Eddie-NL
Everything posted by Eddie-NL
  1. You won't find it as such as it is now a combination CCM and CECM classed as a BCM it is on the drivers side in the footwell area, you will see relays and 3x large plugs that plug in to it
  2. do you mean the cluster or the screen in the cluster?
  3. go and try starting it, then do a scan
  4. There is no fault other than the alarm horn. I would guess that is after he cleared the original scan, A lack of power supply to a module will leave faults in that or other modules
  5. Your one is 3C0 937 049 AJ with vcds you should be able to test the relay function, i will have a look on my cecm
  6. Plug your VCDS in and do an autoscan https://www.google.com/search?q=vcds+how+to+do+an+auto+scan&rlz=1C1CHBF_en-GBGB745GB745&oq=vcds+how+to+do+an+auto+scan&aqs=chrome..69i57j33i22i29i30l7.11145j0j15&sourceid=chrome&ie=UTF-8#kpvalbx=_0xpjYJuUF-CO9u8Po-CV2Ag18 Post the scan up, just edit out your vin
  7. They are quite cheap now, but you will need vcds to fit it, if you are not buying exactly the same one don't copy and paste the coding either. Check that the relays are ok, you could try using the same numbered ones in a different place or test them.
  8. The actual name for it is CECM Central Electronics Control Module You can also find it in a host of VAG cars 2004 - 2009 Mk5 Golf, Early Tiguans, Scirocco Some relays are controlled elsewhere. You need to scan the car and try finding out which Terminal is not working The Relays are Terminal 15 Switched Live Terminal 30 permanent Live Terminal 75 supply http://www.volkspage.net/technik/ssp/ssp/SSP_319_d2.pdf
  9. Testing this unit in my car, till I have my own one ready. Guy who I know kindly lent it to me for testing purposes.
  10. ideally the CAN should be coded for telephone in the installation list. It will work with out Diagnostics in pic is to show that it is working and to confirm part number Your link for GPS module looks good and it has a right angle plug which is good too, so not to damage the wiring if there isn't much space.
  11. What phone are you using? that 5N0 module is a premium one and it doesn't like iphones This kit is a better offering https://www.ebay.co.uk/itm/133678611161
  12. The scales don't look original, have they been changed?
  13. If the cluster has a message NO KEY = Cluster cant see correct Key. So if you don't get that your key is ok If your car starts and dies after a couple of seconds then that could mean an issue between the Cluster and ECU best to get your car scanned with vcds to point you in the right direction
  14. If you dont have the large camera in the windscreen then it has nothing to do with ACC the TSR Lane assist camera does have direct wiring to the front radar
  15. Mileage recorded in a vcds scan is from the instrument cluster, you can check it on some ECUs
