Everything posted by Sharpy64
Advice please on DMF
Ive done gearboxes on the floor before but its a right PITA, thats on the floor of my mates barn, which is set up as a workshop with lifts (sadly none were free at the time). Its not that its a really challenging job its more that gearboxes are just a terrible shape and weight to man handle, took me and two friends to get mine back in and Im pretty sure I was nearly crushed to death by it about 4 times. @Alasdair1 has covered the other main points, id just do the master cylinder for what they cost its not worth not doing it, some clutch kits do come with them included.
2015 VRS TDI - Coolant loss from expansion tank
That does sound like an issue with the PCV. The differences are subtle but the membranes are different, the OEM one is a 2 piece the aftermarket is a one piece and just doesnt feel very "nice" hard to explain. Also the circumference of the plastic PCV "cap" differs hence why I cannot use the PCV valve I bought as its designed for an OEM rocker. I am seeing some residue and have high oil consumption so I am going to swap the rocker. I have ordered an OEM rocker cover as I prefer genuine stuff for things like this as I tend to find aftermarket parts are just not as good or reliable. I do think I am getting blow by and I do suspect its the rings but I know that can be exaggerated by a PCV issue so just fixing things one at a time to see if I can get it to a reasonable level of oil loss. TBH I am looking at second hand engines and then considering stripping it right down and rebuilding it myself with all new parts, would be a good opportunity to do a bit of a horse power increase as well.
Turns out I have an aftermarket rocker cover on my car so I will end up replacing the whole cover to see if that helps. The PCV I took out was different to the OEM one and the rubber didnt feel great, it was quite stiff but was intact to hard to say if that is part of the issue or not.
It’s better but still not great, changing the PCV today to see if that helps.
Octavia Mk3 Screen Retrofit
I have swapped out my small non-carplay unit for the larger model you show above, from what I understand you also need the part that sits in the glove box, you cannot just swap the screen over. When I did mine I bought the screen and the glovebox unit second hand but together and it was a straight swap. You also need a different USB port if you wish make use of carplay options.
2017 diesel 150 DSG 4x4 fuel filter identification
There are generally two variants, one is as described the other isnt. The one that seems the most common is like this, (would need to check model etc) Bosch | Euro Car Parts
Random jerking, like a misfire. No warning lights, no diagnostic code, throttle position 89%. Help!!
Seen this a few times and is almost always the crank sensor, occasionally the cam sensor, Its like a hard diesel stall, properly bangs but doesn't stop, the occasional stall in traffic. For what its worth I did get one random crank code show up but wasn't permenant and then it vanished. For what they cost I would start there for this condition.
Autodoc - avoid!!!
I have had a few minor issues with AD but nothing too bad if you pay for the "safe order", normally a few quid, then returns are free should you need to send stuff back, they just send you a link you print out the label, package it up and drop it off at the post office. Never had any issues in that regard. The only thing I have complained about it swapping some parts out for cheaper ones due to "availability" and not telling me and also not getting a refund for the difference but they were quick to resolve that issue as well. As noted above it is crucial to due relevant due diligence on parts and part numbers as I had an issue with the dig bone bush as there are two and I ordered the wrong one and didn't realise until it wouldn't fit in the subframe. I will note that experiences do seem to vary an awful lot.
The "Definitely Not a Project" Project Thread
Fitted the headlight with the new DRL parts. Looks much better now but is brighter than the other one, so I’m looking for a spare right headlight to do the same on that side.
Already swapped for Polybush versions, much nicer. I’ve had track cars with solid mounts so knew it would be bad but got them cheap so thought I’d try it. Found out why they were cheap!
My DRL kit arrived from AliExpress so using a spare headlight for cheap I first removed the lens by taking the clips off and then warming the sealant using a hairdryer, Then removed the 100 screws and the plastic strip, which is clipped in place, I also removed the LED module, you can see of the old strip the melting that had caused the yellowing, Using the reverse of taking it apart put it back together and tested it, Good result, just need to clean the inside of the light and refit the lens with some new butyl seal which will involve baking the light in the oven once the seal is in place then squeezing the lens back on and refitting the clips. A small but satisfying win.
- 2014 Skoda Octavia Mk3 2.0 TDI – Coolant Loss / Possible EGR Cooler and/or Head Gasket
I had a very similar issue on my mk3 VRs tdi, I have a whole thread on the diag and fix. I’d guess both EGR cooler and HG have failed you can test the former by buying a bypass kit of the cooler this does what it suggests and bypasses the coolant from entering the cooler. If the coolant still sropa you know it’s likely a HG issue. You can also do a sniff test on the coolant and see if you have combustion gasses in the coolant, although that could be from the cooler or the HG so all it confirms at that point is a failure. In terms of fix, id started with a cooler (I have a pretty much new Mahle one I can sell, was on my car for about 2 months). You can also pressure test the cooler once it’s off the car. My issue was a combination of cooler and HG, the latter becoming much more obvious after replacing the cooler as I think pressure was escaping from the cooler and when it couldn’t do that it escaped from my expansion tank. HG job is pretty involved, you’ll need to get the head pressure tested as well just to be sure it’s not cracked and then about £900 worth of seals and gaskets etc. it’s a good 10 to 14 hrs of work so if you’re not going it yourself it’ll be over £2k for a HG job alone, but there’s other items worth doing while you’re in there.
