Everything posted by skoda1982
STOP / START
I thought you meant up and down
Optional Footrest - Part 5E1064209
Kamiq comes with foot rest
Fingerprints on Touchscreen - Scala 1.5 TSI DSG SE L, Automatic, Petrol
skoda dealers do them
1.5 tsi Monte Carlo
Ask about your warranty with springs being added. Is apple car play not standard anymore
Navigation Database update Amundsen
Check on the Skoda website for compatability
Yeti to Kamiq
The karoq replaced the Yeti
The next maps update is May/June they are every 6 month
Check your phone is compatible on skoda website
There's no sd card like there used to be it has it built-in
It downloads automatically there is no rollback or fix but you could try a reset hold on button till it restarts. Doesn't tell you but when you're system updates do a restart. And after 12 months you have to pay for skoda connect for downloads and software updates
70 plate kamiq se, no 12v socket
You could have phoned skoda assist
Between front seats under front of arrest
Yeti to Kamiq
Don’t now why people like to see over the bonnet there’s no need and if they sit so close to the steering wheel and the air bag goes off it could kill
Yeti to Kamiq
My seat is at it's highest and I have the mirror tilted slightly down and have to look up to see through don't get blind spot as it not in the way You must have a longer upper body or your seat to high
STOP / START
Your car is on all the time using power. When you lock it the alarm is on. It's on the Internet esim. First time I have heard steering wheel to high there are no sensors for that. There is a sensor if you don't hold the steering wheel
STOP / START
Yes as the 12v socket is always live so your dash-cam could be draining your battery
quick questions, entry/exit and engine size
If you are going for the 1.0l get the 110ps upto 70mpg
Kamiq Monte Carlo 1.5TSI DSg
The SEL only came with climatronic and not manual.
No the sel has always had climatic not manual. The Monti Carlo comes with manual you can ad climatic as an option. I just leave mine in Auto never used the screen if it needs defrosting I press the max button when defrosted press again goes back to auto
Do the running in procedure before being frugal
Manoevre braking
If you reverse and don't put your brake on when you get a full tone on reversing it will do it for you
Yeti to Kamiq
First service will be a oil change interim service with any updates just under 10k miles or one year second will be just under 20k miles will be oil service plus inspection service.
Scored rear brake discs
Mine was the same but after 6000 miles all smooth
Virtual Cockpit film peeling off
Probably water temperature over limit
Error ERR_1002_DM_IN fixed
Skoda recommended using there usb-c leads as not to cause errors
