Everything posted by varooom
Check left parking light error message
Fair play, best let them sort it out as you have only just picked car up!
What's the car history: Have you changed bulbs recently, like fitted LED in place of Halogen? Have you made any coding changes to the car? If you haven't then maybe previous owner did some changes. Do you have something to read the error codes with?
Amundsen Mib2 Map Updates 2023
The Skoda links and maps are 1810 and marked as 2022-23 The VW link are 1910 and marked as 2023 You need the large download for Denmark, and probably a 32GB card, I was not able to fit the large download onto the 16GB card I have EDIT: You probably need/use ECE 2 region, so should fit on a standard 16GB map card
Amundsen MIB2 Firmware Update
Yes I shall generate a PM for you in next 3-5 minutes
Yes this is correct 0480 version exists
drivers door window squeals in dry weather
Once you get a working solution for you, be good to come back and report too so that others may benefit. Mine has wind noise, but the radio just get's turned up as it has bigger problems than that.
Don't forget @Breezy_Peteadvice for a good clean before you splash out the bucks. I assumed it would be clean as I keep on top of mine, the detailer in me likes it when it beads water.
A rubber sealant/protector is often applied by people when the window makes some noise when lowering/raising. Caused by the age of the rubber and UV affecting it. Things like 303 Rubber Seal Protectant / Gummi pflege and of a similar ilk can be used to restore some of the properties. If I have got the problem correct.
Canbus gateway location
It does state "the assembly work is identical in RHD vehicles" so with luck it should always be behind steering column, but you are right to question this as there will be differences between LHD/RHD.
Yes it would appear so. Airbag and ventilation in the way too.
Yes I shall send link in next few minutes
Infotainment keeps switching off and on randomly
Have you checked radio fuse(s) visually to see if one has a hairline crack? Connector at back is unlikely to have become loose, but never know. Have you scanned car with diagnostic tool?
Driving on the left France etc
Sure thing, interested to see how this pans out. Halogen bulbs when turned off will "dim down" and LED's the light goes off instantly. Back of the headlamps will be different too. Dealer should be able to look up your VIN, and if friendly enough could print out what's been fitted at factory.
To my eyes, and parts pictures, it appears you have LED style. Best to either take a picture of the rear of the lamp, or some actual beam shot images as we get darker. Turn the car around and aim at back wall of your garage would be perfect.
Had a quick look, and these should be the Halogen choices for the Karoq 2022 PR Code: 8WB This should be the LED choice for the 2022 Karoq (it has 4x light sections as do yours) PR Code: 8IT
Have you determined exactly what headlights you have fitted yet. The self study manual for the car only shows halogen or LED. A picture would reveal exactly what is fitted if you are not sure.
@paco https://www.manualslib.com/manual/1985337/Skoda-Karoq.html?page=53 If you need it, this link shows the menu choices you need to find, and only applies to full LED to make the adjustment.
You should aim the car at a wall after dark, take a nice picture of the beam. You can also get a 2nd person to cover NS/OS headlights one by one so you can see each headlight beam in isolation. Then if you have travel mode option in menu's you can toggle it to make a comparison.
As long as the smoke stayed inside the car, all good 👌
2017 Octavia Estate
I don't know if this is applicable to your car (too hot for brain to work 100%) https://www.briskoda.net/forums/topic/477657-amundsen-mib2-firmware-update/?do=findComment&comment=5676531 Screen Amundson 2017 can go blank (customer complaint)
Kind of a standard quoted value, actual time depends on hardware (SD Card speed and CPU/internal storage speed) iirc mine was about 20mins
Travel mode is the correct title.
0480 version is available I shall send you a link in a moment
Latest Infotainment version Bolero
You have PM for MSTD_EU_SK_P6230_0490 file
