Micky 32
Everything posted by Micky 32
  1. When my car was new in 2024 kessy on the drivers side was patchy. But the last 1.5 years it has been working flawlessly.
  2. Yeah it has that pulse setting but i’d say the battery would need to be disconnected to use it. It wouldn’t surprise me if there’s sulfation. According to the obd11 the battery never goes above 70-75% soc and it gets lots of driving 30k a year.
  3. Yep. Charger says full after about 30-40 mins
  4. According to obd11 my “batttery aging performance” is down to 70% after 2.5 years. 70ah Varta EFB+ 70ah.
  5. Mine currently reads 4.6 -4.8 70ah size.
  6. If your battery is a EFB+ the internal resistance 7.4 mohm seems a little high. Ideally should be around 4-4.5 ish mohm
  7. My March 2024 built RS diesel suffers from intermittent reboots. It might not happen for a month then it might return and happen a few times before stopping again for weeks. It seems to happen about 20ish seconds after i start the car.
  8. You should be able to find engine starts in the ecu. A lot of other factors of ah draw. Car sitting in trafffic when engine is off. Locking and opening of the car. Brake regeneration cycling the battery etc
  9. OBDeleven. Total mileage 72,000 miles. Total engine starts 24,500 including start/stop. Battery resistance averages 4.6-5.2mohms depending on state of charge and temperature ( i have seen it reach 50 degrees C in the warm weather ). I don’t trust electronic battery testers on EFB+ batteries. My tester for at least a year fails my battery but it performs flawlessly and start stop works flawlessly.
  10. The total energy throughput and charging throughput on my 2.5 year old vRS is nearly 14,000ah.
  11. Over the last few weeks reboots. It’s the same kind of reboot as a forced one by holding the power button. It won’t do it for weeks and then it reappears. It’s on the latest software. If it reboots i have noticed that it does it about 20-30 seconds after starting the car. It never does it during a drive.
  12. Yeah. It was done at 40k.
  13. I have noticed when moving slowly or coming to a stop i can hear in the background the DSG slightly noisey. Best way i can describe it is like a bearing graunchy dry loose worn cogs kinda sounds. It’s quite low but i notice it and it’s annoying. I feel like i’m driving an old car. Is this normal? The car has done 67k miles.
  14. Go into engine. Then live data. Scroll down until you find it. Post your results, age, mileage etc. Would be good to compare.
  15. Going through obd11 on my car a 2 year and 2 month old diesel vRS with 64,000 miles. You can see how many times the starter has been activated. Manual starts on mine = 8860 Automatic starts ( start stop) = 13038 Total 21898! That’s an average of 27 starter activations a day! How does the poor little battery cope lol
  16. Lately they have being getting noisy, like a grumbly sound when opening and closing. Any ideas? They seem to work ok otherwise.
  17. After that beautiful 87% charge today it eventually went back down 74% SOC ( according to obd 11) after a few trips. I then took a 40 mile round trip . 20 miles to my destination ( no stops). When i got there it had reached 77% soc. I was there for an hour. When i got back into the car for the return journey it had dropped to 73%. By the tiime i got home it only reached 75% soc. There’s just no way normal driving will get my battery to 80%.
  18. Yeah i have used the multimeter and a battery monitor and they all correspond with the bms reading on obd11. All vw’s seem to have brake recuperation. I think it’s more intense on the new cars. My old 2017 Passat with brake recuperation and a AGM battery never went over 14.5 volts unlike the 15-15.3v i see in my vRS. I rarely ever see my SOC reach 80% on the bms. At most even after long drives i will see max 75% but it mostly hovers around 70% . If you go in and out of the car a few times ( unlocking and locking) when parked it doesn’t take much for it to drop down to 63-65%. The start stop doesn’t work when it drops to 60%. Also the brake recuperation doesn’t work under 70% the battery constantly charges.. A few observations. If you do get the battery to 80%+ ( according to the obd11) the alternator completely shuts off but you get the charging voltage when braking. Between 70-80% the alternator will trickle charge with voltages ranging from 12.7-13 volts but on braking the usual 14.6-15.3v . Below 70% the battery charges constantly 14.5-15v. My charger is only a 6 amp, nothing special. It started off at 5 amps draw and over the hour/20 mins gradually dropped down to 1 amp before shutting off and saying “ full”.
