skoda1982
Everything posted by skoda1982
  1. You can set the sensitivity in settings set it to LATE so it doesn't recognise cars at junctions if you are turning left
  2. It's the vag group supplying them not skoda
  3. Not really understood kessy didn’t see the point so much messing. so stayed with press the open button to open the doors you select in settings get in press start button. Press stop button get out shut the door press once locked with deadlock press twice locked without
  4. What I put as mobility offers are.manual
  5. The Kamiq monti carlo 1.0l 110ps is £0 advanced and the kamiq SE Drive 1.5 is £95 advance. Both manual. 1.5 SEL-E is £595 manual advanced
  6. Here’s the mule
  7. Maps are done twice a year and are not backdated the next is about June. Check your version of nav update and the one now
  8. You cannot load from Skoda portal on a memory stick it has to be done on a Skoda memory card. The kamiq system won’t read it
  9. Why would thieves want to steal a Skoda scala. Stop worrying about wether it’s going to get pinched and enjoy the car
  10. It’s not compatible check Skoda compatibility website
  11. You cannot update from the portal for the kamiq it’s done by Skoda connect that does it automatically when one is due if you don’t have Skoda connect you won’t get them
  12. You cannot permanently disabled kessy. in car settings you can alter what doors open. And as a safety measure the key turns off after a few minites when not touched/moved so it cannot be read. Get the MyŠKODA app so you can track your car it acts like a tracker.
  13. The Fabia 4 is not a facelift its all new. They have to keep it looking something like a Fabia otherwise it would have a different name
  14. They have put it on hold as to reduce the backlog of current version may be end of year or early next. If you have put an order for current version this what you will get you have to do a new order for facelift when it comes out
  15. Stop/start
  16. Turn the brightness down in settings you can even do it for your vc
  17. The 1.5 tsi does not have COD. Is the engine vibrating all the time or just when ACT is activated (eco) on dash. ACT only activates when driving so they cannot say its how it is. Go to another Dealer or reject the car. I have the 1.5 tsi and I cannot tell it running even when it changes to eco. I only use Shell fuel
  18. Are they electric or manual
  19. Looks like the weather direction is affecting that. I go to a empty car park drive about 5/10 mph and apply hand brake not clicked on but with button pressed in and pull up and down to clean. You could try replacing under warranty but you might get the same
  20. And he will wish he didn’t drop the Skoda brand🤣
  21. Didn’t know that they were stainless from the factory. There’s a rusted plate that goes around it
  22. The Kamiq and scala have both the exact same interiors it’s just the body that differs
  23. Not heard that if it was you can only have the 1.0l. They stopped the Diesel
  24. If you’re car is under warranty claim for a new battery. Some batteries in 2019/20 were faulty and changed