Cambelt and water pump replacement pricing
Forgot to add that but, yes, I did the same on mine, although the original was still in pretty good Knick at 140k.
- 6 replies
- #skoda
- l&k superb
- superb mk3
- 2.0 tdi
Tagged with:
Panic - main display is blank!
Does it have a physical "knob" for the power / volume? If so try a hard reset by turning on the ignition and then holding down the power button for c 10seconds the unit should reboot.
I do my own work but the kit price is about £250ish for OEM I think, so that seems a little steep just for the kit tbh, job is about 3-4 hours, I did the crankshaft main seal as it was leaking which means taking the sump off so I was on the upper end of that time. Its not really that big a job as there is plenty of room really. I would say c£700 is about right, but it is worth checking some of the oil seals as if they start leaking you get to all all the labour again as the cambelt has to come off. I would also do the aux belt and pulleys at the same time. Just checked - I paid £555 for my wifes 2017 2.0 TDI Ateca 3 years ago as I wanted the evidence. That was using a INA timing belt kit (£150) and inc aux belt and pulleys etc.
- 6 replies
- #skoda
- l&k superb
- superb mk3
- 2.0 tdi
Tagged with:
On oil consumption, I’ve now had the car back a week and while not done massive miles I’ve driven it everyday and cover maybe 30miles everyday at least, so far no noticeable drop in oil. I’m doing a couple of longer drives over the weekend so will feedback again but I’d say it’s definitely improved.
I will already add the fact I have a "yellow" DRL which i need to fix and its not related to the ballast as I have replaced them already!
- The "Definitely Not a Project" Project Thread
So, I find myself in a place where a car I bought was not going to be a project car but there are things that I want to do that make it a bit like a project car. I already have a thread on my engine woes, now they seem to be fixed I will have some pennies to spend on my "not a project" project car. There are some things that I have already done that I have not specifically documented, but I enjoy keeping track of things I do to cars, so here I am. I do most of my own work with help from a friend in his "shed". Already done things are, Head Gasket - What a nightmare Charge air cooler EGR Cooler All associated HG seals and gaskets New Turbo Lowered on Eibach Sportsline Springs Solid Dogbone insert Other engine mounts replaced with new Wheels changed - This was a bit of a random one, the Audi wheels came up in mint condition and were a lot cheaper than getting mine refurbed. Wheels spacers added Rear Windows Tinted Had the bootlid and bumper repaired and repainted as someone had fitted a number plate with wood screws and the bumper had a couple of knocks Fitted the larger and newer headunit Bought the cover to block off the intake to get more air into the air box Removed the snow filter in the airbox cut out the additional holes on the intake pipe to give more air into the airbox. Added a Reiger splitter that I got for £15! Cambelt, water pump and aux belt all replaced Oil pump belt replaced DSG gearbox serviced New discs and pads all round Car is also stage 1 and has had a DSG remaps as well So whats in plan, well as this isnt a project not much.... Suspension refresh - all bushes and links will be replaced / upgraded and new shocks. Chassis stiffening parts High flow filter Turbo baffle replacement TIP replacement Wheel studs Need to detail it at some point been a bit lazy with it as the engines been broken. Sure I will add more to the not a project list as I get on with it!- Improve VRS handling?
As others have said the bushes may pass an MOT but they really only fail when they tear, so overtime they degrade and crack and become soft (much like me it seems), refreshing the bushes is a good place to start. There are so many on these cars I would start with ARB bushes and then look at things like swing arms etc. I had mine on the ramp recently and I was looking at the state of the bushes and thinking I should probably start a refresh as they are looking a little worse for wear after 11 years.- Coolant tank replacement - Should I be worried?
Unfortunately I cannot see the images that you uploaded, however my experience is that the bags are pretty robust, I have removed a few from expansion tanks and never had one split (but I am aware that they can degrade over time). There is often some small amounts of residue in the expansion tank and if you have not had any issues to date and have replaced the expansion tank I would not expect you to suddenly have issues.- Exhaust gas getting into the coolant
Hard to tell but I had a negative sniff test at first then I got a positive once I’d replaced the egr cooler and the charge cooler, ended up being the head gasket. Diag can be really tricky as there can be a few issues that combine to hide the true state of the engine. I thought I had it but then I ended up with another issue that was linked but made worse so needs some careful diag. I have a who thread on the diag and fix of mine if this helps at all? - The "Definitely Not a Project" Project Thread
