Cairus
Everything posted by Cairus
  1. Password, send me an PM https://mega.nz/#P!AgGWtzUFoIP4pguwu7Bh2bhWtG8XiisFKZVDNk8n3ZSTbcmIhTo6VEiYkN8TXsA1Rdgg9bZrDg7uZAIVtm6yKuo1kPk-MEShhLYpAN_grJHGH3-sIMnCGM1SY4KtOlkTuCVhsO1pnAs
  2. A new BCM triggers the CP error. If you install a used one, the CP must be adjusted, as well as the coding and data set if necessary.
  3. ISA can be disabled on models 25with the following assistant camera: Hardware number 2Q0980653A Hardware version H19 Software number 2Q0980653H Software version 1602
  4. I would do it like this
  5. You can't update directly to firmware 1433. You have to do updates between them. I would recommend To have a diagnostic tool.
  6. You have do this, then PM with Firmware Number ;)
  7. https://mega.nz/#P!AgEDeRWdGtvGB5zCrYpuVLMB11Yu-o3ICjQsrwLxHsDLs-IZWumv6zi3_8eYRBYwJIqh95o_ClT3l-y-CVIERe14ygq_uqXCmGFuOT7pPU7pDYLR-QxdAEgXkIrkMyJDravh5ggjWaw
  8. The newest in your train is 0369t I will Upload 0253 in your train
  9. The newest in your train is 0369t I will Upload
  10. The Amundsen requires the SD card in the unit to navigate... the new full Europe map, however, requires a 32GB version. The original map, however, does. The device checks for a CID number on the SD card. If it's incorrect, the navigation system won't work. So, either buy an SD card with the correct CID number somewhere, or patch the device so that no CID query is performed...
  11. Do you have a photo of the sticker when it is still visible, or can you take a photo of the engraved serial number?
  12. I can Help you when you want. For free
  13. @balazs955 Don't forget, every time you replace the unit, component protection is triggered. With a MIB 2 Std, it's easy to patch if you have firmware version until 04xx. Don't forget the coding on the vehicle... with the Octavia, if you have a MIB 1 and convert to MIB 2, you always need a patch, because an official function activation would never work. Component protection could, however, be made official.
  14. Buy a new used one if you have a coding tool. It's much easier to patch. You can also patch the component protection. You'd also have a navigation system then. But it has to be a mib2_std.
  15. You can do it self. Firmware Look under Settings, System Informationen
  16. Now you know your Problem 😉
  17. Which Firmware have the Radio?
