Everything posted by SwallownAmazon
DPF Problem (again!)
My recently bought 2016 Octavia manual diesel vRS is giving no end of problems with DPF codes being thrown up and descendng into limp mode. The story so far: Engine management light (EML) came on coincident with switching off the stop-start function when idling in traffic on a very hot day. Checked at my indie VAG specialist in Sevenoaks with VCDS which indentified a "spurious" EGT sensor fault. Cleared using VCDS and I went on my merry way. EML came on again about a week later which showed a fault with one ot the DPF pressure sensors which again was cleared and I went on my merry way again. Pete did show me the sensors one of which was a Bosch (probably original judging by the dirt) with the other being a Hella replacement. His advice was that there was probably a very minor discrepancy between them and they should both be renewed if the problems happened again. EML came on again about two weeks later shortly followed by followed by the flashing curly glow plug light with car going into "limp mode". Work done was: replacement of both DPF sensors with Bosch units, replaced one of the EGT sensors between turbo and DPF which was burned away to the thickness of a pencil lead, found DPF was choked at 49 gms soot, forced regen of DPF to 4.3 gms soot and I went on my merry way a third time with the car going like a rocket ship on wheels, wallet nearly £600 lighter but which also included an oil & filter change, AC regas and cabin pollen filter change. They did tell me that fairly recently it had been fitted with a replacement turbo which was likely a DIY job because there is no record in the service history that came with it. It's likely that the engine management "electrickery" had been fooled into believing the DPF was clear when it was actually choked. This may have caused some of the original faults I had found. Sounds plausible, what does the "panel" think? This weekend, we had to be recovered from a family wedding in Suffolk when the car went into limp mode three miles before we arrived at our hotel. Yesterday, the breakdown chappie did a code read and came up with a choked DPF and injector fault. He could not clear the DPF fault using the TOPCON code reader he had so we had to wait another 90 minutes for the flatbed to arrive. I had topped up the oil with Castrol Edge Professional before we left home on Friday and when I checked just now it seems to have used about 300 ml in 115 miles. Bearing in mind that both my previous Octavia TDi's (2002 1.9 and 2008 2.0) hardly used any oil between changes, this seems excessive to say the least. The last previous owner was a member of a family that owns a garage chain in the Newcastle area and probably "outed" the car to auction as a bad job ASAP. I bought it in High Wycombe, from the dealer who probably bought it at auction. My questions are: Is it possible that a replacement (probably recon) turbo could have failed in such a way as to cause excessive oil burning and choking of the DPF? Can anyone recommend a supplier of a) a replacement DPF and b) a replcement turbo? The memsahib and I both love the car, as when it's running well, it's super but when it's not running well, it's a bit of a dog..... Sorry it's a bit long-winded but to get a logical answer, as much info as possible is needed. Thanks. Chris.
Central Locking by keyfob intermittent on drivers door but key works.
I've just had a very similar problem: The lock button on the key fob operates all the central locking actuators except the drivers's door but the alarm doesn't work, as when the drivers's door is opened it doesn't sound. Problem only showed up yesterday, is changing the actuator a DIY job or better left to the experts?
Rear Calliper Concerns
The weight is the giveaway, all my "exchange" painted calipers from TRW in the past were b*****y heavy...
- 13 replies
- rear calliper
- help
- information
- brakes
Tagged with:
I too am surprised that coating has come off the caliper. TRW is the manufacturer and supplies the "aftermarket" with exchange units in UK via a parts factor such as Motor Parts Direct; they will not supply consumers direct. If you get in touch with the factory in Redwither Road, Wrexham, they should give you the details for their area rep if you are concerned about the integrity of that caliper; phone number is 01978 667810. They are now owned by ZF (makers of gearboxes, steering racks, etc.) I would be very surprised if the caliper is alloy and not cast iron - all the calipers on my cars have been iron; alloy would only be used where weight is important such as racing or rally cars. I have dealt with them a couple of times with exchange calipers for my Volvo 122S rally car (now sold) and my BMW 740 Sport and found them to be very helpful.
