Everything posted by Cairus
- From Amundsen to Columbus: mission almost accomplished!
Auto Start-Stop not functioning
Charging the battery: if this helps only temporarily, replace the battery regardless of age or mileage.
Software upgrade
Simple SD Card, nur for junp Firmware train you have to Patch
Google Maps etc. in Virtual Cockpit
It’s a hack of the MMI—specifically, the Audi MIB High system.
Amundsen MIB2 Firmware Update
I have the Solution and dont need help
Digital Cockpit Display Error
Your automotive controller is no longer synchronizing with the graphics controller, which indicates a timeout issue. Updating or reflashing the same firmware might help. Otherwise, buy a used unit and find someone who can perform a full backup of the automotive controller, transfer the data to the replacement unit, and adjust the mileage.
- Chinese rear differential
Firmware Update to 369 then Patch
Skoda dont exist, Only Cross Flash to VW Firmware with Skoda HMI is the Solution
Skoda superb sportive estate 2023 suspension to soft
Latest what is this collection of errors post
Correct , there is a Problem
- Skoda Superb Mk3 - Best MIB3 Columbus Head Unit part number?
Firmware update MST2_EU_SK_PQ_P0369T
Dont exist
- Problems after ABS module replacement
- Retrofit Virtual Cockpit LHD
The advantage of this would be that, for instance, you could virtually mount the user partition in Linux and extract the `system.ifs` file from it. This means you could theoretically patch the system directly; no discrepancy would be detected, and the system would boot up and function perfectly. I hope the explanation is detailed enough now. Perhaps this is of interest: @travs @JR RS @Binx1310 @Bap33 abd Others
Even the component protection is implemented quite effectively. It is linked to the CPU Key ID, the eMMC Key ID, and the EEPROM, and is further encrypted using a cryptographic key stored on the VW server. If you were to clone the data via the EEPROM, the system would immediately detect that the cryptographic signature is invalid because the new unit—where the EEPROM data was loaded—has different Key IDs for the CPU and eMMC. In other words, the software instantly recognizes the tampering. I spent hours, days, and weeks trying to bypass this on the MIB2; I succeeded, but the problem is that the solution isn't firmware-stable—a single update wipes everything out. Plus, you need the dump from the unit that was officially paired with the vehicle. The effort involved just isn't worth it for the MIB2. With the MIB3, I am currently in the process of creating a full system backup—meaning the eMMC, including Boot 1, Boot 2, User, and Config partitions. The EEPROM part is simple enough, but the eMMC in the Preh MIB3 unit has 64GB of flash storage. Since I don't use a "chip-off" method, performing a 1-bit ISP backup takes anywhere from 5 to 24 hours, depending on the clock frequency and the bench setup.
Every control unit has a unique identifier known as the VCRN. At the factory, this is paired with the EEPROM, the eMMC Key ID, the CPU Key ID, and the VIN. As soon as the unit is installed in a different vehicle, the software detects a discrepancy and—as shown in your picture—marks all FECs as "temporarily rejected." When you then perform the function activation, the FECs that were valid from the factory (or officially purchased later) are activated; essentially, the routine performs a fresh reconciliation and re-signs the eMMC and EEPROM. In principle, the patch does the same thing as the MIB2 Toolbox—it bypasses the verification check—but with MIB3, the trade-off is that online services no longer work; unlike the MIB2, the software immediately detects the discrepancy in the EEPROM and switches to a "tamper mode." The FeCs appear as rejected in the software, yet they still function despite the tampering.
😂 Sorry. Nobody read What i say: Did you perform the function activation? It probably won't work with ODIS Online, though, because different data is stored on the server. If IT works, only the Fec's from Factory out are activ. In my opinion, the online services are completely useless. The MIB3 runs much more stably and reliably without them. So, disable them via coding, patch the unit, and you're done. But in this case, since the CP has been officially removed, the online service might actually work despite the FEC patch.
Cairus's Leon FR
The Leon needed a little TLC; it wasn't running smoothly anymore, especially at idle. So, I pulled out the spark plugs and coils to check the combustion pattern... It turned out cylinder 2 looked like it had been wet at some point. I installed four new NGK plugs and coils, and now it runs silky smooth again.
