Max M4X WW
Everything posted by Max M4X WW
  1. I will 99% be there. Anyone else?!
  2. I think we are good in groups of 6 from 6 households. Just need to decide if I bring the Superb, Octavia, E39 or Fiesta 😆 depends on the weather mainly.
  3. You may be right, Google seems to suggest it is opening on the 6th June!
  4. Hi all, has anyone got the tools to do this in Hampshire/Surrey? Would happily pay for your time. I have Bilstein B6 on the front and standard on the rear currently but the car is 5 years old and has been taken apart so could probably benefit from being calibrated even though it's not lowered. Thanks
  5. The last time I drove past the pub it look like it was shut as it had to let signs outside. There is a pub slightly closer to petersfield called the seven stars which has a big car park.
  6. Bilstein even do B4 Damptronic if you want a standard replacment. I'm not sure any are serviceable or less likely to fail though - who knows!
  7. The Bilstein code was 23-254343 They do ride a bit firmer, but my old shocks were leaking so not sure how good the ride should have been before, I am on 19's so that obviously doesn't help. Handling is definitely improved but again I am not sure by how much as I am comparing to suspension past its best and I have only done the fronts so far.
  8. Only change the springs if you want it lower, otherwise the stock springs will be fine as the B6 units are not any shorter than standard dampers.
  9. I Think that link is broken.
  10. Anyone got a link for this footrest? Thanks
  11. How is traction with the narrow tyres in the dry?
  12. I've ordered some B6 front shocks from Demon Tweeks as they were cheaper than B4's from Euro Car Parts. I doubt they will show up as the price seemed too good to be true and the website stated 'in stock within 8 days' or something but we will see.
  13. I was thinking it would be good if you could adjust the settings. Compared if current settings were Comfort "-1" Normal "0" and Sport "+1" I'd want them set at something like -0.25, 0.25 and 1.5!
  14. Sounds like it would be perfect for what you want and they should be fairly easy to fit.
  15. I'm looking into this at the moment, anyone got any decent UK suppliers? My front shocks are banging after 60k miles, but I only got the car on 55k so I'm not even sure what the standard ride should be like. Are the B6 any harsher? Thanks
  16. Are your winters the same size as the L&K 18's?
  17. Hi all, I want to remove my rear wiper on my 2015 Hatch. I don't like the look of it and think I can do without it. Problem is I can't figure out how to remove the interior trim to get to the motor! Any ideas? Thanks