  19. I stuck it on the charger again for the craic. This time it took longer to “fully” charge the battery. One hour and 20 mins. Hooked up the obd 11 and it reports the state of charge is 87%!. It usually hovers on average 68-75% with every day driving. However the ah reserve capacity didn’t rise much. It was about 50ah the same reading as when it was at 70% state of charge. On the Topdon tester i got an extra 60 amps bringing it up to 591 amps out of 700 and reported “ good battery” Interestingly Varta advises against using EFB batteries for brake energy recuperation cars. They should only be fitted to cars with basic start stop. They say that the spike of high voltage and forced high amps in recuperation mode can increase degradation prematurely. Doing logs myself i have seen 15.3v and about 30-40 amps forced into the battery when braking or slowing down. Sometimes i have seen normal constant charging at 15v. Mostly i see 14.5v but if my battery is pushing 40 degrees it drops to 14v constant charge. I guess it’s VW and their bean counters.
  20. What i noticed on the charger the amp draw started off at 6.5 amps and the charging voltage 13.5 according to the “ smart charger” . Over 30 mins the amps dropped quickly down to 1 amp and the charging voltage increased to 14.8v before it shut off registering “ full”. The battery ceased to accept anymore amps. I guess my concern was that if the battery charged from 80% to 100% in only 30 mins something can’t be right. I’m sure it would take a lot longer to charge from 80-100 . I have a 9 year old worn out AGM battery from my previous car . At rest it reads 12.37 v ( they are usually 12.9v when new) . If i put the smart charger on it it’s fully charged within 5 mins but drops back down to 12.4v in a few hours. But i know that battery is f****k . I put the tester on my EFB afterwards. Voltage 12.9v and 530 amps out of 700 amps EN and “Replace battery “. The obd11 reads the battery state of charge 73%.
  21. Interestingly i popped the intelligence charger on my battery today. According to the obd 11 it was down to 65% after a short town run. The charger said ot was “full” after only 30-40mins. That’s not a good sign to charge so quickly?
  22. Most of us on here are enthusiasts and we love nothing more than popping our bonnets up and putting chargers on our batteries etc. i do have a neat little smart charger but it doesn’t have a EFB setting just normal or AGM. I’m guessing that can’t be used? However there’s a 70 year old lady up the road from me who owns a 2024 Octavia. I can’t imagine her ever putting a charger on her car or caring about chargers. Interestingly i know 2 ederly people. One has a 3 year old VW Tiguan and the other has a 3 year old Opel(Vauxhall). Both have start stop and EFB batteries. The VW has a Moll battery . His battery reads healthier than mine on the tester despite his being a year older and doing shorter journeys .Both drivers only do about 5k a year and never have any battery problems. The Opel owner was recently in hospital for 6 weeks and his car fired up instantly. I’d say higher mileage and use have a big impact on those batteries. Constantly cycling from brake regeneration, more starter use, subjected to more heat. If i connect the obd11 to my car at the end of the day the temperature of my battery can be as high as 40 degrees+. My vRS puts the battery through more use than my old 2017 Passat. I’m guessing stricter emissions laws are forcing car makers to make more use of the battery. My current total throughput energy and charging throughput after 2 years is over 11000ah. My old Passat after 2 years with similiar mileage and use was 8500ah. As for the electrics when i’m driving all that would be on is the AC on auto , infotainment system and the LED lights on auto. I never use the heated seats etc. The odd time i might use the heated steering wheel if it’s very cold but that would only be on for a few minutes.
  23. This guy didn’t have much luck with his Varta EFB’s. Gone through 2 of them in 4 years. First one just over 2 years and the second 18 months. High mileage driver and mostly disables start stop. I’m not fully happy with the Varta in my 2 year old vRS. I think it should be better for it’s age. I often get low voltage codes. The odd time a morning crank sometimes sounds a bit low. The car doesn’t do short runs. It has 60k in 2 years. Just to add, i did a lot of miles yesterday so this morning plugged in the obd. Battery state of charge only 66%.
  24. I see the red cross now and again. It must be normal.
  25. My 2024 had the same issue. I was driving across fields and lakes etc. There was recently a OCU update and it has improved it by about 95%. It rarely loses lock now but still not 100%.
