Everything posted by Colin1051
Tyre Pressures
Hi all. Just a question at this stage. How often do you check your tyre pressures? I have a reason for asking this apparently innocuous question !
Is the new Kodiaq iV a lemon?
The car was rushed to market so Skoda could claim to be ahead of the net zero mandate. Inadequate testing and poor implementation of the various assistance systems. There are many complaints on here about the IV/PHEV versions. I would expect major recalls any time soon.
Startstop Karoq sport plugin
It's certainly not obvious to me. I still don't get your point "the OP is talking PHEV". A PHEV still has an internal combustion engine capable of producing emissions and liable (in certain circumstances) for an undue idling offence. Perhaps you're simply trying to be argumentative - are You ???
"but because the OP is talking PHEV" Explain please.
I was trying to keep the post brief but to the point and not do a full discourse on all the exclusions, ifs and buts. You're the only one to mention Private Ground !!
Moreover, in the UK, idling is an offence under The Road Traffic Act 1988 Section 42. And yes, you guessed correctly it's to do with air pollution.
Keyless Lock/Unlock
I have a 20l Diesel Kodiaq Sportline 190 bhp, new in March 2025. In particularly cold weather in Glasgow (between 2C and -6C) I've noticed that on occasion the lock/unlock feature doesn't work but a press of the button on the front door handles works perfectly. My previous car, a 2022 2.0l Diesel Kodiaq L&K, behaved exactly the same in the same atmospheric conditions. Has anyone else experienced the same? I can't really say it's a problem since it happens so infrequently, it's merely an irritation.
Remote not working
What ???
Remote not working
I understand that KESSY places a strain on the keyfob battery so that would suggest that the battery will need to be replaced more often. Given the ease with which the battery can be replaced, and the low cost of the battery itself, this is not a deal breaker. Deactivating the KESSY system is akin to throwing the baby out with the bathwater.
Permanently disable A.C.T ?
I can't help you any further.
A quick search on Google suggests that this is a known issue, essentially due to the inherent imbalance of running a 4 cylinder engine on only 2 cylinders. Worn engine and/or transmission mounts are one probable cause. Another probable cause is that when running in 2 cylinder mode the exhaust frequency changes causing the exhaust system to vibrate against heat shields. Thus exhaust hangers, heat shields and connections should be checked for integrity. On some VAG cars a loose wastegate rod can cause rattling which can feel like vibration and in cars with direct injection (like the VW 1.5 TSI) carbon buildup on the intake valves can cause rough operation when in 2 cylinder mode. Bearing in mind the high mileage on the subject car in this post, carbon buildup seems a quite likely cause of the problem. The ACT system relies on oil pressure to activate the solenoids that disable the cylinders. If oil pressure is low, or if the oil control valve is sticking, the cylinders may not deactivate/reactivate smoothly. Depending on the car model driving in sport mode disables the ACT but obviously this is a workaround rather than a solution. Given the diverse nature of the possible causes it is not at all surprising that 'qualified' mechanics have thus far been unable to determine the exact cause. Good luck Brian15 - I think you'll need it !!
Mysterious Brake
From your pevious replies I would hesitate to call you naive. I don't believe for a second this is a feature (it would be the most pointless ever). This is clearly a defect. Whether it affects only a limited number of vehicles is not to the pont, it is still a defect which Skoda has been advised of. In true 21st century corporate behaviour it will not publicly admit to the defect but will fob cutomers off with any old excuse under the sun until the real technicians do some proper testing and remedy the fault, or until a significant number of car owners begin to reject their cars under Consumer Protection legislation and tell the general public through social media of the reasons why.
Does the car have a full service history? I agree with Warrior193. Something other than ACT is at the root of the problem.
Mysterious Brake
With the greatest of respect I think you place too much faith in Skoda Dealerships and in users manuals (which in many respects are no real use). I'm convinced PHEV and pure electric Skodas have been rushed to market, without adequate systems testing, just to show the world that Skoda are ahead of the Zero emissions mandate.
Mk2 Hybrid only with 5 seats
It's because of the battery which sits where the third of seats would be.
Auto Hold
In my Kodiaq Sportline if I set Auto Hold to on it remains that way until I stop driving and turn the engine off. On restarting Auto Hold is off. IMHO that is the way it was designed to work. I suggest you get the car to the supplying dealership and get it checked.
Adaptive cruise control
In the UK ACC is not a mandatory safety device.
Travel Assist
I'm not criticising, it is your choice of course, but why rely on ACC? You are in control of the car and, by law, you alone are responsible for the manner in which it is driven. That said, why do you abdicate that control to an electronic system which may or may not be infallible ?
This is exactly why I never use ACC. Some users have also posted that AEB is also too sensitive and has caused some rear end collisions. My 2.0 litre diesel Kodiaq Sportline has occasionally flashed up the advance collision warning sign on the dash but thankfully has never applied emergency braking. I may just be lucky in this regard !
- Laurin and Klement
- Kodiaq iV constant assistance systems malfuncion.
Limiter Question: 2026 Škoda Kodiaq 1.5 SE L Plug-in Hybrid
I have the Kodiaq Sportline and it has the mandated (under EU regulations) speed limiter. This is enabled every time the car is started. Should you exceed the permitted speed limit on any piece of road, the limiter will emit an audible alarm but there is no automatic reduction of speed to the specified limit. It is frankly an irritation as is the lane keeping feature. I regularly turn both off before I move the car. My car also has ACC but I never use it. I don't think is has any effect on the speed limiter.
5 seater vs 7 seater
More reliable? It isn't just the interior trim that's compromised. Engine, electronics, gearbox, suspension are all built to a price. Good luck if you choose one !!
Poor quality brakes?
Take it back to the dealer for a warranty replacement.
Have a seat in any model of Dacia and you'll quickly realise why they are so cheap. They are designed to a minimalist specification and it won't take you long to walk away.
