GiscoYeti
Everything posted by GiscoYeti
  1. Hello, look here to find the OCU version you need, follow the suggested procedures carefully, extract the file with 7Z and format the USB in FAT32. Make sure the battery is fully charged or connected to a maintenance charger of at least 15 A, and keep the emergency lights on throughout the update.
  2. Original VCDS Ross tech. this is admap 09 >> 2Q0 937 090
  3. Hi, I've also had Connect activated since 2020 and the version is currently stuck at 25.8. I think it will remain that way until March 2026. I used to get monthly updates, but this year I've only had them for four months. You should update the navigation software and the radio database.
  4. Hello, I own a Kamiq MY20 and I have the Ambient package. In my settings, I have the items I am attaching. It should work.
  5. The Battery is 49Ah e 320A see on site https://ifinterface.com/page/page3.php?langid=1 Auguri "Ad majora"
  6. This is true and very important for Start&Stop, but it is very simple with CarScanner and inexpensive.
  7. Hello, I replaced my Kamiq style 1000cc battery two years ago. I took into account the restrictive measurements and power requirements and found two brands, EXIDE and YUASA, with a slightly higher amperage 49 Ah > 55 Ah(perhaps avoiding coding) but with almost double the power, 540 A, with EFB type. At the moment, I am very satisfied with the change I made myself in 5 minutes. I am attaching the measurements and data for the original battery from spare parts. Translated with DeepL.com (free version)
  8. Hi I had my 5F unit replaced under warranty already in 2023, today we have more experience, first I would try to activate for free for one month in trial perid "Infotainment online" in Skoda site do a reset of radio by removing fuse 19 and make sure you are main user and give maximum privacy permissions, so force map update using navigator as well. Use Kamiq always connected in hot spot and in instructions try to force system updates and others. If you have a friend with OBD 2 dongle with carscanner or with OBDeleven I would check the version of OCU ECU 75 and if it has errors. Updating OCU 0139 was part of a recall and if it was done (to me in 2021) the updates to 5F also went through and hopefully the radio will start working again. I remain on standby Translated with DeepL.com (free version) My old maps
  9. Hello also I had Amundsen H12 with SW0156 after a recall for OCU updated to version 0139 and an update to version 0278 the nav did not update maps anymore and after complaints I was changed the hardware and installed version H22 with SW 0306 everything is back fine. The problem with the OCU update is in the activation of the SWAP and the FEC 0071C00 which enables the automatic update of the maps via OTA with connect active (49€ year)therefore SW update of the nav must also include the complete update of the OCU Translated with DeepL.com (free version)
  10. HI, Are you Main User? My last Update
  11. I have VCDS original Rosstech and " Address 75: Telematics (J949) Labels:* None Part No SW: 5WA 035 284 E HW: 5WA 035 284 Component: OCUGen3High H20 0139" is original LOG after update from OCU H20 088 to 0139 SW add ......"E" During Update emergency light ON et engine ON or connect charger
  12. IT'S OK Address 75: Telematics (J949) Labels:* None Part No SW: 5WA 035 284 E HW: 5WA 035 284 Component: OCUGen3High H20 0139 >>>> for my Kamiq MY20
  13. GiscoYeti replied to a post in a topic in Skoda Scala Guides
    HI Have you carscanner?? SVM is "Elementare WATSON"!!!
  14. YES here>>>>> https://vwts.ru/
  15. Hi, can help with this???
  16. Hi in my 2020 Kamiq I changed the original battery about two years ago, in the three years of use I charged it with a maintainer every 40/50 days and checked before the change with a 60% SOH. I now mount a 55AH carbon 2 technology battery, because of the size of the positive terminal cables and a spark of 540. I must say that I managed to have a very good efficiency after about two weeks of standstill I measure a voltage above 12V, the original battery is too low inrush for the on-board electronics a 60AH would have been perfect as in the Audi A1 GB Translated with DeepL.com (free version)
  17. I Have Sport Chassis Control on Kamiq MY20
  18. WHERE? could you put a link thank you!!!!
  19. HI see here https://mega.nz/file/dgNAADwQ#h7p60yQb9OmM0pQ2O9nZvIPsi_k9TMnw Om83pBj3hmY
  20. See here this is right post.
  21. The unit you want to buy, to my knowledge, has to be unlocked by the seller, each unit when it activates is customized to the VIN, only dealerships can unlock in order to be reinitialized. You should check the FECs of your unit in the engineer menu if 007b00 and 007a00 are legal, so if they are you can have carplay and AA wired, then it is easy to make it wireless.
