2014 Skoda Octavia Mk3 2.0 TDI – Coolant Loss / Possible EGR Cooler and/or Head Gasket
Hi all,
I’m looking for some advice regarding an ongoing cooling-system problem with a 2014 Skoda Octavia Mk3 2.0 TDI, 6-speed manual, with roughly 300,000 km.
I bought the car on 25 July 2026. It drove reasonably well initially, but after a little over a week the coolant warning came on and I found that the coolant level had dropped. Sometimes I just release the presher in the expantion tank and the coolent comes bubbling back, after about 20-80km of driving the next day I find that the the tank needs to be topped back up.
So far, the following has been done:
  • Coolant/antifreeze was replaced and the system was checked.
  • The water pump was subsequently replaced after it was suspected of being faulty.
  • Despite the new water pump, the coolant problem continued.
  • Several mechanics have looked at the car. The main possibilities suggested have been either a head-gasket problem and/or a faulty EGR cooler.
  • Most recently, a mechanic carried out a cooling-system pressure test. The tester was left connected for essentially the whole day and the system did not lose pressure.
  • Because of that, the mechanic could not conclusively say whether the problem was the head gasket or EGR cooler and did not charge me for the diagnostic.
  • One mechanic has verbally stated that both the ERG and the Head Gasket have failed. But would not give me a hard quote for how much the repairs would cost.
  • The strange part is that the car can apparently hold pressure during a static pressure test, but it is still losing/using coolant when driven.
At the moment I’m trying to work out the best way to distinguish between an EGR cooler leaking internally and a combustion/head-gasket-related problem before spending a large amount of money replacing parts.
I’d particularly appreciate advice on:
  1. Whether an EGR cooler failure on the 2.0 TDI can cause coolant loss while still passing a normal cooling-system pressure test.
  2. The best way of testing the EGR cooler specifically.
  3. Whether there are any particular 2.0 TDI coolant-system faults I should be checking before condemning the head gasket.
  4. Whether there is any value in doing compression or leak-down testing on the engine in this situation. (Finding a mechanic willing/able to do this test has been next to impossible in my neck of the woods.)
  5. Are there any known signs that would distinguish an EGR cooler leak from a head-gasket failure on these engines?
The engine otherwise runs and drives, and the most recent pressure test showing no pressure loss has left us without a clear diagnosis.
One mechanic has suggested trying Steel Seal/head-gasket sealer to see whether it changes the symptoms, but I’m hesitant to put any type of sealing product into the cooling system before properly identifying the fault - since the car is legally under warranty.
Any advice from people familiar with the Mk3 Octavia 2.0 TDI would be greatly appreciated, particularly if you have encountered a similar coolant-loss problem.
Thanks.
I had a very similar issue on my mk3 VRs tdi, I have a whole thread on the diag and fix.
I’d guess both EGR cooler and HG have failed you can test the former by buying a bypass kit of the cooler this does what it suggests and bypasses the coolant from entering the cooler. If the coolant still sropa you know it’s likely a HG issue.
You can also do a sniff test on the coolant and see if you have combustion gasses in the coolant, although that could be from the cooler or the HG so all it confirms at that point is a failure.
In terms of fix, id started with a cooler (I have a pretty much new Mahle one I can sell, was on my car for about 2 months). You can also pressure test the cooler once it’s off the car.
My issue was a combination of cooler and HG, the latter becoming much more obvious after replacing the cooler as I think pressure was escaping from the cooler and when it couldn’t do that it escaped from my expansion tank.
HG job is pretty involved, you’ll need to get the head pressure tested as well just to be sure it’s not cracked and then about £900 worth of seals and gaskets etc. it’s a good 10 to 14 hrs of work so if you’re not going it yourself it’ll be over £2k for a HG job alone, but there’s other items worth doing while you’re in there.
Here’s my thread
I'm interested in the part, but I can't DM you directly.
Ok, so for further updates with new mechanic number 6:
We took it to a new mechanic, who was apparently the first to check if combustion gases were actually getting into the expansion tank; we got that color change test kit, and it stayed blue.
Next the mechanic first bypassed the EGR cooler. I drove the car for about five minutes, but the expansion tank immediately started filling with air and pressurising again.
I drove it back, and he kept the car until the following day. He then also bypassed the water-cooled charge-air cooler integrated into the intake manifold, which is the large metal unit that takes the compressed air coming from the turbocharger.
With both the EGR cooler and the charge-air cooler bypassed, the expansion tank is now holding coolant normally and, so far, is no longer filling with air.
So its the charge air cooler.
Remove EGR bypass too confirm that isn't leaking would be the next step yeah
Interesting the turbo makes enough pressure to overcome the coolant, but I guess it runs about 10-12psi boost so probably on par with cooling system.
No doubt a bit of coolant get leaked into intake charge and burned.
Hopefully not too expensive to fix.
Really, if you are skint you could almost keep the bypass in and tolerate the reduced preformance without the cooler doing anything. Maybe for a while anyhow.
I had the same issue, charge air cooler coolant leak.
Found the slow leak into the cooler via USB phone endoscope.
Inconclusive sniff test had me worried about the HG or block.
I bought a OEM Valeo one from Autodoc Ireland and had my indie fit it.
Total cost was £4-500 IIRC
Dealers wanted £1200+
Annoyingly I now have ?EGR woes too. Bloody complicated emissions fudges.
