Everything posted by petrolcan
Spare Wheel kit for 2020 superb sportline plus hatch
Done
A worrying blip
Depends whether you're doing the labour yourself really and what you define as expensive eg: https://www.eurocarparts.com/p/starline-alternator-40144153s
I'll have that if they don't
A worrying blip
Get the alternator tested as it sounds like it may be on the way out.
Wheel part number
It's cast on the inside of the wheel. Yes, you have to take it off to find it. No, no-one here can decipher what sort of wheels you have on your car without some basic details or maybe a picture. I'm getting little britain OMG vibes here...
Melted Mess !
Dunno if this is any help to you at all https://skoda.7zap.com/en/cz/superb/sup/2016-851/1/
Melted Mess !
It'd likely help if you stated which engine this is
1.2 TSI Yeti - any advice appreciated on Yeti warning lights
Test the battery first of all. Do you have a code reader or know of someone who does?
hesitant and uneven start
First question that needs an answer is how old is the battery in the car?
speakers
Would it be worth doing a full reset of the head unit before swapping out parts? Or a VCDS scan?
Facelift or not.....
Anything is possible if you throw enough money at it. Off the top of my head you'd need the following: Set of Xenon Headlights with control modules Access to VCDS and/or Odis for coding purposes Probably other things needed too like levellers
- Almost 1,500 miles on a single tankfull of diesel.
You have standard halogen headlights, previous pic is of Xenon headlights.
***SOLD*** Know someone with a Astra-H, Vectra-C, Signum or Zafira-B? This is for them ***SOLD***
Now sold
Looking to buy a superb
Yeah, I know about the change which is part of the reason I didn't get mine done last year. Main reason I got it done was to not push my luck Would still like to see evidence of the 'weak' claim as per @stevetdci
Do you have evidence to back that 'weak' statement up? FTR, I had my timing belt/water pump changed at the end of April at 126k miles and they were original.
What fuel consumption are you getting please.
Wee catch up on this. Filled up on Thursday morning and hit the road to Holyhead. Having covered 240 miles, the tank range was showing 759 miles remaining so there's no reason not to be able to get a thousand miles out of the tank.
The Superb III Picture thread
Think it's been longer than that!!
About to embark on Skoda ownership, Superb L&K Estate
Fitting new blades and having a streakless windscreen brings me immense joy 🤣
Damn! Those springs keep on breaking eh? 🤣
Stalling, and no codes...at a loss
Once the engine dies it will not restart whilst hot. This happened to me in a Vx Signum. Coughed and spluttered for a sec at 50mph and on I went. Slowed down for rush hour traffic and the car died, right as the two lanes merged into one meaning I had cars going round both sides of me, I identified as a traffic island for a while. Breakdown called and they alerted the police (I obviously needed more people staring at me) who kindly got me to a side road. Breakdown arrived after 45 mins and I explained the symptoms only to be told I must be out of diesel (3/4 tank). Fecker jumped in and the car started first time!
@ReaF Do you have VCDS? I'd say your best bet is to take dome live data and try to recreate the issue when driving, it'll capture something. I'd have suggested crankshaft sensor too but they tend to break down under heat and it takes a lot more than a few minutes before starting becomes possible again, up to 1/2 hour in my experience. As to the oil usage, if there are no obvious leaks then you need to do a compression test. Also, as stated by @Warrior193, test the battery on crank rather than resting. Curious to know why the dealer replaced injectors too, was there a fault code on them?
Kodiaq Owners Register
You need to be a Freedom member to do that.
Installing Speed Cameras on The Amundsen MIB2 - Free Database and Quite Simple to Do!
Nice easy install, thanks @bigade1
Infotainment Firmware Updates & More
Assuming it hasn't got bluetooth as there's no phone button.
