Everything posted by Urrell
DPF cleaning temperature
It's not the engine oil temperature that burns off soot it's the exhaust temperature.
Top of the list in a Bing search. https://www.snapon.com/diagnostics/uk/news-centre/technical-focus/dpf-hints-tips#:
DSG - are they six or seven speed ?
Smaller capacity's petrol engines have 7 speed dry clutch, diesels and 1.8 petrol have 6 speed wet clutch gearboxes. Apparently the 1.6 TDI had a dry 7 speed box but I've never seen one of those in a Yeti.
Retrofitting Amundsen RNS315 - what's needed?
Could be it goes into darker night mode when lights are on?
oil temperatures when towing
That's not very helpful is it. The oil temperature will rise when the engine is working hard and they were just asking what would be the normal working range. Once up to temperature mine non towing goes between about 97 to 102 degrees, when in a DPF regen it rises about 3 degrees.
Yeti fuse location for RHD car
I don't think a vest or umbrella were ever standard parts.
- Yeti fuse location for RHD car
The fuse pulling tool is on the back of the fuse box cover.- All seasons - Yes or No?
I'm the one calling you out on stupid and dangerous comments, I knew you would not provide evidence that """the rating actually means the speed that the tyre can sustain for 600 seconds before suffering a catastrophic carcass failure """- All seasons - Yes or No?
That is not was said earlier, for reference it said """the rating actually means the speed that the tyre can sustain for 600 seconds before suffering a catastrophic carcass failure """ Of course it will likely fail if above either rated load or speed, but should run safely continuously up to rated load or speed not as above for 600 seconds before suffering a catastrophic failure. There is a world of difference between those 2 comments.- All seasons - Yes or No?
Post a shortcut to where it says ""the rating actually means the speed that the tyre can sustain for 600 seconds before suffering a catastrophic carcass failure ...""" I know I am not getting a sensible reply to that.- Yeti 2017 compared to 2013
In MFD Settings Convenience ATA Confirm- All seasons - Yes or No?
That is the biggest and most dangerous load of crap I have ever heard, it is the highest speed the tyre can safely maintain within the load limits of the tyre.- 2015 4x4 Black Edition - ok to have different tyres front to back ?
If you get 2 all season tyres I'd fit them to the back, could be very tail happy if fitted to the front in anything other than perfect driving conditions.- Which coolant please?
The latest coolant specification is G13.- Failing to engage cruise control
My Fabia locked out cruise control when a vacuum pipe to the brake booster split.- Issue with drivers window auto function
It happens now and again without anything getting trapped in the window.- Hardwiring a dashcam - snag hit
Would it be easier to remove if you separated the parts of (the socket and plug) that adapter?- Issue with drivers window auto function
Close window, release switch then hold it up again for about 5 seconds.- OBD11 reader yeti 2011 2.0 CD 140
What make is it?- OBD11 reader yeti 2011 2.0 CD 140
Most cheap OBDII readers are just that, don't think many will go as far as resetting faults.- Amundsen and phone pairing
On that notice? did you download the relevant manual/s?- yeti/ Bodywork issues
There should be that protection film on both sides. - Yeti fuse location for RHD car
