it must be triggered by a very clear pattern: a large number of very short trips in hybrid mode (not EV), without any long trip to break that sequence.
Well, that's not actually 100% true, because going downhill with the present technologies the car will either do a lot of coasting, or if it will not coast but it will use engine-braking - there will be no gasoline in the "mixture". The user manual quoted above does indicate/suggest a normal procedure to clean the GPF.
First thing first: DPF - diesel particulate filter GPF - gasoline particulate filter most recent gasoline engines also have a particulate filter, in order to comply with Euro 6(d) standard. You probably need to drive for a longer distance using your internal combustion engine and NOT using the lowest revs possible.
Just how reliable is the Mk iv ? Would you avoid.
Post a picture of the headlights and we'll let you know... E.G..: pre-facelift (with Matrix): post-facelift (with matrix):
Kessy locking keys in car
...User Manual? Let's not forget that leaving the key inside the car while washing the car, is a (widely used) way to avoid the car locking and unlocking + folding/unfolding mirrors.
Climate control on PHEV
The heating (PTC element) or the cooling (electric compressor) are both powered from the HV battery. The "brains" of the process, control and coms with the servers (if you send the command from the App), power relays and (I assume) the cabin ventilator (that blows the heat or cold inside) are fed from the 12V - the flimsy as you call it. If you have the car connected to a charger (HV) before you leave, ideally you should charge the last 10-20% of the HV battery before you leave - this also acts as some sort of pre-conditioning of the battery, since it raises a bit the temperature while charging (you mentioned very cold weather). In this scenario, starting the cabin heating several minutes before you leave should have no impact on the 12V battery, since the VAG logic is to also charge the 12V battery (if needed) while charging the HV one. p.s. looking at the screenshot you sent, I realized I miss the exterior temperature showing in the Skoda App. The idiotic Cupra App doesn't have that displayed, and I bet the information is available on the server (sent by the vehicle when requested)
Update 2730
Let's not forget better looking both on the inside and outside! 😁 However, Octavia has a lot more space to offer...
New 2025 Octavia VRS owner... with a few questions
The facelift Octavia has SFD2 implemented, which means that you will not be able to code anything related to the Lane Assist - since the corresponding module is locked. However, I was was able to set Speed Warning to Off (or Last Setting) using the OBD11 one-click-app. Just follow the procedure indicated in the description of the App (open bonnet, ignition on...). Concerning the EPB auto-engage, AFAIK if you have the Auto-Hold activated when you stop the car, the EPB will be automatically applied. (this is actually one of the reasons I do not use the auto-hold 😁)