- 13 replies
- rear calliper
- help
- information
- brakes
Tagged with:
Leaking fluid from engine mount
Another example of "rip-off Britain" .....
Another DPF question - Warning light consistently comes on after hour and half of driving
Had the same issue with my recently acquired 2016 diesel vRS with 144,000 miles. DPF warning light came on when trundling in traffic on a very hot day. Fault cleared by my friendly garage - showed as "Intermittent DPF Pressure Sensor". Fault cleared and OK for a few days then, Same fault cleared by garage but was shown a Hella sensor on the "upstream" side and the original Bosch one on the downstream side. Advised that they both ideally should be changed so booked car in. Incidentally, I was told by a friend who followed me one day at this point that there was quite a lot of blue smoke from the exhaust. Before the work could be done the curly glow plug light started to flash with the original DPF warning light again and car was in limp mode. Got the car back after two days restored to health. The garage told me it had recently had a new turbo fitted but the folk who did that work for a previous owner in Newcastle ignored a number of other faults including the almost choked DPF and an exhaust gas temp sensor that was almost burned away to nothing. They must have also reset the DPF "electrickery" to zero which meant it would not regen on its own. Anyway, two new Bosch DPF pressure sensors, a new EGT sensor and a forced regen later the DPF is now down to 4.3 gms soot (from 49 + gms); all the lights are out and it goes like a train with no smoke from the exhaust. My advice to DaveyK would be to look for your local BOSCH specialist garage (who may specialise in VAG cars as ours in Sevenoaks does); they should be able to sort you out.
- Humming at 50 / 90 / >130 kmh
Mk 3 Octavia Facelift v Non-Facelift
That's what i wanted to know but didn't express myself very well in my original question.... DOHHHH
I have a 2016 Octavia 3 vRS TDi Hatchback first registered on 23/06/2016 that I bought last month. It has the variant AACUNAXD shown in the V5, is this enough info to confirm if this is a "Facelft" model? What are the differences between a facelift and a pre-facelift version?
Coolant issue
Thw three most important factors for a successful bleed are, I believe: System should be cold. Heater should be at Max heat Engine should be running to circulate the coolant.
Coolant issue
I'd say there is an airlock somewhere, but where? That is the question..... Without understanding the layout, I would try and find the highest hose clamp, undo it and fill the cooling system from there with the engine running and cold. My BMW E38 740 Sport with 4.5 litre V8 takes about 30 minutes to fill and bleed the cooling system properly. There is a bleed valve on the expansion tank that MUST be higher than the heater hoses at the back of the engine. This is difficult as the bleed valve is actually a lot lower when the car is level so, it MUST be done on ramps; and the engine has to be cold, i.e. with the thermostat closed and the heater on full heat to make sure the matrix is filled properly. If the stat opens you have to go away, make a cup of tea, watch the cricket for an hour and start again... Quite a rigmarole and it sounds like VAG havn't fitted a bleed valve to save money.
DPF differential Pressure Sensor fault codes + limping
Hopefully (!) final update on my issues: Garage changed both DPF pressure sensors but still could not force a DPF regen even though the "machinery" started OK - it kept stopping. After further investigation, it turns out the turbo was replaced recently (unknown to me when I bought the car) and the original exhaust gas temp sensor between the turbo and DPF was put back/left in place. This probe was almost burnt away to the diameter of a pencil lead so was changed and hey presto the DPF regen was completed without further problems. Soot down from 42.9 to 4.3 of what ever units are used. Goes like a rocket now......
I have exactly the same problem and it's having a Bosch sensor being fitted tomorrow to replace the Hella one that a previous owner had fitted. Hopefully that will solve the problem...... Coincidentally, the glowplug warning light came on this afternoon when the low fuel warning came on at 65 miles range. I'll get my indie VAG specialist garage to sort that at the same time.
- 1.6 TDI Octavia 5E3 Brake Calipers, Discs + Pads.
