Everything posted by East_Yorkshire_Retrofits
Octavia iV reversing camera retrofit service!
It's a Saloon pictured, there's no rear washer. Estates will have a washer system. 😊
Full Matrix Headlights
Worth noting with matrix headlights, it's absolutely crucial that you keep the headlight lenses clean Also important that people don't try adjusting the height of the lights themselves as the calibration is far more complex than just height
MIB2 02XX to 0478
East_Yorkshire_Retrofits replied to East_Yorkshire_Retrofits's topic in Skoda Octavia Mk3 (2013 - 2020)In that case you're all good to go then 👌 We've never had much luck with the units we've worked on so don't even bother attempting with VCDS
MIB2 02XX to 0478
East_Yorkshire_Retrofits replied to East_Yorkshire_Retrofits's topic in Skoda Octavia Mk3 (2013 - 2020)It's not the security login that's not doable with VCDS VCDS doesn't allow you to change the diagnostic session to engineering mode, to allow you to enable the developer menu. Seems this isn't necessary on all units though 👀
MIB2 02XX to 0478
East_Yorkshire_Retrofits replied to East_Yorkshire_Retrofits's topic in Skoda Octavia Mk3 (2013 - 2020)You can't enable developer mode with VCDS unfortunately We connect to prepare SD cards and talk you through each step
MIB2 02XX to 0478
East_Yorkshire_Retrofits replied to East_Yorkshire_Retrofits's topic in Skoda Octavia Mk3 (2013 - 2020)We can carry out the update remotely however you'll need OBDeleven or similar to enable developer mode on the infotainment unit Alternatively you can post the glovebox radio unit to us. The car is still driveable with it removed It's £32.49 for the update
Can high beam assist be retro fitted to my 2021 Octavia SEL with front camera?
Your car has the necessary hardware, I believe they all/most of them have the ADAS camera in the UK on the MQB2020 platform
We certainly can, however I've just checked parts prices and the HUD alone is £1280 + VAT, then there's the brackets & fittings + labour. You'd be better trying to get one used and bring it to us Worth noting you'd also need a replacement windscreen & ideally a replacement dashboard
Yes we can, but it's cheaper in the Skoda store 😊
RE 2Q0 ADAS cameras High beam assist isn't SWaP Lane assist & traffic sign recognition are. We can activate both
Adding a wireless charger
Bare in mind the original will have a designated position on the fusebox, and will integrate with the infotainment system. You also have the option to add an antenna & amplifier to allow it to boost your telephone signal 👌
USB and Bluetooth stopped
Does it charge the device? Does it connect via Bluetooth? Have you tried other devices?
If you'd like to send us your VIN then we can quote it for you, don't worry if you don't plan to go ahead - it's something we need to price up anyway 🙂
We can retrofit the factory wireless charger for you 🙂
What happens when you try to use them?
DCC dynamic chassis control replacement costs? aftermarket?
Coverdale car parts will likely be cheaper than that, if you send me your VIN I can give you the part numbers to allow you to shop around easier 🙂
We're based in Bridlington, East Yorkshire
MIB2 02XX to 0478
MIB2std updated from 0241 to 0478. Aswell as adding the newer type menu, this software update allows the use of a later display with "app" button & also allows units with MOST (fibre-optic) to function with a virtual cockpit. It also functions compatability improvements & bug fixes. Completely error free, as it always should be. www.eastyorkshireretrofits.co.uk
We are now offering a genuine reversing camera retrofit for the Skoda Octavia iV You can find more information here https://eastyorkshireretrofits.co.uk/collections/skoda-octavia-iv-2021/products/octavia-iv-reversing-camera Please don't hesitate to ask any questions!
