Everything posted by mark999
Back Tyre for 1.2 TSI
I’ve had Goodyear all seasons on several cars including my old Octavia scout, SLK230 and Auris hybrid. I’ve been delighted with the cold and wet weather performance. Personally I would match all 4 tyres if possible, the problem with the 16” Fabia tyres is that it’s a very expensive size. A while ago I priced up a set of 15” steels with cross climates for my Fabia - they were about the same price as just the 16” tyres A good midrange 16” summer tyre is the Khumo HS51 or 52. They are around half the price of the all seasons. Mark
Issues with Key after battery replacement
I’ve had a nightmare with keyfob batteries for the Fabia - even major brands. Now I always test the new battery before changing. This has been a godsend Ansmann Alkaline Button Cell & L...Ansmann Alkaline Button Cell & Lithium Coin Battery TesterSome of the new batteries were nearly dead. Mark.
Dealer issue again
If you paid on credit card you could try a section 75 claim with your credit card company. Earlier this year I successfully claimed the repair cost from ATS, after they stripped the threads of the wheel bolts, on my Merc. Mark
Fabia 3 Estate Metallic Clonk From Rear -Easy fix
For a while I’ve been getting an occasional metallic clonk from the rear of the Fabia. Worst on right hand turns but sometimes over potholes I was convinced I had a broken spring. Local mechanic put it on the ramp and found a big lump of gravel in the spring cup. Thankfully a cheap fix 😀
ATS Hull Stripped Wheel Bolts
usually have tyres delivered to my local garage for fitting, but couldn’t get the Asymmetric 6’s for the SL delivered for anywhere near the ATS fitted price. Really wish I had followed my gut instinct and paid the extra. ATS managed to strip 6 of the wheel bolts claiming previous damage! The last time the wheels were off was at the service at my indie back in August. Reckon I’d have lost the wheels by then. Gingerly drove it to my indie and they were able to retap the threads and supply new wheel bolts. A complaint to ATS got the standard denial so I submitted a section 75 claim with my credit card, and this morning had confirmation that my claim was successful.
Tyres
Take a look on the tyre reviews website 😀
Tyres
The Khumo Estca hs51 and hs52 are very good tyres for the price. We have the HS51 on the Fabia and a relative has the later version on this Peugeot partner and we’re delighted with them. Unfortunately the 16 inch tyres are a relative rare size, hence expensive. Out of interest I priced up replacing the wheels and tyres (with steel 15”wheels and cross climates) and they worked out the same price as just replacing the 16” tyres.
Basics: how to restart the engine after manually switching off?
It’s probably worth getting the battery tested or at least charged on a smart charger. If the problem continues it’s probably worth getting a diagnostic scan. Mark
Are you depressing the clutch when starting? Mark
Scout 2.0 BMM Manual (2008) - Fluids
Don’t forget to change the hidden filter in the Haldex, in their wisdom Skoda don’t include it on the parts diagram.
Fabia Turbo lag
Our 110tsi 6 speed manual has the same “problem” being used to the torque of a pd diesel I was very surprised that I would need to drop to 1st when merging on to roundabouts. My other motors have 3.0 v6 engines so loads of low speed torque 😀 they’ll never get to the 62mpg that Fabia did on our airport run🤪
A car thats only done 1000 miles in 4/5 yrs due to owner being ill
Check the date stamp on the tyres, if they are 15 years old I would seriously consider changing them. Mark.
Dpf issues?
There are companies that offer to clean the DPF which may be an option. Mark
Dpf issues?
You really need a scan with VCDS which will give you the soot and ash content of the DPF and should highlight any problems with the DPF pressure sensors. At around 155k it’s likely that the DPF is at the end of its service life. Mark
I can’t delete old connected phones from the head unit
You could try rebooting the unit by pressing the volume button for around 10 seconds. You will have to pair your phone again and will probably loose other settings. Mark
Spark Plugs Change Time or Mileage?
VW part number for the plugs was 04E 905 602 (NGK PKER7A8EGS) at the time there was no difference in price between VW branded or NGK Mark.
3 genuine VAG spark plugs for my Fabia were £45. Got my local indie to fit them for a few quid. Mark
Change Haldex oil in a Skoda Octavia scout 4x4 2008?
IIRC it’s every 4 years or 40K Miles. Don’t forget the hidden filter if yours has the gen 4 Haldex. Loads of good info here:-
First Brake Fluid Change At 2 Years?
Thank you just checked, it’s definitely a 2021 model year😀 Booked in for the fluid change, don’t want to risk the warranty or extended warranty. Mark
Thank you. It was registered in Jan 21 so probably is a 2021 model. Mark
Just had the 2nd service carried out at my dealer. I was always under the impression that the first brake fluid change was at 3 years, The dealer advises that Skoda now recommends at 2 years. The Skoda website still clearly says 3. Does anyone know which is correct, I politely decline the brake fluid change and the recommended air con service. Mark
key fob battery
Well after yet more battery changes, my dealer has eventually replaced both key fobs. Fingers crossed for batter battery life. Mark.
MK2 Scout buying advice
Our mk2 140pd Scout was an excellent car. We too averaged around 43mpg. If you do get a mk2 make sure that you change the hidden filter in the Haldex coupling. Skoda, in their wisdom, don’t even show it on the parts diagram 🤪
What fits in the boot of the Fabia mk3 Estate
I’ve been really pleased with our mk3 Fabia estate the boot is definitely tardis like. Needed to pick up a mk3 focus bonnet last week. I was amazed to find it easily fitted in the boot. Saved me a fortune on delivery delivery 😀
key fob battery
My dealer changed both key fob batteries on the 5th May, yesterday got the replace key fob battery warning. Just over 4 months. My dealer isn’t interested saying they only expect them to last 3-6 months. The car doesn’t even have keyless entry. My Jags Keyless fobs lasted 4 years. Just sent another email to Skoda customer services. Mark