Not on a Skoda but I have very good experience on my BMW 740 Sport (E38 variant) with EBC Greenstuff brake pads. The BMW brakes are marginal for a 2.5 tonne 300 bhp car (single piston sliding caliper) but the Greenstuff pads have significantly improved things; better intitial "bite", less fade and less of the black dust associated with copper based pad material. I shall be fitting these pads to my Octavia vRS as soon as I can undo the wheel nuts.....
Intermittent fault with newly purchases Octavia - repair or return? WIthin 30 days.
Check that all the plasic undertray fittings are properly secured to the brackets / holes in the floorpan. There may be something loose that "flaps in the breeze" above a certain speed. I have a 2000 BMW 740 Sport as a hobby car and the garage that serviced it and changed the front O/S thrust arm didn't check properly and the undertray part covering the front O/S fell off on the way home. They were adamant that it was secured properly but I know couldn't have been otherwise it would not have fallen off.....
vRS Hatch Wheels.
- Information about my disc brakes
In my case, it was about as useless as the chocolate teapot..... Tried that, it came up with three alternatives with no advice on how to choose. The dealer couldn't even tell me because there are the three variants, the fitting of which seems to have depended on which way the wind was blowing at the time. The only reliable way to do it was to take the wheel off and measure the disk.- Information about my disc brakes
Just taken a front wheel off to measure mine at 312mm. It's a 2016 vRS diesel Hatchback. There seems to a consensus on here that the diesel vRS has smaller front brakes than the petrol vRS; why is that?- Skoda Octavia 3 Owners register
Just traded in my 2008 Octavia Elegance TDi for a 2016 vRS Hatch in Corrida Red. Meant to be, as the first operator of this car leased to the Freight Transport Association also lives in Tonbridge so the car has come home..... I'll have to visit the chap so he knows he's not being stalked!- vRS Hatch Wheels.
That's put my mind at rest somehat, Rich - thankyou. The rim edges are in such a poor state that I think I'll have to have them refurbished. They spoil the look of the car which is otherwise immaculate.- vRS Hatch Wheels.
Thanks for that, adds even more to the confusion.... This morning, I took one of the front wheels off to measure the front disc diameter so I can order the correct Greenstuff pads. I laid the wheel down on the inside and there was a loud clatter when the inside wheel rim hit the brick paved drive. I had expected the wheel to land on the sidewall of the tyre but no. Your table above says there should be a bulge of 4.5mm in the sidewall; I can assure you the wheel rim exceeds that by some 3 - 4mm. Makes me wonder whether at some stage in its past, it has been fitted with wider rims but kept to the same 225/40 x 18 tyre size. Sadly I do not have access to a wheel rim measuring caliper to confirm its width. On a similar but slightly different tack, are there spacers built into the inside of the wheel? Mine appear to have spacers but I don't have another vRS to compare with.- vRS Hatch Wheels.
I have just bought a 2016 vRS diesel Hatch that has the Gemini 7.5J x 18 wheels as (I believe) the standard fitment for that model. The tyres are 225/40 x 18 but they look very skinny on those wheels, to the point where the rim protecting rubber ridge on the sidewall has no effect with consequent "kerb rash" on all the rims. Has anyone fitted wider section tyres, say 235/40 or 245/40 section, to give better protection to the rims? If anyone has done, what was your experience? Do they clear the suspension and wheel arches OK? I've been a diesel Skoda Octavia driver since 2002 when I persuaded my MD to allow me to have one as my company car and when I retired in 2014, bought the last one which was just traded in for the vRS.... Chris.- Rear windscreen washers again
Mine comes out by just lifting the end where the jet balls are by hand........- Newby on here.
Just signed up as looking for help how to remove front grille. I have a 2007 2.0 Tdi Hatch that was my company car and when I retired in 2014, they didn't want it back with 140,000 odd miles. It was handed over as a retirement gift and they even paid the tax as a "benefit in kind". It was my second one, the first being a 1.9 Tdi which also did 140,000 miles in the 6 years I drove it. Also have a couple of "hobby" cars: 1937 Morris 8, 1967 Volvo 122 S rally car, 1990 Audi 90 20v (also ex-company car then used by the memsahib) 2000 BMW 740i Sport, 1950 RT Type bus ex London Transport. - Information about my disc brakes
